The diaper in this Instructable is a fitted pocket diaper with hook and loop fasteners. I like pocket diapers because you can remove the absorbent liner for laundering so it gets cleaner and dries more quickly.
Of course prices will vary, but these diapers cost us about $2 or $3 USD to make. It sure beats paying $15+ per diaper! Also with these diapers you will need a waterproof outer layer, either PUL or wool.
Remove these ads by
Signing UpStep 1Materials List
1 yard of flannel (any kind, color, or style) OR 1/2 yard of flannel and 1/4 yard fleece or 1/4 yard of waterproof PUL (if you use waterproof fleece or PUL you won't have to use a cover over the diaper.)
16" of 3/8" elastic
4 3/4" Loop side of hook and loop fastener
2 pieces of hook side 2" X 1 1/2"
Ruler or Yardstick
Tailors chalk or fabric marking utensil
Scissors
1 Prefold diaper (for pocket insert)
Diaper template
Sewing Machine
NOTE: There are many ways to make your diaper template. You can trace a disposable and add 3/4" to all sides. There are also many websites dedicated to helping you draft you own pattern. For our pattern, we used a store bought sewing pattern for a diaper cover and modified it a bit.
First I recently added that you DO NEED a waterproof outer layer. You can make it with the outer layer as waterproof fleece or PUL and you won't need any more layers.
If you're just making a fitted diaper, you will need a waterproof cover either PUL or wool. I would change a few things about this pattern because it was so bulky. I am going to be updating soon.
You don't need so many layers of flannel. You just need one inside and one outside. You could use absorbent fleece on the inside and it will take the feeling of wetness away from baby's bum. I wouldn't use a prefold as an insert, I would either make some microfiber fleece, terry or other absorbent inserts. The prefold made it way too bulky. Although for nighttime you could add an infant sized prefold for maximum absorbency.
Again, I'll me making an updated version of this soon.
Great, straightforward instructable, though!
