Remove these ads by
Signing UpStep 1Gather your tools and supplies
1: transparent or translucent vinyl tubing (I used 1/4 inch ID, about the minimum size I could work with)
2: several 3mm 4Volt ultra bright LED (Larger size LED will need a larger diameter tubing)
3: electrician's fish tape or long stiff wire (needed during assembly)
4: fine gauge speaker wire ( I used 26AWG wire)
5: Ultra sharp push pin (an awl or needle will also work)
6: firm stable work surface
7: small ruler
8: sharpie pen
9: hot glue gun
10: inexpensive flashlight
11: small flush cut side cutters
The power delivery seems to wreck most designs. We definitely need an effective high power, low volume supply on this plane of existence. Mini nukes would be great!!!!!
http://beadstore.wigjig.com/index.html?stocknumber=2911
