Introduction: Lata - Pesas
Las latas de refrescos deben reciclarse. La mayor parte de las veces el reciclado no nos beneficia en nada a nosotros, aunque sí al planeta. Una forma de obtener beneficio del reciclado de las latas,  es darles otra utilidad. En el Instructivo de hoy veremos como se puede fabricar una sencillas pesas para Fitness con una latas vacías.
English version.
Soda cans to be recycled. Most of the time, dropping a soda can in a recycle bin does not create any profit for us, although it does aid the planet. One way to get a return from the recycling of cans is to give them another utility. In this Instructionable today we will see how you can make a simple fitness weights with empty cans. step 1 MaterialsWe need:. Four cans of soda or beer (according to taste). Two pieces of PVC pipe of 29mm diameter or similar (Nominal 3/4" or 1" PVC pipe is about this size). Wood is also a good choice. 8 nails or screws 3x35 mm (exact size does not matter, but much over 2" will not fit inside the cans).. Ready-mix concrete . (Or use cement and sand. 1 part cement to 3 parts sand). Water for mixing concretestep 2 Preparation of the cansWith a can opener, remove the top of the beverage can. Smooth the edges with a pliers. No need to strive much as they will be covered by mortar and will not leave dangerous edges.We'll make holes in the ends of the tube and insert a few screws or nails to form a cross. The goal here is that when the concrete has cured, the nails or screws keep the tubing or timber embedded into the concretestep 3 adding the mortar.Mix the mortar and fill two of the four cans. Insert the tube or timber and let dry. Wait at least 24 hours. Repeat with the other two cans.step 4 increasing weightStandard mortar are achieved weights about 1 kg ( about 2.2 pounds) If you want to increase the weight, we can also fill the tube and add stones or pieces of metal to fill. Finally, if you want extreme weights, we can use larger size cans. Enjoy!
Step 1: Materiales
Necesitamos:
. Cuatro latas de refrescos o cerveza (según gustos)
. Dos trozos de tubo de PVC de 29mm diámetro o similar. También es válida la madera.
. 8 clavos o tornillos de 3x35 mm.
. Mortero en polvo. (También cemento y arena. 1/4 cemento + 3/4 arena)
. Agua para amasar el mortero
Step 2: Preparacion De Las Latas
Con un abrelatas, quitamos la parte de la lata donde está la anilla. Alisamos los bordes con unos alicates universales. No es necesario esmerarse mucho ya que quedarán tapados por el mortero. y no es peligroso.
Hacemos unos agujeros en los extremos del tubo y pasamos unos tornillos o clavos formando una cruz. El objetivo es que, al secar el mortero la unión con el tubo o madera, sea fuerte y no se desprenda  con el uso.
Step 3: Amasado Del Mortero Y Rellenado.
Amasamos el mortero y rellenamos dos de las cuatro latas. Introducimos el tubo o madera y dejamos secar. Transcurridas 24h. repetimos la operación con las otras dos latas.
Step 4: Para Aumentar El Peso
Con mortero estándar, se consiguen pesas de alrededor de 1 Kg. Si queremos aumentar el peso, podemos rellenar también el tubo y añadir piedras o trozos de metal al rellenar. Finalmente si queremos pesos extremos, podemos usar latas de conservas de mayor tamaño. ¡A disfrutar!
