Ikea Lack Plus (light)
143,348
368
18
Posted
Introduction: Ikea Lack Plus (light)
Everyone knows that table because it's the Ikea's philosophy essence for an extremly low price. Built from nothing more than 4 screws, air and wood fibers can withstand a lot considering how flimsy this material is.
Here's how it's made:
http://www.wired.com/gadgetlab/2009/11/video-inside-an-ikea-factory/
What is the most striking flaw though, is the surface that wears out quickly. You can put a sheet of glass over it to add some glamour or you can go even further and add a light source beneath, and have a cool clubbing accessory!
I've been thinking of making an evenly backlit surface, but it turned out to be not possible using that low budget.
Sticking white foil sheet blocks too much light, transfer paper lets too much, 2 cathodes can't evenly light the surface.
Thinking about the problem drove me to a simple solution such as - christmas lights!
So, what you will need:
A lack table
Sheet of custom cut frosted glass
LED Christmas lights
Two rolls of double sided foam tape
reasonably long electrical cable
miscellaneous plugs, switches, tools
Step 1: Cut It, Cut!
You ca cut the table with a paper knife with no much trouble.
Mark a stripe around the edge as wide as the foam tape (20mm).
In the corners there are cubes that hold the screws. I didn't know that so I scraped the surface from them, you may want to leave untouched finish over them, they are around 5,5cm in size.
Take out the honeycomb.
Step 2: Accesorize
Insert what you think is right.
Using an IBM connector allows you to unplug the cable when not needed.
Step 3: White Inside Out
Paint the inside, glue a sheet of paper to the bottom.
Step 4: Connect
Solder the wires and test connections.
I've changed my mind and moved the power socket to the leg. More convinient.
Glue the leg, wires doesn't strech!
Feed the cables through through back of the leg.
Step 5: Sticky Stuff
Prevent lights from moving using scotch.
Stick the foam tape over the glass. Watch out for air bubbles.
Foam tape is incredible, it holds so firmly!
You have only one chance to align the glass, my is off for a milimeter or two.
Second person may come in handy.
Step 6: Be Proud
Time for the final blink-blink!
Flip the switch and reward yourself with something that looks great with light shining from below.
  • Metal Contest 2017
    Metal Contest 2017
  • Wheels Contest 2017
    Wheels Contest 2017
  • Remote Control Contest 2017
Questions & Answers
18 Comments
Next time use plastic instead of glass? It's your friend's fault for being stupid tho. cheers
In fact, all the glass in the world should be removed, just like hot coffee, slippery water and scissors, so that the peaks of evolution (you and your friend) can be safe and prosperous.
Any glass table top should be made from tempered glass for this reason. (Ever wonder why those commercial glass tables are so expensive?) It's a lot stronger than garden-variety window glass and will shatter into harmless granules if broken. FROSTED (what the industry would call "opaque") glass that's tempered is very expensive, though; as an alternative you could use inexpensive frosted window films on the bottom side of a tempered glass panel.
YES! This is just what I need. Iv'e been planning on building myself a lightbox! This will work better than perfect! Hoorray!
Yeah! While we're at it, we should remove all the recipes off the internet because someone might stick his head in the oven and die.
Very dangerous.
Did you replace the honeycomb structure? without it the table should lose a lot of it's rigidity.
No I threw it away. The glass is held so firmly that it regains some part of its rigidity. You just can't put heavy objects on it, but the glass would crack anyways. So there is no worry about the table being destroyed easily.
