You may be able to use a capo to raise the pitch a few semitones (but you can't lower the pitch), or you can count up or down as you play each chord (which is OK for one or two intervals). Otherwise, it can get complicated remembering different keys or all the sharps and flats.
Here is a quick, easy and cheap transposer to easily change the key of any song. You just decide which key you want to change from and to, then set the wheel so that the two keys line up- and you can instantly see every chord you need to change to. Full instructions for how to use it are in Step 7 (and also on the free PDF download with the wheel design from my website - see below).
Remove these ads by
Signing UpStep 1: What You Need
- A4 cardboard (best) or thick paper. I got coloured card from a $2 shop, or you can get it in a craft or stationery store. If you're using thick paper, it's best to laminate it.
- paper fastener - the split type that you push through and open put. If you can't get one, you could try using a twist-tie.
- laminating pouch if you have access to a laminator; you could use contact plastic. If you have reasonably thick card, you don't need to laminate or cover it - you can easily make a new wheel when it gets tatty.
You can download a free PDF design from my website, www.cathyschords.com
Visit Our Store »
Go Pro Today »
For those interested, the chords for 'C' are;
C, Dm, Em, F, G, Am, B°, and back to C. Every key has each note in it, whether sharp or flat, so you will always have "A, B, C, D, E, F, and G in some form or other.
Another very handy tool is the circle of fifths. You can look that up and find a bunch of them. I prefer the plainer ones, with minors in the middle. The circle goes along with standard notation, so the more keys to the right the more sharps you have, and the farther to the left the more flats. This way if you don't know standard notation you can still figure out what key you're in. It has plenty of other uses as well.
I have an old list of chords that I still use, arranged in keys so that it's easy to see the main chords and secondary chords in each key - but it's probably out of print but still copyright :(
http://www.microtools.de/gcplus/
It's Java, so it will work on just about anything. I've probably learned more from that little program than anything other guitar resource I've seen.
Here's the link: http://www.microtools.de/gcplus/
Thanks, Tragicsnowfall!
What am I remebering? I actually had grade two Royal Conservatory theory, but I am truly gapping. I do in reality deal with post traumatic stress, and there are holes in my memory-which is really frustrating. I picked up my guitar and can only remember two chords. I know that I am not comfortable using the tab system- I learned with diagrams of the strings and dots on frets. If I have too many questions, hit delete and we can pretend that I was never here ;0)
You've made my day by helping me. Hope you have an excellent day.
I remember going to a seminar once where they explained the history of music notation...was interesting at the time, but I don't remember why our Western musical scales are designed with odd intervals like that!
Well, if you're ever in Melbourne....
My method for guitar is: pick a couple of easy chords (D and E7 are good), practise them with a slow song (e.g. Rock My Soul), bash away with your right hand, sing along and have fun! Instant gratification, no sweat and tears (maybe a little blood if you play too long at first and use steel strings - ouch - need to let the fingertips harden gradually).
That's why my site is organised in levels, with simple chord diagrams on each song sheet (and large font for oldies like me)- you can start very easy and gradually pick up extra chords at your own pace, and you should be able to play some songs at each level as you go.
Some people are happy to only ever play the first few chords, and that's fine. Others get keen and go right through to bar chords. I haven't written those up yet - I think the basic stuff is what's most useful with my site. So keep picking up that guitar, check the chords you know on the simple chord chart and find some songs with those chords ( list of songs with chords at www.cathyschords.com/listofsongsforguitar).
Have fun, and let me know how you go. Remember, it's great therapy for you, and great if you have young kids around, too- they think you're SO clever;)
Suggestion re your range: some songs need a wider range than others, and it can be tricky to work out the best key to sing in. Our Friday Folkies group has male and female voices, so we tend to do a lot of songs in D (a bit high for me, and the guys would prefer Eb, so it's a compromise; some of the women prefer to sing higher, too).
This is where a capo is so great - you can try out a key, then if it's a bit low, try it with your capo on 1st, 2nd, 3rd fret.. you may be able to go higher if your neck isn't too wide.
Try singing a song like Rock My Soul, which has a narrow range and only 2 chords - start in the key of D (D, A7 chords). For my voice it's OK in D if I sing low, but if I try an octave higher, it's too much of a stretch. If neither works for you, try a capo, or even a different key - the A and D7 chords are easy to play. I'll often try a song in the key of C (or D), then in G, to get a quick idea of a good key for a song - then I can use a capo to bring it up a bit if needed.
Once you get an idea of your favourite key to sing in, you can try that one first for a new song, then use a capo, or transpose if needed. I do find that my voice changes from day to day, too;) Some of our group songs have 2, 3 or even 4 sets of chords written in, as we've tried out different keys at different times. One group member used to call these one "alphabet soup".
Singing along to songs is a bit of a trap- so often the recording artists have a great range (they are professionals, after all) and if it's a male voice, that can be hard, too. I like Peter, Paul & Mary and Simon & Garfunkel to sing along to as I can usually do one of the voices. John Denver is OK for me, too. Otherwise I have to turn up the volume to drown me out! Perhaps you can find a good "sing-along" artist for you - or just accompany yourself on guitar :)
In the key of D, the Dominant 7th chord that you would use would be A7.
The D7 (or A7 chord etc) is actually a "Dominant 7th" chord, which has the minor 7th added to the major chord/triad. The Dominant 7th chords are used frequently, and are commonly just referred to as "seventh" chords, which is a bit misleading... for guitar, I find it easier just to learn the main set of chords for each of the common keys;)
Hope this makes sense...
A thought about singing: If you want to sing along with a song that's not in your key and you used to sing descant, can you try some harmonies? Also remember that if you practise singing scales, you can maybe extend your range again?
I went looking for a good chord chart online- I have a really good one that I've had for over 40 years which shows the main chords in each key, the key signatures etc, really clearly laid out. I don't know if it's still in print, but it's probably still copyright, or I'd scan it, (I may still do that one day, just not sure of the legality - maybe OK for study purposes).
I found a similar chart that you can download- not a very clear scan, but a good layout- check it out at
http://enterarena.blogspot.com/2009/12/guitar-chord-guide-by-danny-taddei-1986.html
If you're a visual learner like me, it may help you to get a good "overview" of the chords and keys - though if you want to get back into all that complex theory, good luck with that one- sounds too much like hard brain work for me;)
Hope you have fun - and keep playing and singing- even simple songs can be fun!
I tried playing your "father Charles.." notes, but they didn't sound like anything to me ;I
You could always make a larger version and write in the notes if you wanted:)
