Introduction: Japanese / Oriental / Asian Inspired Box V2.0
About: I hope i can show you that you really dont need to be a master craftsman to create and build great projects, and hopefully inspire you to start making yourself. I will try upload a video every Monday but due …
So a few weeks ago i made a small box inspired by Japanese / oriental designs.
And as much as i like it, it made me want to make a better one.
So here it is v.2.0 - All made from scrap wood still (as always) but i love how its turned out , still not perfect but i still love it anyway!
I added the Japanese symbol for hope / courage as a detail.
This will be a present for my mum on her birthday, so fingers crossed she likes it as much as me!
I hope you enjoy!
Please leave a like, share & comment. And subscribe for more like this!
Check out the original - https://www.youtube.com/watch?v=2MrhxA0ePEk
Follow my work on instagram - https://www.instagram.com/ggwoodprojects/
Help me make more projects- https://www.patreon.com/GGWoodwork
OR
One time tip - https://www.paypal.me/GGwoodwork
Thanks
GG
Step 1: Cut & Rip
I started with an offcut of 2x4. I cut it down to a length i thought would be good and ripped it in half.
Step 2: Cut Out
Next i moved onto the part that would actually form the box, i took some scrap wood (meranti im told) and basically cut out the middle on 2 pieces, making sure they where the same length as i wanted the box to be.
Step 3: Clean Up & Glue
Now it was time to clean up the inside, i used some chisels to smooth out the saw marks and get the 2 inside pieces the same size.
Then i glued them together using every clamp i owned.
Step 4: Plane Lid & Bottom
While the middle was drying, i planed the top and bottom flat and square. and added a small angle on the top / lid piece.
Step 5: Flatten & Glue
Once the glue had dried i flattened out the middle and glued on the bottom piece.
After that was dry i planed the sides again so they where flush with each other.
Step 6: Plane & Cut Handle
To make the handle i used a thin strip of the same 2x4 , i cut it down to size leaving it 1" short of the overall box length.
Then i planed it down and cut a 45 degree angle on both ends.
Step 7: Handle Supports
To support the handle and make it stand off the lid i cut some thin strips of meranti to the same thickness as the handle
Step 8: Glue Handle & Lid
Next i moved onto gluing the handle together and attaching it to the lid.
I sanded all the pieces except where i was going to put he glue.
I sanded up to 1,200 on all the piece's then just glued them together using but joints .
Step 9: Hinge & Lid Support
Once everything was glued up it was time to add the finishing touches, i used 3 - 4mm barrel hinges to attach the lid to the box.
Then i cut out some more meranti supports that where the same size as the ones on the lid, i glued these inside the box so it would line up with the handle supports.
I did this because it made it look like the lid was floating, and i love how it just looks like its hovering there.
Step 10: Glue Feet & Burn
Now i wanted the box to be raised slightly so i cut some small square feet and glued them to the bottom of the box.
To add the finishing touch in my eyes i decided to burn the Japanese symbol for hope / courage in the center of the handle.
This was my 1st time wood burning, and as the handle was so thin it ended up being 6mm x 6mm in the center. if i was to do this again i would burn it before i glued the handle on, it was a right pain trying to burn it while it was glue in place!
Step 11: Finish & Job Done
Next it was time to finish, i used some clear wood finish to seal the color and grain, i applied 2 coats of this sanding everything at 1,200 grit in between coats.
Then to get the gloss finish i was after i used spray lacquer. i put 4 coats of lacquer on again sanding at 1,200 grit in between coats. Then that was that - Job Done!
It was a lot of sanding but in the end it was worth it.
I think it looks amazing, still had slight defects but i dont mind, just shows it was hand made by me.
And as its a present for my mum i dont think she will mind!
Hope you all like it and found it a good build
Watch the full build - https://www.youtube.com/channel/UCRMjvilGRdZxHqr34QKzB_Q
OR
Thanks
GG
