Introduction: Increase Your Fuel Mileage 50%,(Pressurized Air Dissolved in Fuel)
Check the Physics if you Don't Believe it.
Step 1: The Regulator.
Connect the Air line in the Direction of the Black arrow Shown on the Regulator, and connect your other Air line from the Fuel Tank to the Regulator, Secure as Necessary,
i Would Suggest using a Little something extra (the Brass looking thing to the Left of the Pressure Dial) it is a airflow Controller, allows less air into and fuel Vapors out of your tank during use, which i find works better.
Step 2: Dreadful Electronics,
Not going to give the Whole Rundown, but Red is Positive and Black is the Negative Pole, run wires through the side of the vehicle where the door opens.
do not connect the Negative Clamp til you have Completed Connecting the Wires, Strip the Ends off the Electrical Wire, tighten to the Positive Terminal, run that end to the front of the car towards the Driver seat, Connect to Push switch and insulate with Ideally electrical tape, other tape works just fine, connect the other line that goes to the 12V adapter (red) clamp, Make sure to put the clamp near some plastic to insulate it from short circuiting, and secure with zipties as necessary,
Flip the Switch during use of the Vehicle, and flip it off when you are done.
Step 3: The Why...
Heres the Link to the Youtube Video that i made doing a Preliminary test.
https://www.youtube.com/watch?v=tXq9r65LUQg
Step 4: Tips on When to Use.
If any of you have Made this or are in the Process,
The best times to Use it,are trips that are 15mins or more for around town(low Volume), so that way you will have time to fill the Volume of the Tank(half Empty tank=half the volume of the tank you have to fill) and make pressure, otherwise the Mileage Gain will be Negligible, as it is not actually fully working yet, highway is Definitely the Best area to use it.(high/full volume from the compressor)
As Well as if you are Keeping the Project attached to your vehicle after using/Testing, and using the Same Air compressor it is not biased, meaning when it isn't in use fuel will evaporate slowly out of it, Haven't found a Appropriate one way pneumatic valve to use, so i would suggest during non-use to turn your regulator all the way towards the -(minus) end to close the valve.
and Just in case you still feel skeptical after testing your vehicle and the computer reads higher mileage and you think it did something to Mess with the Computer calculations, Use a Solid physical Method to test Gas Mileage by filling your vehicle til the Nozzle stops twice,(close regulator First) recording Mileage, then driving with it in use for 20 or so miles(more miles means more accurate reading) then (close Regulator) if you are skeptical about the aeration of the fuel to effect the pressure on the nozzle putting in less gas go ahead and let it aerate for as long as you think is necessary, fill tank til the nozzle stops twice, then divide your mileage into your 1.3 or whatever Gallons to get your MPG's which should be accurate with your computer. for the Solid answer of yes your computer isn't crazy.
Although if you have it your "range" and fuel meter components will be Inaccurate when using Pressurized air.
Green Design Contest
