Humid Climate Solar Dehydrator
This dehydrator is my version of an upper Mid-west design. I adapted it (as recommended) to fit the windows I had on hand, which I also use for my cold-frames. These windows were roughly 32" by 32", which matched nicely with 32" wide galvanized roofing. I couldn't get the wavy kind in my area, only the ribbed, so had to adapt the screen support system accordingly. I used cedar throughout for to withstand weather without coating it with any preservatives or paint. It also makes the frames really light so I can put them on a 4 1/2 foot high shed roof.
Materials (for two dehydrators):
3 1x6 3/4" 6-foot cedar boards (these are fencing boards in my area - I picked for few knots)
1 sheet of 8-foot galvanized ribbed roofing (is enough for 3 dehydrators)
2 yards of 36" aluminum flashing
2 32" x 32" storm windows (or other similar sized glass)
Matte black spray paint
2 yards of 36" aluminum screen
Staples
Galvanized nails (1 1/2")
1" finishing nails for drying screens
Tools:
Jigsaw with metal-cutting blade
Tin snips
Table saw with rip fence to produce frame elements
Stapler
Step 1A Simpler List of Materials
Two years after initially publishing this Instructable, I found myself conducting a Saturday build of three smaller dehydrators with three friends of mine.  I found 3 windows of the same size at the local Habitat ReStore and worked everything from there.  I also wanted to get the three of them done in less than a day, so I went with materials that simplified things.
For each dehydrator:
1   24"  x 27 3/4"  storm door window
Dehydrator bottom: Aluminum flashing,  white on one side, shiny on the other:  24" x 27 3/4"  (no need to trim ribs)
Heat sink: Aluminum flashing,  black on one side, white on the other:  22" x 26"  (no need to paint)
Nylon screening:  24" x  30"  (easier to work with than aluminum screening)
3  1" x 6" x 6' cedar boards:  one ripped 3 1/2" wide (for top and bottom),  one ripped 4" wide (for the sides),  one ripped into 1" wide pieces (for tray frames).  Once the pieces are cut for the box, rip the remainders into 1" wide pieces.
scrap 2" x 2"  (about 4" - 6" long) for heat sink handle
1 1/4"  galvanized spiral nails  (for making the dehydrator trays)
1/4" staples
8  1 1/2"  deck screws  (to hold the outside box together)
For this size,  the top and bottom were the 27 3/4" sides of the window.
Because the flashing doesn't have ribs,  you'll have add "risers" to the long sides of the trays using scraps of the 1" wide pieces.  The flashing is much easier to cut than galvanized roofing!   We cut the screening oversize for the trays and found the nylon easier to stretch tight than aluminum screening;  it was also easier to trim once the top pieces were nailed on.
We completed three dehydrators in 4 hours.
10 comments
Jan 30, 2011. 2:13 AMfaun108 says:
Thank you for this inspiring instructable!
I asked myself however if you checked the temperature? I want to build a solar dryer for herbs and most plants should not be dried over 40 degrees celsius. Any expericence or ideas?
Jan 31, 2011. 2:42 PMfaun108 says:
Thanks for your reply! It´s very much appreciated! I will experiment with it and maybe put a thermometer inside, to get a better idea of the development of temperature.
Best wishes!
Nov 25, 2010. 6:15 AMjonnyarmony says:
Hey I was wondering if this model of a dehydrator can be stacked on top of each other. This would be useful, as to not take up so much room.
Also, I didn't see you mention many vegetables that you dehydrate. I imagine that this will work for most, but will it work for carrots, celery, peas?
Aug 27, 2009. 8:40 AMguy90 says:
Very informative and useful, thank you for the upload
May 24, 2009. 8:31 AMshilohjim says:
Is the aluminum screen food safe? I worry about acidic foods reacting with it.
May 26, 2009. 3:31 AMimrobot says:
will this work for meats?
May 22, 2009. 9:07 AMrimar2000 says:
Very useful work.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:amtrudell
