3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
LED Hula Hoop
Step 5Mount LED's
Mount LED\
Next, mount the LED's in a 1/4" LED Holder . . . I got mine from Radio Shack, part #276-079. First , shove the LED assembly you just soldered, back into the 1/4" hole, just below the surface of the hole.
Then, snap the LED holder into the 1/4" hole you drilled. Now, while making sure the LED holder doesn't pop out, use a small rod (I used an old drill bit) to snap the LED into the LED holder from the back. This is where the hole through the entire hoop comes in handy! You should feel the LED snap into place.
Feel free to test your LED wiring at any time . . . you don't need to wire up the whole circuit before testing!
REPEAT STEPS 3-5 for all the LED's you plan on putting in
1 comment
Sep 2, 2010. 5:00 AMgeraghty says:
Hi, so for evry led i have do i need a hole on the oposit side of the tube? do these get filled in by somthink? hope you can help i rearly want to make one of these.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
16
Author:jeffkobi
