3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to carve a shrink cup
The principle of a shrink cup are, the cup are cut from a fresh log and you put in a bottom made from dry wood. When the cup drys it will shrink and make a tight fit around the bottom. If your skilled enough you can make a cup that are watertight.
This is a easy and quickly made project. I'm using simple tools that most of you already have. My cup is made from birch but you can make it from any wood. It just needs to be fresh cut.
Step 1Tools you need
Tools you need
Most will already have all the tools needed to make a cup. If you want to go very simple you can make it with only a saw, a knife and a hand drill.
But the marking gauge and the power drill makes it easier.
The ax, the froe and spookshave are used to make the bottom.
If you don't have a suitable knife look at my instructable showing how to make the perfect carving knife
http://www.instructables.com/id/How-to-design-and-make-a-perfect-carving-knife/
122 comments
1-40 of 122next »
May 30, 2011. 6:31 AMKittyF says:
you leave the bark on. doesn't that peel away after it all is dry?
Aug 6, 2009. 6:56 AMflio191 says:
does this work with bamboo? or not really since it's a very different type of wood? great cups though, i live in the city an it's hard for me to acquire fresh wood, but next time I'm out in the country, I might just bring my tools with me! Thanks!
May 30, 2011. 6:23 AMKittyF says:
Actually, if I remember right, you just cut a section of bamboo just below a joint, then just below the next joint. smooth the inside of the resulting cup and it already has a bottom, the joint.
Oct 12, 2009. 2:12 PMred-king says:
 technically bamboo isn't wood, but grass... but it might work...
Aug 6, 2009. 11:27 AMlaci37 says:
Well I think at the segmentation parts it's not hollow so if you want a bamboo cup just cut it on the right places.
Aug 6, 2009. 10:57 AMsrilyk says:
You wouldn't even have to "carve" one with bamboo, AFAIK. Bamboo is naturally watertight and the segmentation parts aren't as subject to cracking as wood is (different growth patterns). I'm not sure if bamboo shrinks when it dries, but if so it should work pretty similar to this technique. Now I wish we had some nice birch trees 'round these parts. Bamboo, too for that matter :P
Dec 15, 2009. 9:58 AMwhiteoakart says:
For bamboo, cut right below one of the nodes. That will be your bottom.
The trick with bamboo is to cure it thoroughly.  If you let it air dry, it will crack apart.  To cure bamboo, start with a green piece.  Use a propane torch with a wide flat spreader end.  Slowly, work back and forth over the culm.  It will turn from green to golden brown and smell like popcorn.  Do not burn it. If it turns black, you are going too far.
Dec 15, 2009. 10:01 AMwhiteoakart says:
BTW, do not try to fire cure bamboo while it is whole.  It might explode.  If you want to cure a long limb, or culm, you must first drill holes through the nodes down the center of the bamboo.  Or, it will go, BAMBOOM!  Please don't throw a piece of uncured bamboo into a fire to see what happens. Someone could get very hurt.
Dec 15, 2009. 11:24 AMflio191 says:
xD bamboom... thanks haha
Jul 19, 2010. 11:41 AMtomman says:
do you think it would work to use this ideal to make a ring
Jan 28, 2011. 2:39 AMKalibar07 says:
actually i have in the past made a wooden ring.. it is possible just make sure you watch the thickness of the ring and definately use a hard wood.. so it does not split on you
Aug 15, 2010. 12:06 PMSasquatchKid says:
I made your lask i keep it in my survival kit
Jul 25, 2010. 6:28 PMDon,t try this at home says:
i cant find a berch tree were i live would you sell a cup and if you would how much????
Aug 7, 2009. 9:33 PMpaper sack ideas says:
for those of us without trees to cut, maybe contact a tree service or landscaping company to see if some fresh pieces could be attained.
Aug 21, 2009. 9:27 AMwhiteoakart says:
You can also go around the neighborhood after a big storm. I've retrieved lots of nice wood that way. Magnolia, black cherry, maple, cedar, tulip poplar. (I make flutes)
Dec 10, 2009. 9:38 PMhitman_kiwi says:
You should make an Instructable on making flutes out of wood! the one I found was using PVC.....
Dec 11, 2009. 9:13 AMwhiteoakart says:
Yes, I am actually in the process of doing just that.  I have several Instructables in the works for this.  One will show one of the traditional methods of making a Native American flute from a branch without power tools.  Another will show a more modern way of making them.  With this basic knowledge, I will expand to making a wooden side-blown flute, an end blown shakuhachi style flute, and a wooden saxophone.  PVC is a good starting point.  Whenever I make a new wind instrument, I experiment with PVC first so that I understand the dynamics without having to worry about the labor and skill involved with working wood.
Dec 12, 2009. 12:22 PMhitman_kiwi says:
 That sounds awesome! Cannot wait to see   :D
Aug 7, 2009. 2:16 PMChaseReno says:
O.K., sophomoric question here. Why don't you just not carve all the way through the body of the cup? I'm sure there's a reason. By the way, this is one of the better Instructables I've seen. Great pictures and great explanations.
Oct 22, 2009. 4:48 PMcorey_caffeine says:
please do?
Aug 8, 2009. 3:53 PMChaseReno says:
See? I knew there was a reason. Would love to see an Instructable on how to carve a one piece cup. Cheers!
Aug 5, 2009. 2:43 PMElycian says:
(removed by author or community request)
Oct 22, 2009. 4:47 PMcorey_caffeine says:
PLANTS ARE PEOPLE TOO! lol
Aug 5, 2009. 5:13 PMDon,t try this at home says:
You need to cut one down so it can shrink around the bottom.
Aug 17, 2009. 12:13 PMElycian says:
Aug 18, 2009. 9:28 AMDon,t try this at home says:
I got the same problem but it is termites there in every tree around so I cant make anaything.
Aug 10, 2009. 6:25 PMtomman says:
could you make a ible for the keg
Oct 12, 2009. 2:11 PMred-king says:
 yeah. it would be like "here's a link to this instructable" and then: "use a bigger piece of wood."
Sep 27, 2009. 10:05 AMRon-Ray says:
I would give anything to be younger and be able to spend about a year near you and your family. You know so much about wood, knives and living off the land (so to speak). I can only imagine how much more you know! Only in the past few years have I realized how wonderful and fulfilling crafting things from wood and steel are to the soul and body. But alas... we get older and begin to see the things that are REALLY important in life, just to realize that we are now too old to accomplish them! ... How unfair knowledge and life can be....... (Maybe next time? ;-) Thank you Thomas, for these wonderful insights to life's intriguing basic joys.
Sep 7, 2009. 11:58 AMtomman says:
could you use sandpaper for shapeing
Sep 8, 2009. 3:07 PMtomman says:
thanks any way
Sep 8, 2009. 9:07 AMpeater says:
That is a beautiful bearded axe!
Aug 16, 2009. 9:50 AMgluvsu says:
What patience you have! These are adorable! Also, a wonderful project for someone on survivor!! Hey why dont you apply for survivor. You would be famous for your cups. :)
1-40 of 122next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
221
Author:morfmir(Random stuff)
