Step 2Build the Minty Boost kit
Instead of connecting the battery holder in the kit, we're going to solder a JST connector to the MintyBoost PCB. This tiny connector will then allow the MintyBoost circuit to connect to the Lithium Polymer battery charger circuit. Make sure you get the polarity correct!
Test the MintyBoost by connecting the battery pack (make sure the battery pack has a charge) and charger circuit. The MintyBoost connects to the connector marked SYS on the charger board and the lithium polymer battery connects to the connector marked GND.
Now cut a notch in the Altoids tin for the USB port and use some double sided adhesive to mount the PCB to the Altoids tin.
| « Previous Step | View All Steps | Next Step » |
http://www.sparkfun.com/commerce/product_info.php?products_id=8599
Mintyboost is kind of a diy thing, radio shack will defiantly not carry it.
As for the battery Radioshack i think only sells replacement batteries for cameras, phone etc.
There's a schematic for the charging circuit here: http://www.sparkfun.com/commerce/product_info.php?products_id=726
Here's the manufacturer's page on the MAX1555 IC used in the charging circuit:
http://www.maxim-ic.com/quick_view2.cfm/qv_pk/4002/t/al
http://ladyada.net/make/mintyboost/make.html
One of the best books I bought last year was Physical Computing by Tom Igoe. For anyone wanting to use microcontrollers to actuate motors and servos and learn basics about transistors and things like that it's awesome.
All this is assuming you still are using the MIntyBost PCB. Just looking at it I think it would be hard to make a PCB boost circuit smaller than that. Maybe using surface mount components you could do it but it would be a fair bit of work. You would save more room by altering the charging circuit as it has a much larger footprint- if you combined the boost circuit and charging circuit on one PCB with a minimum of connectors that would really shrink it down.
