LOG Raspberry Pi With Car Monitor
Published
Introduction: LOG Raspberry Pi With Car Monitor
About: Lazy Old Geek
So this Lazy Old Geek (LOG) decided to buy a Raspberry Pi. Now the Pi itself is really small (see picture) but the first problem I found was that with the all the cables connected, it’s not very stable. The cables, especially my HDMI cable dominated where it was going to be. So the first thing I wanted was a more stable environment.
Step 1: Power Supply
Instead of a Raspberry case, I decided I wanted a little development platform for my Raspberry.
Well, I had a power supply that I stripped out of (I think) an old DVD player that didn’t work. It has 5Vdc and 12Vdc. I tested the 5Vdc and it seemed to have at least 2 amps current so should be adequate for my Raspberry Pi.
So I built a plastic case out of some clear Lexan to reduce shock hazard. I left the front open for ventilation.
Then I bolted my Raspberry Pi to the top piece of Lexan. (see picture)
Even with the Lexan, the Raspberry still shifts around so I usually tape it to the power supply box unless/until I come up with some kind of a latch.
Step 2: More Improvements
Okay to eliminate the Ethernet cable, I bought a USB WiFi adapter. I already have a wireless network in my house.
http://www.ebay.com/itm/111239881192?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Be careful when selecting an adapter as many will not work with the Raspberry unless you know how to set them up to work. This one said that it would work and it did. Here’s how I set mine up.
WiFi Comfast USB 150MBs
Plug it into USB.
Power Up.
I think I had to power up twice.
Click on WiFi Config
MANAGE NETWORKS
Adapter: wlan0 (should be displayed)
Probably have to Scan for networks.
Select: your own SSID: (EnGenius1)
SSID: (EnGenius1)
Authentication: WPA2-Personal (PSK) (This is the protocol I use)
Encryption: CCMP (This sometimes called AES-CCMP)
PSK: ?????? (Pass phrase)
For keyboard and mouse, I already own a wireless Logitech set. I think mine is an MK320. It requires another USB port.(see picture)
Step 3: Car Monitor Display
Well, I bought a 4.3” display from ebay. Search for “4.3 LCD car monitor”
http://www.ebay.com/itm/380890377615?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
The one I received is a little different than the picture. The one in the picture looks like it has a swivel mount. Mine is adjustable only up and down. (See picture)
So I have 12Vdc on my power supply so I hooked up a power cable to it for the car monitor display. I also had a set of RCA AV cables (see picture). So I plugged the yellow jack into the display yellow receptacle (AV1) and the other end into the Raspberry Pi video out. {The standard for these cables is yellow for video, red for right audio and white for left audio}
Then I turned on the power. NOTHING!!! Some of the sparse documentation said that with no video, there would be a blue background. But I had nothing.
Well, I was about to complain to the seller but was playing around with it and some how hooked the display up to my DVD player. OOPs, it worked.
Okay, so I had to do some research on Raspberry Pi and video.
Step 4: Config.txt
So the Raspberry Pi has a file called config.txt that contains information used to set up the video.
Okay, here’s a potential problem. Suppose I edit config.txt while using my Raspberry Pi with my HDMI monitor. Then it might not work with any video. Now the Raspberry Pi software is based on Linux. While I was able to get the NOOBS software loaded onto an SD card with Windows, I wouldn’t be able to edit it with Windows.
WARNING: There are a lot of websites that say you can easily edit Raspberry config.txt with Windows. Don’t believe them. I was not able to do this. When I plugged the SD into my Windows PC, I couldn’t even see the config.txt file. And I do not have a Linux PC. {And I hate Linux}
I found this website and loaded Win32DiskImager onto my Windows PC and tried it out.
http://computers.tutsplus.com/articles/how-to-clone-your-raspberry-pi-sd-cards-with-windows--mac-59294
This works mostly. It does take a long time.
WARNING: One of the problems I found is that SD cards of a certain size, e.g., 8gB are not really all the same size. Apparently, Win32DiskImager copies the whole SD, so if you’re trying to copy an image to an SD that is slightly smaller than the image, it will not work.
So I made a Raspberry Pi image for HDMI display, so I can remake an SD if mine doesn’t work.
Here is a pretty good description of config.txt for video.
https://raw.githubusercontent.com/Evilpaul/RPi-config/master/config.txt
To edit config.txt
Start up Raspberry Pi.
If you’re in graphics mode, double click on LXTerminal
Type in “sudo nano /boot/config.txt”
Most of this file is just descriptions of various options that can be used.
Any line that starts with a # means that it is just a comment. So in my config.txt you have to go down to the bottom to find the active stuff.
Comment out all active lines that start with hdmi
In my file I changed the following lines:
hdmi_force_hotplug=1
config_hdmi_boost=4
overscan_left=24
overscan_right=24
overscan_top=16
overscan_bottom=16
disable_overscan=0
to this:
#hdmi_force_hotplug=1
#config_hdmi_boost=4
#overscan_left=24
#overscan_right=24
#overscan_top=16
#overscan_bottom=16
#disable_overscan=0
NOTE: I’m not sure if all of those lines need to be commented out or not.
Then I added the following:
sdtv_mode=2
sdtv_aspect=1
NOTEs: The mode=2 is actually PAL which is Europe but my display says it will take NTSC or PAL. It works on both but PAL seems to be a little better for graphics.
The aspect=1 is 4:3 which seems more readable then 16:9.
The sdtv_colorburst doesn’t seem to affect readability so I didn’t use it.
All of the hdmi stuff doesn’t seem to affect my display.
So the only active lines in my config.txt are the following:
sdtv_mode=2
sdtv_aspect=1
start_x=1
gpu_memory=128
Then save the file
Then do a reboot
sudo reboot
Warning: For those used to PCs, the Raspberry Pi takes a long time to start up. I think it’s even longer for RCA video as (I guess) it looks for an HDMI display first.
Now with this file, I can sort of read the text on my car display.
Step 5: Display Adjustments
On my display, the three buttons on the back are not identified. But with trial and error, the middle one is mode/select, the top is up and the bottom is down.
Pushing the middle one toggles through the setup options.
Brightness
Contrast
Saturation
Zoom 16:9 or 4:3
English Several other languages
Reset
Well, I discovered that by adjusting the Brightness and Contrast, I was able to improve readability of the text to an acceptable level.
NOTE: While my Raspberry is set to aspect of 4:3, I like the car video at 16:9 as it fills the screen.
Step 6: Conclusion
Well, the pictures show some of the results.
Since I am OLD and my eyes aren’t the greatest, I don’t find readability to be adequate for creating projects but the car monitor could be useful for some projects.
After I got my car monitor working, I found this article from Adafruit:
https://learn.adafruit.com/using-a-mini-pal-ntsc-display-with-a-raspberry-pi/overview
As usual, Adafruit did a great job on this article. As a result I changed my config.txt by adding this:
framebuffer_width=640
framebuffer_height=480
overscan_left=-14
overscan_right=2
overscan_top=-15
overscan_bottom=-16
I did try 320/240 and it was much easier to read, but I liked the 640/480 better.
    • Planter Challenge
      Planter Challenge
    • Casting Contest
      Casting Contest
    • Clocks Contest
      Clocks Contest
    2 Comments
