On a recent trip to IKEA, I saw the "Dioder" LED set for about $25 and I got inspired to make my own LED light box at TechShop. All together, I saved over $100 by making my own and I had a lot of fun making it!
This is a great project for artists, designers, and photographers! It only took a few hours and it's something I will use a lot.
I made this at TechShop!
http://techshop.ws/ts_sanjose.html
Remove these ads by
Signing UpStep 1Materials/Tools/Equipment
Materials:
- "Dioder" LED set from Ikea.
- 24" x 24" Sheet metal (Steel)
- 1/4" translucent acrylic sheet
- Something to make electrical connections (solder, electrical tape, solderless connectors, etc.)
- Powder coat or paint
Equipment:
- FlowJet waterjet cutter (You could also use the various shears in the metal shop at TechShop)
- Sheet metal bending brake
- Spot Welder (or something else for joining sheet metal)
- Laser Cutter (or table saw for cutting acrylic)
- Powder coat gun and oven
Tools:
- AutoDesk Inventor 2012
- PC
- Soldering Iron
translucent white or diffusor white vinyl. Apply vinyl to inside of acrylic.
I would also suggest using .063" aluminum sheeting to build box
enclosure. you could also ask if the have old signs that you can salvage LED
moduels from.
[edited for redundancy]
I'm not familiar with the Costco LEDs, but I imagine they would work just fine. I wasn't looking for anything special in terms of light color.
otherwise good job.
For those who cant get translucent acrylic normal clear acrylic and be frosted with: A frosting spray used for windows, a solvent or fine grade sand paper (wet and dry ideally)
A light sandblasting is also great for frosting acrylic or glass.
IT IS 41X23 CM. JUST I REMOVE THE SATHERED SCREEN AND DONE.
This is definitely something I'm thinking about doing as a project with my son. Thanks!
