Robo-BellHop can be your own personal assistant to carry your bags, groceries, laundry, etc., so you don't have to. The basic Create has a bin attached to the top and uses two on-board IR detectors to follow its owner's IR transmitter. With very basic C software code, the user can secure heavy groceries, a large load of laundry, or your overnight bag onto Robo-BellHop and have the robot follow you down the street, through the mall, down the hall or through the airport -- wherever the user needs to go.
Basic Operation
1) Hit the Reset button to turn on command module and check sensors are engaging
1a) the Play LED should go on when it sees the IR transmitter to follow you
1b) the Advance LED should go on when the robot is at very close range
2) Hit black soft button to run Robo-BellHop routine
3) Attach IR transmitter to ankle and make sure it's turned on. Then load up the basket and go!
4) The logic of Robo-BellHop is as follows:
4a) As you walk around, if the IR signal is being detected, the robot will drive at max speed
4b) If the IR signal goes out of range (by being too far or too sharp an angle), the robot will traverse a short distance at slow speed in case the signal is picked up again
4c) If the IR signal is not being detected, the robot will turn left and right in an attempt to find the signal again
4d) If the IR signal is being detected but the robot hits an obstacle, the robot will attempt to drive around the obstacle
4e) If the robot gets very close to the IR signal, the robot will stop to avoid hitting the owner's ankles
Hardware
1 iRobot virtual wall unit - $30
1 IR detector from RadioShack - $3
1 DB-9 male connector from Radio Shack - $4
4 6-32 screws from Home Depot - $2.50
2 3V batteries, I used D
1 laundry basket from Target - $5
1 extra wheel to onto the back of the Create robot
Electrical tape, wire and solder
Remove these ads by
Signing UpStep 1Covering the IR sensor
Wire up the 2nd IR detector to the DB-9 connector and insert into Cargo Bay ePort pin 3 (signal) and pin 5 (ground). Attach the 2nd IR detector to the top of the existing IR sensor on Create and cover it with a couple of layers of tissue paper until the 2nd IR detector doesn't see the emitter at a distance that you want the Create robot to stop to keep from hitting you. You can test this after you've hit the Reset button and watch the Advance LED to go on when you're at the stop distance.
The first few lines:
Should be
You can steal" someone else Create with the IR Transmitter.
I would suggest adding an identifier for each IR Transmitter.
http://www.roombareview.com/chat/viewtopic.php?t=1178
