LED Aquarium Lighting
This is an LED based Aquarium Light. It consists of a sheet of plexiglass with holes drilled in it to accommodate LEDs facing downward into the tank. The circuitry is above the plexi and will be waterproofed with silicone/hot glue later on.  The power supply can be any transformer that you have kicking around. I used a 9.0VDC 800mA clock radio transformer.
The idea of this is to:
1) Reduce the cost of lighting your aquarium
2) Lower the heat generated by lighting
I am in no way responsible if anything goes wrong, and as with any electronics, there is a certain amount of risk involved.
I would not recommend using this on a planted tank because LED's do not have the proper spectrum.
Step 1Planning and Design
First off, you must decide how many LEDs you are going to install, and how to install them. I decided to use a 18x3 grid of LEDs. For my 10g tank (20" long), I chose to start the LEDs 1" in from each end of the tank and a 1" space between LEDs. Your design will most likely vary. You also must consider the fact that resistors are needed when working with LEDs. I had this site recommended to me and I found it to be VERY useful. You must know what voltage and current your transformer will put out. You also must have your LEDs chosen and know the voltage and current required by them.
29 comments
Sep 9, 2011. 9:12 AMbutterflyrobin says:
If you want the light more diffused sand the rounded LED lights so that they are flat on the top. This will also allow you to use less lights for your set up.
If you drill your holes at an angle you can even angle them to get more even lighting across larger tanks without having to use a wider set up or if you wanted to replace a light in a current hood light.
Also, for anyone that may not know Led lights, resistors, jumper wires, breadboard, circuit boards and extra wire, and even you transformer can be found at Radioshack.
Feb 4, 2012. 2:02 PMArbitror says:
If you get the proper full spectrum LEDs you can use this for planted setups.
May 17, 2010. 6:56 PModdysea682 says:
 Where can I find LED lights in utah like a shop that sells them, mostly around salt lake city
Jun 15, 2011. 8:54 AMjeffeb3 says:
The internet has a lot of choice. The best electronic shop I've used is mouser. Lots of specs, and lots of choice.
Nov 12, 2011. 6:07 PMbudman95 says:
new to building with leds what will happen if you use a transformer from alarm clock and don't use resistors?
Sep 29, 2011. 9:40 PMphillipwheatley says:
i may sound dumb, but what is a transformer, its purpose, and what kind of transformer are you using?
Oct 29, 2011. 7:22 PMkievokanievo says:
A transformer is an electrical component that has two sides (a primary and a secondary). It is used to step a voltage up or down according to the need. His transformer takes the 120 volts AC (alternating current) from the outlet into the primary side and steps it down to 9 volts on the secondary while also converting it to DC (direct current) by additional methods.
Oct 8, 2011. 11:49 PMRGalliath says:
You do realize that it would have been much simpler to use one or only several resistors instead of 30.
Sep 29, 2011. 9:36 PMphillipwheatley says:
i know that black chord is the power supply...is it plugged directly into the wall outlet? i want to replicate this same concept for my fish tank/turtle aquarium and powering the LED lights is the only part of the project that i am uncertain of.
Jun 15, 2011. 8:58 AMjeffeb3 says:
Great project. I think I will try this at home. Do you think the lighting would benefit from a more diffuse light? I've used thin white plastic before to make LEDs have a more spread out light source. If you had the ability to dim the LEDs, do you think you would? i.e. an adjustable timer (555 timer) would allow you to adjust the duty cycle with a trim pot, or I suppose you could dim them with an additional power consuming pot, but that might not be as efficient. I just wonder if I would ever think they were too bright...
Sep 9, 2011. 9:15 AMbutterflyrobin says:
Another thought is to put some a row of Blue lights in the fixture as well to simulate moon light. You would just have to use a three way switch.
Sep 6, 2011. 6:08 AMratcrib says:
good instructable! one suggestion - don't use hotglue for this type of stuff - it's not a long term solution...after a year or so in close contact with water it will lose it's bonds and may peel off surfaces. Consider using epoxy or silicone.
Mar 21, 2011. 2:04 PMpyroarchist says:
can you get the same effect by hot gluing a bunch of throwies into the plexi?
Feb 26, 2011. 7:58 AMjoshiers8605 says:
What is the MCD on your LEDs, mine are kind of dim, lol
Feb 26, 2011. 10:13 AMjoshiers8605 says:
ok :), thanks a lot, very helpful, great tutorial also
Jan 8, 2011. 11:55 AMShadowTheClown says:
Ok, I have a very large fishroom. 50 tanks as of right now and 30 in storage, when i plan on moving i want to use all of them. I've been researching into doing these for all of them with a combination of blue and white leds to make an actinic bulb effect, but im also thinking of making a back section for moonlights on the breeding tanks. What im getting at is, obviously the cost of running flourescents vs these is worth it, but being in a large humid fish room, where the lights run 10 hours a day on a timer, would the bulbs burn out? or even with hotglue protection will the wires corrode faster?
Dec 27, 2010. 1:12 AMtheledguy says:
Awesome project! I used your method to build a fixture for my 20gal tall, and it looks fantastic. Not only does this conserve energy (my 3X33 panel only consumes 7 watts, and puts out more light than the old 15W T8 fluorescent), but colors look so much more vibrant than with either incandescent or fluorescent. Anyone with an aquarium should look into building one of these
May 20, 2010. 3:45 PMrooster8d says:
You did a real good job on this.  I have done some LED work and I like your setup.
Mar 21, 2010. 9:21 PMkmossman says:
(removed by author or community request)
Jan 16, 2010. 11:36 PMMike__ says:
How thick is the plexi that you used? It looks to be 1/4" ?
Did you find that the plexi sagged in the middle and is that the reason why the tank has is drained a bit from the top?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
7
Author:Willard2.0
I graduated in June 2010 from the Grande Prairie Composite High School. I have since gone back to high school to upgrade. Currently I am working on achieving the CompTIA A+ Computer Technician certi...
more »
