I love lights, and I love music… Naturally a color organ is something that I always wanted to make. However the circuits are often pretty complicated, using many op amps, etc. I'm sure that many people feel the same way.
Now the wait is over. If you are a bit familiar with electronics, you can build a 3 way color organ with only 29 components. I've streamlined the circuit to the absolute minimum, using easy to obtain, inexpensive parts. In fact, if you are electronic hobbyist, you probably have all the parts sitting around already!
In case you've never heard of a color organ, it's a device that emits different colors of light based on sound. LED Color Organ Triple Deluxe divides sound into three frequency bands, and emits red, green and blue lights accordingly.
Watch the video and you'll see what it does.
Remove these ads by
Signing UpStep 1: Overview
Three groups of LEDs each responds to high, mid, and low frequencies of sound.
In order to simplify the circuit, I design the Organ to connect to a headphone output of audio equipment. The power source can be a 9V battery, or a regulated AC adapter that outputs 9 V. (Most wall wort type adapters output much higher voltage than they are rated, therefore not suited.)
I'd like to thank Collin Cunningham of MAKE: Magazine for publishing his LED Color Organ. His version is a lot more sophisticated and complex (read: expensive), which led me to design a super simple version.
Visit Our Store »
Go Pro Today »
Hope this makes sense.
Aki
The R/C values are figured out by experiment. (Too lazy to figure out the math ;)
plus, will the printed circuit affected when i change the component? (by any means.. just changing without changing inside the software.)
i have this problem that when i do it on breadboard, it lights up like demo video. but on pcb, red leds are the only one light up and voltage at transistors drops drastically.
did i make error in somewhere? ;/ i'll post images later for u to check. thank you. :)
Do you have any advise about this problem?
And can i know the voltage rating for each capacitor that have polarised? thank you. :)
p/s: does the voltage written at capacitor will effect the circuit if each capacitor has different voltage rating? sorry, i'm newbie about capacitor stuff. hope you can reply.
Capacitors should be rated at least 12V. Doesn't matter if the voltage doesn't match. Voltage rating only means that the capacitor can withstand up to that voltage.
Aki
However I've been working on the new, improved version, and it's almost ready. I will do another instructables very soon.
Thanks
100 ohms at the input is to "mix" stereo signal into one without stressing the audio device connected. (Those should ideally be larger like 10k ohms but I could not afford the signal loss.)
Thanks
http://en.wikipedia.org/wiki/Electronic_filter
From there, you will find many links to references.
thanks
You can use small pre-amplified microphones like this one: http://adafruit.com/products/1063
or this one: https://www.sparkfun.com/products/9964
Aki
i build circuit as it is as yours but please explain me that why are you add second capacitor in blue led.
there is only one capacitor in schematic.
and if necessary to add it then tell me the value of it so i can add also.
when i on the circuit blue led is very dim and when i play music through computer's headphone, led operated for few second then automatically dim.
give me solution for it.
Thank you.
Please note this circuit is analog, and each transistors have different characteristics. Therefor it's often necessary to adjust the values of the components.
but now problem is that how to control input of circuit (volume) because if i decrease the volume then i can't hear music but when i increase level of music then led react constantly on so give me the resistor value that i can put between circuit input and speaker output.
temporary i used pot(4.7K) to limit input but nothing happening
should i use more then or less then 10k resistor to limit input ?
See the attached image - "+input" would connect to your speaker, and ground connects to both the speaker negative and the Color Organ's ground. "+Output" connects to Color Organ's input. (Don't worry about the ground connecting the pot's case.)
In your improved color organ circuit video. There seems to me a capacitor on the battery line of the upper right of the breadbord. May i ask what that change is? Does it fix the red led not lighting up?
This capacitor doesn't really affect the operation. If your red LED is not working, the problem is elsewhere.
http://www.instructables.com/id/Make-Music-Controlled-Christmas-Lights/?ALLSTEPS
I'm not an engineer but i need this to work badly if possible. Would it be possible to make a parallel tap from the positive side of the LED light on your circuit (right before the LED light itself) and attached it directly to the positive terminal of the solid state relay in the link above (where the positive speaker line should go), then attach the negative terminal of the solid state relay back to the negative side of the LED. My purpose is to extend the function of your circuit to much much more lights without (not too much modification, hopefully) Eventually, i'll be tapping 2 more of the same device to the other 2 remaining frequencies. Then maybe make it more complicated by adding 3 more to the stereo version of your circuit.
Since i'm adding the AC (high voltage aspect) of electricity into the scenario, i'm pretty sure there are risks here.
Gino
I think hacking a more sophisticated circuit like this one is much safer option.
http://blog.makezine.com/2010/10/18/circuit-skills-led-color-organ-spon/
will find out the voltage and current that passes through regular music headphones, if its not far off from the voltage passing through the LED on your circuit then it will work (cross fingers). Incase its not, hope the current and voltage on yours is higher so i can lower it before it hits the LED. Will let you know if it works. Sorry Collins circuit is beyond my build ability. Will try it with yours first. Thanks alot.
1. Could I possibly use MOSFETS instead of transistors? if so, what other changes should I make to ensure that they are biased correctly?
2. If I use yellow LEDs instead of blue, what resistor values would you recommend, or what should I change?
3. is there any way a CdS cell or 555 timer can be included in this circuit to increase complexity? I am trying to use a few other components, but am not sure how I can incorporate them to change it up a little. Please let me know what you think!
Thanks!
1. To use MOSFET instead of the BJT would require some mod to the circuit. Can't tell you the specifics, and to be honest I don't think it's worth the effort. If you want to scale up color organ, go with something like this: http://blog.makezine.com/2010/10/18/circuit-skills-led-color-organ-spon/
2. Use 270 ohm for Yellow. Same as Red.
3. Like the question 1, my circuit here is a practice in simplicity and compromise. Not a good candidate for scaling up.
Aki
Aki
Connect NPN power transistor's base to Q2's collector via 150 ohm or so, the emitter to the ground, then the high power LEDs connect between +12V and the collector. Do the same with Q3 and Q4.
The main circuit should still be supplied 9V, not 12V, unless you adjust the biasing of transistors.
I've made it on protoboard, but only the blue ones are working :(
I check it several times, I don't know what's wrong.
I'm beginner in the electronics, could you help me?
