3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
How to make a RPG-7 prop.
Today I will show you how to make an RPG-7 prop for your own film, costume, some crude prank or just to make on a rainy day. I chose the RPG due to it's distinctive look and because it's very common in today's world and it's just plain cool. Now neighbor-scaring freaks or  movie directors can make a cheaper version without shelling out thousands.(of course it won't look as real) The total cost of the project ranges from $20-$40 depending on the materials you have. History and technical information here >> http://en.wikipedia.org/wiki/RPG-7   (yes i used wikipedia as a source of information)
I tried to make it to scale. I'm not sure of the exact dimensions, I just estimated.
Ok this is my first instructable, so bear with me folks. At times it may seem a bit confusing, so i'll try my best to clarify things.
And let me just say this now. IT DOES NOT SHOOT. However it could be easily modified to do so.
(Disclaimer: I am not responsible for anybody getting arrested or fined for anybody who uses this improperly or anything of that sort.)
Step 1Materials you will need.
You will need quite a few items, lucky these are common and can usually be found around the household. If not, your local hardware or craft store should have them. If you connot find the exact object you could easily substitute it.
Two 1.5" diameter, 2' long PVC pipes, or one 3' tube.
1.5" PVC coupler
1" diameter PVC tube
Pipe insulation clamps
2 empty contact lense cleaner bottles
Cardboard
Cheap Dollar Store gun
2 wooden paint mixing sticks
electrical tape
PVC cement
Hot glue gun plus glue
2 large styrofoam cones
A bottle cap
Contact paper with wood design
Assorted spray paints and acrylic paint
A plastic cup
Mod Podge
30 comments
May 22, 2012. 7:53 PMGriffinM says:
Very nice this will be used in my action films
Oct 6, 2011. 12:56 PMmyakka says:
just get two funels from autoway and glue together
Sep 17, 2011. 4:23 PMjgilbert4 says:
HELL YEA i make it work :D i used a model rocket engine stuffed in the back of the rpg missle and modefied it alittle so i could attach aligator clips tto the igniter and just put a button under the trigger so when u pulled it it wud press the button which would turn the power on making the ignighter light the rocket and it wud shoot out with an AMAZING wuuHUUAAASHHHH noise and it makes a smoke trail like a real rpg but one problem is its not safe to fire anywhere but up cuz i fired it at a wall and it hit it turned around and came back in my direction and also u gotta remember it comes back down lol it landed in my neighbors pool when i shot it up and they thought it was a real rpg and hid in their basement cuz they thought it was active and wud expload if they touched it. :P i explained it to them tho..... eventualy muahah jk i told them right away and told them it was for a holoween party.
Aug 8, 2011. 3:28 PMThat One Eegit says:
where do you get wood patterned contact paper?
Jul 20, 2011. 6:27 PMGuardianDuo says:
Elmer's glue with water seemed a bit too... watery, so I ended up using just pure elmer's glue for my first cone. Took about 4 or 5 oz of the stuff, but it didn't turn out that bad.
Jul 8, 2011. 8:14 AMewilliams10 says:
Wait, is this the 2 inch PVC or what size is this?
Jul 9, 2011. 7:13 AMGuardianDuo says:
2' = 2 feet.
You need 1.5" (inch) and 1" PVC.
I'm just confused on the styrofoam cone size. THEY'RE SO EXPENSIVE
Jul 6, 2011. 2:05 PMCptme says:
real nice but i think you could use a different cup on the end like one that flares out like the real thing
Oct 26, 2010. 7:24 PMMatrix-technician says:
Yoyu should make an "ible" incorporating an estes launching controlor into this so you can shoot off the rpg with a solid fuel rocket motor in the back. 5 stars. YAY FIRE!!!WOOT!!
Jun 4, 2011. 1:04 PMtdesmarais says:
Yeah, a friend and I are making a movie, and we plan on using this design for the launcher, but we need it to launch using rocket engines. What I plan on doing is lining the inside of the body's PVC pipe with a metal tube, and th rocket's PVC pipe will hold the engine. We would feed a D cell battery into the pistol grip, with the wires hooked up to the engine on the inside. When the trigger is pulled, a button would be pushed, igniting the rocket engine, and sending out the rocket! The only thing is I need something better for the cone on the end, because a styrofoam cup would melt.
Mar 24, 2011. 6:37 AMM4industries says:
Check it out. I modified your plans slightly to make mine actual size and to fit my available resources.
Mar 20, 2011. 12:27 PMM4industries says:
Department of Defense specifies that the RPG without missile is 37.40" long.
Jan 23, 2011. 6:18 AMminimike229 says:
That thing is so sick I found out a way to launch it with rubber bands but its not that good good first post
Oct 8, 2010. 11:45 AMyourworstnightmare says:
what do you do with the paint sticks
Nov 22, 2010. 1:53 PMLandon Sullivan says:
Those are what the trigger guard was made out of.
Nov 9, 2010. 2:09 PMbuffalobillshater411 says:
i will actually make it with an actual estes rocket engine. i will post pics of the completed rpg.
Sep 26, 2010. 9:17 PMNerfTech says:
Great first post. Well explained with good pictures. I look forward to more.
Sep 2, 2010. 8:33 PMradimaida says:
i like it a lot but shouldnt the handle wood be the same as the wood in the back??
Jul 18, 2010. 10:53 AMseabananers says:
this is so cool i hope the cops dont make me make one cone bright orange LOL good job
Jul 9, 2010. 1:02 PMTimmyMiller says:
you should totally put an a instructable on hw to make a scope for an rpg.
Jun 5, 2010. 5:16 AMgoggerbogger says:
lol, viola en voila is something different :p i'm working on this too for an upcoming video :D thanks for the instructable!
Jun 5, 2010. 11:06 AMgoggerbogger says:
lolz, thanks anyway for the beautiful prop :p
May 30, 2010. 5:40 PMEl Chucko Norris says:
 Possibly the best "make a prop weapon" idea ever.
Beautiful job man
May 16, 2010. 9:51 AMfire_drakon117 says:
\m/ good job
Apr 9, 2010. 4:12 AMdinnertime8 says:
 =^@                        wow............
Mar 22, 2010. 1:17 PMCaseyCase says:
 Inspirational. I'd like to make a panzerfaust instead.
Mar 22, 2010. 12:49 PMlemonie says:
You finished thing looks great, very much like the real thing.
L
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
9
Author:dom13marco
