How to Make a Proper Western Union Solder Joint
129,244
465
90
Published
Introduction: How to Make a Proper Western Union Solder Joint
About: I have always been tech support for just about everyone. I am an Autodidact. There is nothing I can't teach myself. I was a Auto Tech for more than 20 years. I was ASE Master certified. I was in the top 10 d...
This is one of the harder solder joints to make. When I was in school this was my favorite solder joint. This joint is almost 100 years old and it's history goes back to the days of the telegraph. This was a common joint that linemen would use and when used with solid wire it does not require solder to keep it together if done right.
From Wikipedia -
"The Western Union or Lineman splice was developed during the introduction of the telegraph to mechanically and electrically connect wires that were subject to loading stress. The wrapping pattern is designed to cause the termination to tighten as the conductors pull against each other. This type of splice is more suited to solid, rather than stranded conductors, and is fairly difficult to complete.
The Western Union Splice is made by twisting two ends of a wire together counterclockwise 3/4 of a turn each, finger tight. Then, using needle-nose pliers, the ends are twisted at least five more turns, tightly. The cut off ends are pushed close to the center wire. "Short tie" and "long tie" variations exist, mainly for purposes of coating the connection with solder. The longer version may aid in solder flow. NASA tests on 22 and 16 AWG wire showed that the Western Union Splice is very strong and is stronger than the wire alone if done properly."
You will need:
Solder and soldering iron
The wires you want to join
and a 3rd hand set up like I have to hold the wires wile I work. Note this is only needed when working with stranded wire.
Shrink tube of the right size. Please do not use electrical tape as it just makes a mess and doesn't work worth a hoot when it gets hot or old. Besides it makes a nasty sticky mess. You can use the liquid "electrical tape" but that too looks terrible
And lastly a banana. I don't know why you need one but you do need a banana.
Step 1: Prepping Your Wire
Because we are using stranded wire this joint becomes much harder to do. First we strip back about 1" on each wire we want to join. Then we twist the wire strands together to make a more solid wire. When wires are twisted in a tight bundle you can better manipulate it and it accepts solder much better.
SAFETY: Wear safety glasses when doing this. Hot solder can do extreme damage to your eyes should you get even a dot in your eye. I know I had it happen and I was blind for a whole summer; never again.
Before we solder there is a point that must be made. Solder when used with heat has a capillary action meaning that it will gravitate to the heat source. When the wire is properly heated and solder is introduced the solder should almost "soak" into the joint. When joining wires I always put the iron on the bottom and the solder on the top. This speeds the completion of the joint which makes sure I do not overheat the wires insulation, compromising the joint.
Step 2: Twisting the Wires
Now we will start the joint. FIRST make sure you put your shrink tube on one of the wires and slide it down the wire so the soldering iron does not start it shrinking. I can not count the number of times I have made a beautiful joint only to find that I forgot the shrink tube and now have to cut out the joint. Now at the half inch mark twist the right wire up and twist it around the wire on the opposite side of the joint. Then do the same for the other wire. With solid wire we would pull the wires to make them tight and then pinch down the last 1/8" of the wire with a pliers. We can not do this with stranded wire as the joint would fail before we soldered.
Step 3: Soldering the Joint
Are you wearing your safety glasses?
First make sure your iron is hot enough to do the job. With it turned on try putting solder on the iron first. If it accepts solder take it right over to the joint and heat the joint and then introduce the solder the instant the solder you put on the iron starts moving. The primer solder as I call it helps heat the joint faster. If it is not hot enough "Have you tried turning it off and on again?"
The solder should appear shiny when done. If it is dull or has a brown residue on it the joint did not achieve proper temperature and is called a cold joint. Cold joints are what makes most cheap electronics from China fail fast or not work at all. If your solder joint looks like I described it go back and heat it up again. Basically when it stops smoking you have the right temperature as it has burned off all the flux. Do not heat it so much that the insulation starts to melt.
When done your joint should look like the last picture here.
Step 4: Tidy Up and Insulate
Here we center the shrink tube over the joint. At this point if there is any sharp points from the solder joint you must correct them or they will render the shrink tube insulation useless. This correction can be done by gently smashing them down with a pliers. Once you have the shrink tube in the right placement apply heat to the tube and it will begin to shrink. Be a bit stingy with the heat as you can burn the tube and then it just looks nasty or doesn't work at all. We want a professional looking joint don't we? As the tube shrinks keep moving the heat until it appears that the tube has finished shrinking. In the photo here I used open flame. This is ok because there are no flammable vapors near me. Should you have to do this is a flammable vapor situation you will need to ventilate the vapors or remove them. Heat guns and hair dryers suck in air and super heat it so they too will ignite fums. Even the switch on them makes spark when starting them.
Do not use this joint in a situation in which it is continually subjected to water or liquid as it will fail. I would call this joint water resistant rather than water proof. This is a great joint for things like car radios should you have to make a harness because one is not available (see Audi Quattro). These joints also have almost no bulk when done right.
Should you have to use multiple joints in the same area stagger the joints so that the don't line up with each other and create bulk in the harness. Generally 1" offset from each joint is best especially if you want to put it in a harness sheath.
Oh I forgot.......Eat your banana.
2 People Made This Project!
  • Clocks Contest
    Clocks Contest
  • Make it Move Contest
  • Casting Contest
    Casting Contest
90 Comments
You know, RayChem (now a Tyco company) makes a really slick shrink-on solder splice that works as well as a WU and provides a better environmental seal.
http://www.amazon.com/Tyco-Shrink-Splice-Soldergri...
All you need is a heat gun to have the splice soldered and apply/seal the heatshrink tube. Either end of the tube has a bit of hot glue/plastic that seals the joint from water/gas. I love these splices and have been using them since the 70s when they appeared in the "official" aircraft wiring repair kits distributed in navy.
I think those are slick. I personally like shrink/crimp tube connectors. I use them in almost everything exclusively because they can be done in the cold in the dead of winter. Good luck doing this joint with a soldering iron at -20 degrees. The connectors you posted get the job done with no fuss. I use the 3M brand ones only because they are more industrial. But they can be bulky.
The solder/shrink splice was _the_ hot toy when I was in the service. The environmental issues associated with protecting the joint and the places where you might be when you have to make that splice are big issues for the military aviation (probably for armour, too).
I spliced together a 120-wire bundle using the raychem splices during a single shift while lying under an F-8 on a flight deck. I am certain it would probably have taken at least two shifts with solder and shrink wrap alone.
Please tell me it was a Crusader. Even when guided missiles became the norm the idea of a 20mm canon was still a cool IMHO. "The Last of the Gunfighters"
Heya Izzy,
It was a sorta Crusader :-) An RF-8G photo recon version. No guns, but the fastest F-8's you'd ever see. They got upgraded befiore the cruise in '75 to the big J57-P420's.
Those birds could scream. Our OIC (Errol Reilly - The maintenance guys called ourselves Reilly's Rowdies and used that on our unofficial squadron/cruise patch [officially it was Reilly's Rookies since all of our pilots were newbies]) used the whole runway to take off from Cubi Point. About 1/4 of the way down hit hit burner, rotate at the very end (the last 150-200 feet), and just go. Straight up. The fighters were just too heavy to do that.
I was with in a detachment from the the west coast photo recon outfit. VFP-63 operated the F-8 FRAMP and all the active duty Navy RF-8Gs on the west coast. My wallpaper happens to be the plane that had the cut up wiring bundle.
If the military taught me anything is that you are the best part dead without proper recon. In my world all the recon was done the hard way (up to your armpits in jungle waters). There wasn't much IR recon done at that time; it was done on foot in the parts of the world I was in. Could have saved us lots of hiking and heartache.
I love these shrink on splicers but at $1 a shot I save them for hard to reach places or inhospitable environments.
I save mine for just such instances as well as when I am feeling a bit lazy ;)
If I only used them when feeling lazy my solder iron would start getting dusty ;)
Solder splices are great. I was a cable assembler for a while and we used these fairly frequently. I have a butane soldering iron with a torch tip that works with solder splices when I don't have electricity to use a heat gun.
Thank you for the great 'ible. This was the first solder joint I learned when I started in ham radio at age 14. My Dad taught it to me and he learned it from my grandfather who was a railroad station agent and telegrapher.
Great to hear from someone who has grown up with this. Someone who has had this passed down through the years. I did this post mainly as a history lesson.
I presently use a dual range iron. Mine is 30/65 watt if I remember right. Naturally the heavy the gauge wire the more heat you will need.
make sure it's not a banana split!!(badumcrash)
get it? if you solder up the wires correctly it won't split!?
btw: molten solder to the eye?! *cringes* how did you get it out?!
Blink fast and scream. It will just fall out, but not before it makes you wish for death.
...*feels for eye*but how could it jump up like that?!
Actually the rosin is more likely to spit and sputter into your eye, and is more dangerous in my opinion.
