How to create simple animatronics- part one: using the MAKE controller
Here's how to build simple animatronics using inexpensive hobby servos and the MAKE controller kit. I wanted to keep this as simple as possible so there is no programming required and the electronics are kept to a minimum so that anyone should be able to do this with a minimum of tools and experience.
I wanted to create a animatronic head for a costume I'm constructing. I wanted it to be entirely self contained- no exposed wires, etc. and unlike many animatronics used in movies, I didn't want to use radio control due to complexity/control issues. I also couldn't afford a commercial animatronics controller.
Enter the MAKE controller! This piece of hardware allows you to connect readily available hobby servos (as well as motors, lights, etc.) to simple analog input devices (I'm using flex sensors) to control movements. I have this set up running the controller in POLY mode, which doesn't require any computer programming and is very easy to configure. Of course you can always program the controller later on to maximize its potential- it's a pretty amazing piece of hardware.
Here's what the finished animatronic armature looks like (it's mounted to an old welding helmet as a test rig) along with a movie clip and what the finished costume will look like- it's a Horus guard from Stargate.
Here's a video of it working-
There are a ton of possibilities using this controller for animatronics:
Make a Predator costume with animatronic head and shoulder cannon
Build a giant dinosaur with a moveable head, eyes and tail that reacts to movements or goes through a pre programmed routine
Create interactive displays and haunted house attractions
Follow along and I'll show how the mechanism for the Horus head is constructed and maybe you'll be inspired to create your own animatronics....
UPDATE: Makingthings.com, the manufacturer of the MAKE controller has removed the POLY mode firmware necessary for this instructable from their website and it no longer is included in the firmware for the controller. If I can find an earlier version of the firmware necessary I'll post it here. They have also removed all tutorials regarding the POLY functions. Bummer. I have started working with the Arduino platform due to it's lower cost, smaller size and ease of use and have created another animatronics tutorial here:
http://www.instructables.com/id/Arduino-animatronics-make-your-awesome-costumes-m/
Step 1Materials and tools
Materials and tools
Materials:
Hobby servos- I'm using Hitec HS 300 and HS 605BB standard size servos. Many standard size servos are available on eBay for under $10 each.
MAKE controller kit- available from Making Things: http://www.makingthings.com
Materials for armature- I use printed circuit boards (PCB's) for the main construction along with some plywood, brass and aluminum.
Power source- I use a 9.6V battery to power the controller and a 4.8V battery to power the servos.
22ga wire- three seperate colors are needed
Flex sensors- these are available from Jameco (part #150551): http://www.jameco.com/webapp/wcs/stores/servlet/ProductDisplay?langId=-1&storeId=10001&catalogId=10001&productId=150551
Miscellaneous hardware- brass hinges, small screws/bolts, zip ties, heat shrink tubing
Miscellaneous servo hardware: http://dubro.com/hobby
Tools:
Dremel tool or saw to cut servo mounting boards and aluminum
Drill bits
Tap to cut threads in aluminum
Soldering iron/solder
Multimeter
Small phillips screwdriver
Wire cutters
65 comments
1-40 of 65next »
May 21, 2011. 5:09 PMtinker234 says:
where did you get that hours guard helmet where plese tell i need to make one to go with my jafa armor on my work bench
May 21, 2011. 7:13 PMtinker234 says:
ohh sorry looked like you in costume should thought about that
Mar 18, 2011. 10:05 PMJaden Vynark says:
Hey I had an idea for an animatronic wolf. Any sggestions on how to make this?
Jan 17, 2011. 7:42 AMScottDC says:
Finally got video of my Horus costume.
See the video over at YouTube:
http://www.youtube.com/watch?v=pKf9VMGt540
Oct 22, 2010. 9:08 AMsunnywork says:
Great work! I'm really glad to find it! spidesk.ru
Sep 30, 2010. 11:40 AMspartan1996 says:
is there a cheep (probaly not but cheap as in under £30/$30 controller kits with 8 flex sensors??? thanks im just about to make a few prothsthetics of predator and figured id use an animatronic head :) (never made 1 before)
Oct 6, 2010. 12:10 PMspartan1996 says:
thanks I have never even looked into animatronics so I'll probably start with an arm lol but still can at least try :).
Sep 10, 2010. 3:42 AMN3v3rm0r3 says:
Can you add more than two flex sensors? If yes, how?
Sep 10, 2010. 7:15 AMN3v3rm0r3 says:
One question: the firmware is some kind of code concerning the MAKE controller?
Sep 13, 2010. 4:46 AMN3v3rm0r3 says:
Aha, can you find the controller somewhere else than the Making Things site? I'm asking because they are out of stock :(
Jun 20, 2010. 11:47 AMChaoBreeder says:
Hey, how's the Horus costume going? I heard you were swamped with projects. I picked up the original Stargate at Walmart for $5, and was wondering, how the hell are you gonna make the mask shrink up into the back? :p
Jun 21, 2010. 6:05 PMChaoBreeder says:
Haha, I was just joking about the mask shrinking up in the back. I have a question for the costume, are you going to do the Movie or TV series armor considering the cold weather?
Jun 26, 2010. 4:18 PMChaoBreeder says:
Sorry for the constant questions but, how are you going to see out of this costume?
Jun 26, 2010. 9:37 PMChaoBreeder says:
Thanks! That'll help me with the scaling of the pepakura file.
Jan 7, 2009. 1:51 AMScottDC says:
I had this idea to make an animatronic Horus costume from Stargate... so I started searching for reference material - I couldn't believe it when I found this site. Ordered a MAKE Controller within 10 minutes of reading about it. One problem is that the latest firmware does not have POLY mode, so you would need older firmware for these instructions to work. I've started writing my own controller code...so far so good.
Apr 9, 2010. 10:34 AMScottDC says:
I did finish my Horus costume for Easter 2009, had issues with the flex sensors so switched to an old PC analogue joystick mounted in the head with mouth/chin control.
http://www.facebook.com/photo.php?pid=5355459&l=3d1b1a886a&id=642109656
It didn't win any prizes, but it was popular at the Swancon Masquerade.
About a week later it almost got destroyed when a car crashed into our house.
My latest project was an flexing tongue for another costume using an Arduino, cheaper, smaller and less power hungry.
Thanks for a great Instructable.
Oct 16, 2009. 9:45 PMvfitch says:
how much should the total price be around.
Nov 2, 2009. 3:23 PMmskogly says:
I read that the i-cybie robot dog was supposed to have 16 servos on board, so I was a little disappointed when I opened it up and found this cheapo elektrical motors you find in every other toy. I got one that had short circuited, and wanted to try to bring it back to life with an arduino as a servo controller, but i ended up just connecting it up to a toy keyboard to be able to trigger some kind of movement. Can be checked out here http://pappmaskin.no/2009/11/frankendog-diy-animatronics/
Sep 14, 2009. 10:17 PMmetal slug 2 says:
Sorry, I just have another question. You mentioned that as the wires to the flex sensors get longer, there is an increase in noise and therefore a decrease in the accuracy of the sensors. How long were the wires which ran from your hand to the MAKE controller? and approximately how long would you suggest I allow the wires to be?
Thanks =)
Aug 30, 2009. 8:30 AMweevil says:
I'd love an arduino animatronics tutorial. I've used an arduino to make a servo move before, but the subtleties of building something like say, an eye mech, are a mystery to me. I'd love to be able to cheaply throw together some potentiometer or wiimote controlled eyes (left right, up down, maybe even blink) with an arduino, a few servos, and some chunks of shapelock.
Sep 4, 2009. 7:19 AMweevil says:
Wow! I'll check out those books...
Sep 2, 2009. 12:34 AMmetal slug 2 says:
Very nice! I am currently working on an animatronic mechanical hand, each finger being controlled by its corresponding finger on my hand. I am using the same sensors that you used (SpectraSymbols 4.5" flex sensors are the only ones out there I could find anyways, I got mine from Sparkfun.com), and will be utilizing them through a glove setup, as you have done. @Weevil, I will be using the Roboduino, which is a robot-oriented version of the Arduino. I might (if time allows) document my results and create an instructable on it. @Honus, is there any optimal value for the resistor used for the flex sensor? My friend suggested I use 14k.
Sep 3, 2009. 8:32 PMmetal slug 2 says:
Ok, thanks.
Jun 5, 2009. 2:05 PMMaltiK says:
I thought ur never supposed to directly wire resistors to motors?
1-40 of 65next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
581
Author:Honus(Multi-Bot)
I'm a former bicycle industry designer turned professional jeweler. I like working with my hands and am happiest when I'm in the shop building my creations. If you need help with your project just let...
more »
