The approximate cost is $25.00 per lamp.
If you would like more information than this instructable can provide, check out the website for this project. http://led.hypertriangle.com
When I finished this project, I was very satisfied with the results. The light produced from 87 LEDs is very usable. You can see graphs of lux if you are interested at the website above.
The best part about this project is saving energy. The 87 LED lamp uses a mere 8.4 watts! (0.7 amps @ 12VDC)
This project was seen at the Intel International Science and Engineering Fair (IISEF) and the Bay Area Science and Engineering Fair (BASEF).
Help us out and digg this story!
Remove these ads by
Signing UpStep 1Materials Required
T12 Fluorescent Tube Protector
48" x 1.5" x 0.25" Plexiglass
87 Super Bright White LEDs
29 2.7 ohm 1/4 watt Resistors
2.5m 18 AWG Bare Copper Wire
20cm 14 AWG Bare Copper Wire
Solder/Flux
LM334
TIP32C
ZTX948
1k ohm 1/4 watt Resistor
100 ohm 1/4 watt Resistor
0.2 microfarad Ceramic Capacitor
Suggested Suppliers:
For the LEDs, if you are building your first buib, I recommend LED Shoppe. They have sweet deals on LEDs. The only problem is that they dont carry the most efficient or recent diodes.
For the bare copper wire, the 18 AWG can come from an old scrap of RG6 and the 14 AWG can come from Romex House Wiring.
The tube protector comes from most hardware stores.
Almost every other component there can be ordered from Digikey or Mouser
How did you "difuse" the led's?
Thanks
try it , make it and compare .
i promise this will give more light .
second LED tube light have long lifespan, 40000 hours more, keep eyes, no noise, can work under high voltage. and there are many advantages.....
usually for good leds and some famous brands its about 0.3% in 3000hours.
But we are only making complete tubes, but we need to test the leds, and choose the best to use, offer best quality to our clients. For more you may visit our website www.topuledlight.com, thanks
The key is mirrors.
Yes if you just put a ton of LEDS in a housing and power them all you are doing is making a LIGHT ENGINE just like a floresent tube is.
they have some patented method of using LEDS and mirrors to disperse the output and direct it using far less LEDS.
It is pretty neat to see how it is done.
After building do I just replace the normal flourescent tube with this? Or will I need to make some adjustment to the balast? also as I am in the UK do I build the small circuit as is or do I make some changes?
I HV MANY QUESTION TELL ME IN PERSONAL MSG....
Now what is the limit (down and up) of LEDs you may use? Lets say if you should replace a 4W lamp?
However, if you are willing to spend the time when these lamps are used in multiples they are very capable of lighting a room. I created four of these lamps for our project and we lit an entire room with three of them. The reason is because they are highly directional with light only coming from 20 degrees of the entire lamp.
Thanks - check out our site LED Ideas There are more pictures and graphs of light intensity.
