My girlfriend has a lot of books. A lot of hardback books. A mountain of books. Our apartment has exactly zero shelves. But there is sixteen feet of clear wall space that a bookcase can go up against and none of the shop bought laminate versions appealed. So these are my plans to make an appropriate bookshelf. The entire project cost $220 for all the materials.
Remove these ads by
Signing UpStep 1: Tools and materials
Tools:
Safety glasses
Circular saw / table saw / jigsaw / cross-cut hand saw
Power drill
Hand sander
Work bench
Wood drill bit
Angle drill guide
3/8” dowel centres
Clamps
Measuring square
Measuring tape
Materials:
5x - 8’ lengths of 1 x 10 softwood
14x - 6’ lengths of 1 x 10 softwood
132x - 3/8” x 2” hardwood dowels
24x - 2½” x ½” corner braces
4x - 2” corner brackets
4x - 4” straight braces
Wood stain and protection of choice
Wood glue
Wood screws
Another option instead of solid Spruce/Pine/Fir is to use a good quality ¾” thick plywood. An 4’x8’ board ripped into 1’x8’ boards by the store could be slightly cheaper in price if you don’t mind seeing the plywood edge.
Visit Our Store »
Go Pro Today »
Here are a few suggestions. Instead of relying on a couple of metal angle braces to prevent racking, strategically place some vertical boards perpendicular to the supporr boards, and anchor from the back with three screws per intersecting shelf. These "flat" boards could then be anchored to the studs, without the use of metal brackets.
However, in lieu of anchoring to a wall, especially in a rental situation, use the short tee section to brace the longer section. This would requre some "flat" boards, as well, and some stronger connections between the two sections.
Design loads for shelves of books usually run at about 50 lbs per lineal foot, and most of your supports seem adequate. Typical spans, depending on wood species, usually max out at about 4 feet with such loads.
Finally, when I used to have those monstrous stereo speakers with flat bottoms, I would place adjustable screws in the bottom panel to minimize contact with flooring materials, such as carpet. While this was done for acoustic reasons, it also made the speaker more stable, as the tilps of the screws were supported directly by the subflooring, instead of the carpet. And it didn't damage the carpet.
Your design of the spaces on the shelves is quite appealing, and adds a great deal of interest to what would otherwise be a boring rectangular shape.
I'm sorry, I don't quite understand how the vertical boards are anchored to the studs from behind? Do you mean to make the vertical boards as brackets themselves for the shelf support? The T-section does help support the shelves, but you're right that the joints are not strong enough to support it entirely. Very interesting values for bookshelf loading though!
I will agree that having just the flat boards on the bottom is not ideal. I now want to raise the bottom with 4" feet and then a footer board around the bottom to cover the gap. 20:20 hindsight! Thanks for the comments.
I think what chuckyd was saying is that you could put a piece inside of "apparently" random shelves, perpendicular to the rest of the structure to add strength. For example, if you cut a piece that was the exact dimensions of one of your opens, you could "blank" that shelf. You'd still have the use of 90% of your shelf space, but wouldn't be able to see the wall behind that section. Those back pieces could then be anchored to your wall, in place of the brackets. As for the T section, maybe a divider could be put in place, spanning the split, that could bear the load. It would also turn the T section into a buttress, preventing the whole set of shelves from tipping. Hope that helps.
Again way to go. Having seen your design I think I'll start drawing up plans of my own. Thanks!
But I can only encourage that you give it a go! A small scale staggered shelf would make a great feature piece.
i did a project like this, but it was not as long. my biggest mistake was using plywood, and it's glued and screwed.
Whats wrong with that?
well, i had to get it upstairs to where it will sit, and it's wicked heavy. all one piece, more than two sheets of 3/4 ply. it took 3 guys.
plus, i can never take it apart!
nice job!
However, as a professional translator with over 20 years experience I am appalled by the French translation on the Madison Mill "dowel pin" container.
The translation provided makes absolutely zero sense in French. An approximate translation into English would be "Fluted Fingers". What the heck is that ???
The time tested AND correct word for a dowel in French is "cheville".
It is very common for companies to completely disregard proper translation on products and ask anyone with access to Google translate to come up with something, no matter how wrong it is. That is just a personal peeve when it comes to translation... don't let it stand in your way of enjoying this "instructable".
Cheers !!
If only I had the space to accommodate such a beauty .....
but seriously .. outstanding job on the shelves. I like how the chamfer outlines the edge of the shelf. Very clever.
Thanks for the kind words though!
I did notice a rather humorous typo under the "Security" section:
"it needs to be anchored to the wall to prevent falling over and trapping any small plants or children."
Small plants?
