Lantern Clock
Lantern Clock
Hello All
here is my first Instructable, It’s a beautiful Nixie Lantern clock, A little steam punk and a bit Victorian, made up of mostly of found components
I tend to communicate better when there is something to show so please look at the images and tags, they sometimes will hold more info than the body of text.
Here is a parts list....
-large slab of walnut 2" thick by 36" long and 12" wide
-large slab of maple 1.5" thick by 30" long and 12" wide, both found on eBay
-2" diameter clear acrylic tubing .125" wall about 12" long, any plastic store and eBay.
-an assortment of gears and gauge faces / bezels, knobs and metal bits,
- A nixie kit, I highly recommend a seller on ebay who goes under the name...petes_kits,  here is a link...  petes_kits, http://shop.ebay.com/petes_kits/m.html?_trksid=p4340.l2562
he has to my knowledge the only nixie prototypers board out there that gives the experimenter options of screw terminals, solder pads and designated nixie patterned mounts for leads, not to mention he always answers and is there to help you out.
-you will need some basic electronic skills
-a multimeter with a continuity function (prefer an audible function).
-3 Blue leds
-A mill and lathe for custom parts, machining skills are very helpful
-lots of brass and aluminum
-all sorts of hardware and locktite
-12 conductor 28AWG ribbon cable
-9VAC transformer, wall wart
-assortment of gears, shafts and collars
and finally... lots of imagination.....
Step 1Finding the way
Finding the way
first step was to gather all your resources and mix and match, try to figure what works and which direction you are willing to head in.
my original concept was to have each Nixie in it own chamber. but through trial Realized I did not want the clock to be lengthy.
after finding the diameter i was going to work in, i made sure the 2 Nixie tubes would fit side by side within the acrylic tube, this required a custom circuit board to be made to not only physically hold the nixies in place but to allow all the terminals to be easily soldered to, this also allowed me to place where I wanted the wires to terminate into the circuit board, out of site.
for the circuit board you will need....
-copper clad single sided circuit board material
-etching solution http://www.allelectronics.com/make-a-store/item/ER-3/DRY-CONCENTRATED-ETCHANT/1.html
-circuit board transfer http://www.allelectronics.com/make-a-store/item/TEK-5/TECHNIKS-PRESS-PEEL-PC-BOARD-KIT/1.html
all materials were purchased here http://www.allelectronics.com/
etch cut drill mount.....
137 comments
1-40 of 137next »
Jan 24, 2012. 6:44 PMlongwinters says:
This has to be one of the best projects I have seen here or anywhere, I gave up trying to count the different skills used to construct it.
I love the wood work as I have done much furniture building, but the brass work puts this over the top, thank you so much for posting this, my poor old NIXIE clock will never be the same, in a some what grumbling tone, thanks for raising the bar so high, off he goes pondering the quality of his next project.....
Jan 16, 2012. 4:03 AMchvdwalt says:
This is truly awesome! I'm blown away!
Jan 9, 2012. 7:22 AMDaPope says:
What was the total cost of this project? It looks AMAZING and I would love to build/buy one.
Jan 5, 2012. 7:25 PMelectronfan says:
I thought to have seen really cool things, but this really blew my mind! Truly an amazing piece of art!
Jan 8, 2012. 7:36 PMelectridanger says:
I wouldn't classify this as art...I would classify this as pure epicness
Jan 8, 2012. 7:35 PMelectridanger says:
Agreed
Jan 2, 2012. 4:47 PMGASSYPOOTS says:
how do you read it!?!?!?
Jan 4, 2012. 4:10 PMGASSYPOOTS says:
uhhh i dont seee and #
Dec 26, 2011. 9:46 AMtlynch1 says:
ok that is one amazing clock you're work is top notch!!
Dec 26, 2011. 8:12 AMTHEORANGESNOWFROG says:
You have done an amazing work! Nice instructables!
Oct 7, 2011. 11:59 PMkgroce says:
can you make me a clock .. i'll pay :() Jepito@Gmail.Com
Dec 25, 2011. 3:56 AMithi says:
can you teach me.. i love to do new things like that m.ibthisham@gmail.com
Dec 23, 2011. 2:23 PMLlamarama says:
This is easily the most beautiful Nixie clock I have ever seen, in my opinion. Simply wonderful! Well done!
Dec 24, 2011. 9:44 AMLlamarama says:
It's just such a beautiful object! Nixie tubes are almost hypnotic all of the time, this brings it up to a whole new level! :)
Dec 21, 2011. 8:58 AMUgifer says:
Just seen this as a contest winner and I have to say it's one of the greatest projects I have ever seen here. I was interested to read that you had tried it out on a friend's boat - I thought it looked slightly nautical from the first picture.
Some day, when I have about 50 years to spare, I love to make one of these. In the meantime I will just have to admire yours!
Great stuff.
Dec 4, 2011. 10:27 AMZachFejes says:
I have to say, I think this clock is absolutely amazing. Great job!
Dec 8, 2011. 12:40 PMzimbibu says:
Love the clock. When do you thiink you'll be starting a new instructable?
Nov 8, 2011. 12:06 PMasteidl says:
Awesome project, incredible work. Would love to try making similar. Although, Yoda tells me to do, or do not, no try.
Nov 4, 2011. 8:27 PMzerochance says:
Beautiful Design and tremendous craftsmanship. This is one of the coolest things I've ever seen.
Oct 21, 2011. 8:35 PMdolichol says:
this is a really neat project! I want to build this, but I am a beginner with wiring, so I find myself a bit confused with your wiring directions. Could you possibly post a much more detailed wiring instruction?
I love this project idea- can't wait to start building it! I just need help with understanding the wiring portion. Very cool!
Oct 29, 2011. 4:09 PMdolichol says:
awesome, thank you!
Oct 10, 2011. 8:42 PMabramians says:
Absolutely INCREDIBLE!!!!!
Oct 10, 2011. 2:30 PMaction pig says:
The maple and walnut combo is gorgeous. Beautiful work!
Oct 9, 2011. 11:12 PMPersona says:
No. I'm sorry, this is just far too cool. I can't stand it. I can't believe you MADE this!!
Oct 7, 2011. 8:55 PMstevemoseley says:
Great project and Instructable. Congratulations on the win!
Oct 7, 2011. 11:37 AMdenaetak says:
I am so happy you won! I voted for you! It is beautiful! Keep up the great work! Denae Tak :)
Oct 5, 2011. 7:28 PMemihackr97 says:
You won an iPad the same day Steve Jobs died. Doesn't it feel kind of weird?
Oct 6, 2011. 1:38 PMemihackr97 says:
i do. :)
Sep 30, 2011. 8:31 PMjohnnyappleseed says:
This is beautiful on so many levels I'm almost speechless. The dedication. The precision. The aesthetic lines and arcs. Implicitly admirable. Truly.
1-40 of 137next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
45
Author:hellboy
