This is a fairly simple project.
Parts Needed:
MAX6952 LED Array Driver
Microcontroller ( I used a boarduino )
280 LEDs ( I used red 3mm purchased at mpja.com cheaply )
Perf board. ( I used a dremel to shave it down to size )
40 PIN DIP Socket
4 AA Battery Pack.
Threaded core ribbon cable ( Tried using solid core... DOES NOT WORK )
I used a 15pin VGA connecter to connect the array driver to the MCU and Power pack. Makes it easy to detach and work on outside of the jacket.
Remove these ads by
Signing UpStep 1Building the LED Array
Basically you want to follow the MAX6952 wiring diagram and make sure your 5x7 arrays are matched up to what it needs. I've included a photo of the completed array.
I just punched the leds through the fabric and into the perf board. You don't need to solder down the leds to the perf board (as they will ultimately all be soldered together anyways), but you may want to if the fabric is unstable. I used my pliers to bend the pins and inspected the led array with a magnifying glass once completed. Testing continuity with a meter is a good idea too. LED array problems can be hard to diagnose later.
Oh, and welcome to the site! As you may have gathered, we love LEDs here, and there's actually a competition running at the moment for cool things with LEDs in- I think this project could do well, maybe you'd think about entering it?
- PKM
I entered it in the contest. See if I can get a few more LED projects done before the end =P
