And before I get started, I want to make a DISCLAIMER: I am not an electrician and will not assume responsibility for any damage that occurs as a result of you attempting this project. If at any point you feel uncomfortable, hire an electrician! We have had this chandler installed in our house for about two years without any problems.
There are a lot a steps involved but I will do my best to explain things in terms anyone can understand. So, here goes. . .
Remove these ads by
Signing UpStep 1
- Canning Jars with lids (6 large, 9 widemouth, 6 small)
-Wire (18-2 Lamp Cord)
-#10 Washers
- Hex Nuts (that will fit your nipple (which is the threaded metal rod))
- Steel Nipples
- Small Hose Clamp
- 4 Keyless Sockets
- 4" offset crossbar
- 4" PVC cap (found in plumbing section. We used this as the ceiling plate because it provides a lot of room to accommodate all the wires that are coming from the fixture.
-3" machine screws (to attach the ceiling plate to the crossbar)
-2 Acorn nuts
-2 wire nuts
1. The jar glass was dangerous to touch
2. The insulation of the wire coming out of the jar was hot and very soft, which is how it feels before the insulation melts, which would be dangerous.
3. It is beautiful!
You make these things, so maybe you are doing something else to dissapate the heat. Any ideas? I'd like to make a chandelier with these jars, but frankly I don't consider it safe (As an electrical engineer, I worry more than others).
Besides the four holes in the lids I haven't made any other considerations for heat dissipation. We have had ours up for two years now without any problems.
Let me leave it on for a while and check jar temperatures and the insulation. I will get back with you with what I find out.
I agree on the painting the cardboard socket covers. It would help a lot!
I appreciate the suggestions. It is great to hear different perspectives on projects.
Does the light diffuse well through the jars? I find that lights with just a clear glass casing cast too harsh of light for me. I would be tempted to frost the inside of the jars with a glass etching solution so the light is softer.
One thing though. You wrote in your disclaimer:
"I am not an electrician and will assume responsibility for any damage that occurs as a result of you attempting this project. "
You may not want to assume responsibility. Could get you in big trouble.
Great project. I think i'm going to give it a try.
