Introduction: Lego Portal Turret
These are the instructions for my popular design of a laser turret from Portal. It's all Lego; you won't need any other materials to make this nice display piece.
Step 1: Parts Needed
Here are the parts you'll need. You may have some, most, or all of these in your own collection; if not, you can get them from Bricklink.com (or Lego's Pick-A-Brick , but they tend to be much more expensive, if somewhat easier). Part names may be different between Bricklink and Pick-A-Brick.
No. Color             LDraw no.     BL no.          Part name
4    Black              48729.dat       48729b        Bar 1.5L with Clip
2    Dark-Gray      44728.dat       44728          Bracket 1 x 2 - 2 x 2
2    Dark-Gray      4733.dat         4733             Brick 1 x 1 with Studs on Four Sides (color doesn't matter)
2    White              4733.dat         4733             Brick 1 x 1 with Studs on Four Sides
2    Black              47905.dat       47905           Brick 1 x 1 with Studs on Two Opposite Sides (can be Dark-Gray)
2    Black              4593.dat         4593              Hinge Control Stick
3    Black              3820.dat         983                Minifig Hand
1    Black              4497.dat         4497              Minifig Spear
2    Dark-Gray      30162.dat      30162            Minifig Tool Binoculars Town
2    Black              4006.dat         4006              Minifig Tool Spanner/Screwdriver
2    White              3024.dat         3024              Plate 1 x 1
8    Dark-Gray      4073.dat         4073              Plate 1 x 1 Round (color doesn't matter)
1    Trans-Red     4073.dat         4073              Plate 1 x 1 Round
2    Black               4085c.dat      4085               Plate 1 x 1 with Clip Vertical Type 3
2    Dark-Gray       4085c.dat      4085              Plate 1 x 1 with Clip Vertical Type 3 (type 4 is even better)
2    White               3023.dat        3023              Plate 1 x 2
2    Black               3794.dat        3794              Plate 1 x 2 with 1 Stud
4    White               3710.dat        3710              Plate 1 x 4
4    White               3460.dat        3460              Plate 1 x 8
2    White               3021.dat        3021              Plate 2 x 3
4    White               50746.dat      54200           Slope Brick 31 1 x 1 x 2/3
2    White               3048.dat        3048              Slope Brick 45 1 x 2 Triple
22  White               50950.dat      50950           Slope Brick Curved 3 x 1
5    White               61678.dat      61678           Slope Brick Curved 4 x 1
4    Black               4599.dat         4599              Tap 1 x 1
2    Black               41677.dat      41677            Technic Beam 2 x 0.5 Liftarm
2    White               6541.dat        6541               Technic Brick 1 x 1 with Hole
2    Light-Gray       4274.dat        4274               Technic Pin 1/2
1    Black               6558.dat         6558               Technic Pin Long with Friction and Slot
1    Light-Gray      4697b.dat       4696               Technic Pneumatic T Piece - Type II
4    White              3069b.dat       3069               Tile 1 x 2 with Groove
An Excel sheet of the parts with links and more information is attached.
Step 2: Step 1
Onto the build! I'll add hints down here for the Lego-illiterate. ;)
Step 3: Step 2
Yes, the tiles are supposed to swing back and forth loosely here. They will be secured later.
Step 4: Step 3
Unlike the previous step's bricks, these have studs (the knobby things) on all four vertical sides -- they are often called "travis bricks". This step ties the whole assembly thus far into one piece.
Step 5: Step 4
Step 6: Step 5
Step 7: Step 6
None of the non-white pieces' colors here matter much; they won't be very visible.
Step 8: Step 7
Notice that you do the same thing on the other side.
Step 9: Step 8
Step 10: Step 9
Step 11: Step 10
Step 12: Step 11
This connection may be a little loose; using newer clips or gently squeezing the clips before attaching the brackets can help.
Step 13: Step 12
The 1x1 slopes are called "cheese slopes", one of my favorite parts.
Step 14: Step 13
Step 15: Step 14
This one can be a bit tricky; the bases of the sticks, when put in together, should stick tight in the red plate.
Step 16: Step 15
Fit the previous assembly in the 1/2-plate gap that goes around the body. Try to fit the balls of the lever handles in the gap in the middle; this may take several tries. Once they're in, gently squeeze the body to slightly shrink the gap, to hold the eye in place.
Step 17: Step 16
Did you get the eye in? Great!
Step 18: Step 17
Step 19: Step 18
The tap's top can move around a bit within the slope, making for some nice angles.
Step 20: Step 19
Depending on the parts you have, you may have to pull the hands out of your minifigs' arms. It's okay, they won't mind.
Step 21: Step 20
Step 22: You're Done!
Once you've adjusted the legs to your liking, congratulations! You now have your very own Portal turret. I recommend using it only as a display trinket; it won't hold up to much play.
Step 23: Credits
These instructions were built in LDraw/MLCad, then screencapped in LDView and edited in Photoshop Elements.
Step 24: ...But What About the Laser?
Oh, right. You're wondering how I achieved the laser in my photograph? Don't worry, your turret won't actually kill you.
Materials needed for laser effect:
Laser light (warning: don't shine in anyone's eyes, etc.)
Misting humidifier or something else that creates a mist or fog
Step 1: Shine laser into turret's eye (it's okay, he can't be blinded)
Step 2: Fog up the area with the humidifier to make the laser visible
Step 3: Take picture
Here's my setup:
http://www.flickr.com/photos/ltdemartinet/4653056529/in/photostream/
game.life challenge
Finalist in the
game.life challenge
MakerBot Challenge
MakerBot Challenge
