Simple replacement fix for dashboard lamps. LED's should out live the vehicle so should never need to replace them again.
you need;
- straw hat 1/2 watt leds (one for each bulb) (eBay has thousands to chose from complete with resisters)
- resisters for the leds to operate on 12-13.5 volts
- heat shrink tubing (to make it neat and tidy
- soldering iron and solder
- some thin wire (i use telephone cable)
- hot glue gun and glue
- tools to remove the dash panel
this is really easy to do and has vastly improved the legibility of my dash
Step 1: Remove the dash panel
So firstly remove the panel and disassemble it so you can connect to the electrical tracks
pfred2 says: Nov 6, 2011. 4:31 AM
Some things you may wish to add to your article.
What diameter LED you used. The ones you used seem to come in 5 and 8mm sizes.
What Ohm value resistor you used. You stated the correct Watt range but never the resistance value.
A more sure fire way to determine LED polarity. One easy way is seeing which lead is shorter. The shorter one is the cathode.
With apologies to Will:
To big, or not too big, that is the hole question!
http://www.educationbug.org/a/to-vs--too.html
Personally I like cars better after all their dash lights burn out :)
professor sparky (author) in reply to pfred2Nov 6, 2011. 6:40 AM
hi!
i use 8mm LED's which i buy with the correct resisters to run on 12volts, its cheaper than buying them seperatly and easier for those who dont know how to work resistance values. Mine are 2w 100ohm resisters.
R = (VS - VL) / I
VS = supply voltage
VL = LED voltage (usually 2V, but 4V for blue and white LEDs)
I = LED current (e.g. 10mA = 0.01A, or 20mA = 0.02A)
The polarity you need to check is the dash unit as the tracks are not normaly marked. sorry if that was not clear.
Perhaps i will do an instructable on basic LED science
pfred2 in reply to professor sparkyNov 6, 2011. 8:55 AM
No it wasn't clear to me when what you said was, "before we solder up the last connection to the LED's we need to check the polarity as LED's are polarity specific."  Check the polarity of what? The last thing you mentioned was LED. I am a contextual reader. Rereading it knowing the polarity you mean is the supply polarity it all makes sense. It didn't the first time I read through it though. Well, it did make sense to me, just not what you meant.
I'd like to see how the math is figured for a 100 Ohm resistor running an LED off 12 volts. So write that LED science article! Are your LEDs 80ma? The ones I was looking at online seemed to be about 20ma. Yours must be really bright!
professor sparky (author) in reply to pfred2Nov 6, 2011. 9:09 AM
hi, the LED's are 3v forward voltage, 100ma forward current.
yes they are realy bright!!
search eBay for "strawhat led 8mm"
the ones i use are 0.5w
pfred2 in reply to professor sparkyNov 6, 2011. 12:49 PM
I bet they are bright. Have you measured your current draw with a multimeter? What the hey it is working for you good luck!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
