Because this is an educational project it's intended to be inexpensive at scale. There are only two electrical components (the LED and the battery) and if you buy them in bulk, and use the full roll of copper tape, it should come out to less than $1 per candle.
This first version of the candle doesn't flicker; it's really more like a little flashlight, but it's a nice shape and size to be used in lanterns or halloween pumpkins. I'm working on a design that uses a programmable ATTINY85 chip to flicker the LED.
Submitted by Ace Monster Toys Hackerspace in Oakland, CA for the Instructables Sponsorship Program
Remove these ads by
Signing UpStep 1: Materials list and tools. Also: What to use if you don't have a lasercutter
Additional materials:
1 LED. I like the jumbo 10mm LEDS, for example this yellow one from Jameco.com
1 CR2032 battery, available from adafruit.com and at most DIY hardware stores
1/4" adhesive copper tape, you can find it on amazon (see below for alternatives)
A bamboo skewer or short 1/8" wooden dowel
Tools:
Scissors
Wood glue
A strong clamp (an office binder clamp works well)
Wire cutters
What if you don't have a laser cutter?
You can cut these pieces out of 1/8" corrugated cardboard using a craft knife, or out of 1/8" wood using a scroll saw. You can even cut them out in layers of thin cardboard with scissors, and glue the layers together. if you choose a different material just pay close attention to the thickness of piece #2: It should be almost the same thickness as the battery. All of the parts need to be strong enough to hold up to use, and they need to be non-conductive, but if you keep those things in mind you can cut them out of anything you like.
Alternatives to copper tape
Since I was making a lot of these at Ace Monster Toys I bought a whole roll of 1/4" adhesive copper tape, but that's expensive. One alternative is to buy a smaller roll of copper tape from your local garden center - they sell it there as a snail deterrent. You'll need to cut it down into 1/4" strips. The simplest alternative of all is to use ordinary aluminum foil from your kitchen. Again, you'll need to cut it into strips, and you'll need to glue it. Rubber cement will work better for this than wood glue. Aluminum foil is thinner and more delicate than copper foil, so the key thing is not to leave any jagged edges that could tear as you move the switch arm.
rimfire13 says:
Nov 14, 2012. 2:24 PMReply
ringai says:
Nov 14, 2012. 3:30 AMReply
jessyratfink says:
Nov 13, 2012. 11:50 AMReply
Not Nice
Visit Our Store »
Go Pro Today »
