I had a few options to upgrade my lights. I could buy some external driving lights from a company like Hella or KC. They are readily available in all shapes and sizes and are extremely bright. People often add them on their cars as additional fog lights, or even for off-roading. I decided that installing these on my car would be somewhat of a hassle. I would have to mount them, which involves drilling things. Then the new hole begins to rust (especially in the salty winters) and it creates more work. It would also put more load on the battery, and I would possibly have to install another relay.
I chose the second option, which was replace the sealed beam headlights with reflector enclosures. Then a normal halogen or xenon bulb can be clipped into the reflector and plugged right into the car's female plug. It was much less trouble, cheaper, and less things to go wrong in the future.
Remove these ads by
Signing UpStep 1Buy the Goods
- 2 x Headlight Conversion Housings @ $22.68
- APC Xenon Super White Halogen Bulbs (pair) @ $15.99
- Total < $62.00
Good job on the 'able
2) You leave yourself open to lawsuit if you do cause some to have an accident and a witness happens to get your license plate number.
3) If said witness call the police if you think of taking off after you CAUSED an accident you can and DEFINITELY be CHARGE with fleeing the scene of an accident which has some SERIOUS repercussions.
So I hope this gives you the idea to NOT do stuff like that.
Try driving for 10 or 11 hours straight and every third vehicle you meet have their auxiliary lights on! Talk about causing eye strain and fatigue. If most drivers would read their owners manual and check out their state traffic code, they would find out that they should treat their auxiliary lights as though they are high beam head lights. If you meet other vehicles, you should turn them off since they don’t have a dimmer switch for them. Most auxiliary lights are brighter than low beam headlights and they only illuminate about 20 feet in front of the vehicle using them…but they cause an irritating glare. I have been using my high beams for years on drivers that run with their auxiliary lights on all the time. I don’t know why they think they are so cool when they aren’t. wrksnfx and lunchbox9864 both most likely run around with their bumper lights on blinding everybody and when someone throws the brights on them they get their feelings hurt because they can’t be cool if they have to turn them off. All I have to say is if you can’t see the road unless you are running those stupid auxiliary lights all the time…you need to stay home after dark and quit blinding everybody you meet on the highway! As for using my high beams to give you a taste of your own medicine…so be it. You get what you give!
Keep up the good work Yerboogieman and maybe those who think they are the only one's that matter will get the message...I am right there beside you giving it back to them! If they run off the road...it is probably because they were distractracted trying to figure out how to bright light you back and couldn't find the switch since they run around all the time blinding other drivers with those stupid bright bumper lights on!
If the headlights of D.O.T. approved stock vehicles are to bright for you then that means you should either if your headlights are hazy then they need to be recondition or upgrade your older vehicles stock headlights to the newer brighter headlights or both this will offset the brightness of visible light of oncoming traffic w/o blinding them and cause you less eyestrain & headaches.
Before you whine about my vehicle's is too old to do this on it my response is bull, because I own a 1979 Ford Ranchero 500 and I installed brighter lights on it in the STOCK headlight buckets, without any problems and yes it did cost a little more than old stock headlights a worthwhile investment but if you want to argue about it then look at this way.
Cost of newer headlights vs. less eyestrain & headaches = less eyestrain & headaches
Look at me, I have a big lifted truck to make up for other short comings in the bedroom.
As for the colour, guess it will depend on the local laws - some states/countries will let you do it, some won't. I know those washer nozzles with blue LEDs are popular over here in Australia, but I know someone who asked a police officer about them and was told they're a flat NO because they distract other drivers at night (or so they're saying - guess that means truck drivers with vast arrays of LEDs on the side need to take them off, huh?). You'd be best asking your local authorities about them
Bootleggers = No
Pot Growers = Yes
People Dumping Garbage in the forest = Yes
Don't take that negatively, I'm only trying to clarify. :-)
As for the actual 55/60W headlight bulbs, they shine white, even though the glass is tinted blue.
And as for the law in Canada, you are probably right. I wouldn't know, though, because I don't live in Canada.
