Light Theremin
Light Theremin
The Light Theremin is a simple to build instrument that uses light and shadows to create sound. The theremin circuit used nomally for these insruments are quite complex, this one however is as simple as a 555 Timer IC and some basic components from your scrap box. so with out any more delay...Lets get started!
Don't forget to visit my site:
http://www.wix.com/SimpleCircuits/Simple-Circuits
Step 1Materials
Materials
Your materials list is really quite short. You will need the following parts...
Please note that the quantity of each part is in the [ ].
-555 Timer IC [1]
-100uf Electrolytic Capacitor [1]
-1.0uf Disk Capacitor (Marked "104") [2]
-Photo Resistors [4]
-1K Resistor (colours: Brown, Black, Red, Gold) [1]
-a Switch [1]
-9v battery [1]
-A speaker [1]
-A IC proto board to keep it all nice and tidy [1]
-Some machine screws and nuts to hold down the board (optional)
41 comments
1-40 of 41next »
Apr 7, 2010. 3:46 AMluudvig says:
Thanks, I built it and it works great!!
Mar 1, 2011. 7:00 PMrtty21 says:
Looks cool! I'm subbed!
Sep 3, 2011. 1:51 PMbibbibbib says:
is the voltage rating for the 100uf capacitor 25v? or something else
Jul 9, 2011. 4:38 PMblinkyblinky says:
104 capacitors are 0.1uF!
Mar 7, 2010. 2:42 PMmgrc says:
Mine won't work...I put in on a breadboard and re-checked everything twice. Does it matter if 2 of the photorisistors are slightly different sizes? Are they polarized (+, -). I also tried what datenkrieger said and removed C2 and put in between pins 1 and 2, but still nothing. I'm using an adjustable power supply set to 9v, so it's not that. my 555 timer said LM 555CN. I'm using a 100uf cap and two caps marked '104', just like you said. The speaker is marked at 8 ohms and it makes crackly sounds when I hook it straight up to a AA battery, so that works. I'll ask my dad, but do you have any ideas?
Mar 7, 2010. 3:40 PMmgrc says:
Nevermind, I got it. It turned out I had a bad spot on the breadboard, so I just moved everything over a bit, and still using Datenkrieger's idea, it works. I might need a better speaker because it really sucks with low pitch, it just makes ticking noise. Has anyone wired it up so a pair of photoresistors changes the pitch and the other pair changes the volume? It would be like a radio-wave theremin. Good instructable BTW. Thanks
Feb 27, 2010. 10:40 AMraisin_brain747 says:
where can we get all the materials?
Feb 19, 2010. 1:36 PMGreenD says:
 I'm assuming light allows for current to pass through the photoresistors?
I wonder if there is a way to make the sound more pleasing...?
Feb 22, 2010. 5:36 PMraisin_brain747 says:
Would it be possible to add an oscillator and a pot. to control said osc.
Feb 1, 2010. 3:48 AMkappish028 says:
oh i see.hehehe!!! thanks your the best! before i forgot can i see the back of this light theremin that you made if that is possible but if not its ok. last question can i bend this theremin?
Nov 24, 2009. 11:47 AMMottGia1 says:
Hey, you said we needed 2 "0.1uf Disk Cpacitor" but on both the next images you say we need 1.0uf capacitors, which ones do we really need then?
Jan 27, 2010. 12:28 AMMottGia1 says:
Thank you
Jan 26, 2010. 10:55 PMedspegeddd says:
i'm confused about the capacitors as well.  I bought 0.1uf disc capacitors because they read "104Z" on the side, and look exactly like the ones in your picture.  the electronics store did not know of any 1.0uf capacitor with '104' marking... just the 0.1uf.  anyway, my circuit works it's just the volume output is very very low.  you can barely hear it.  any ideas?
Jan 15, 2010. 12:42 AMkappish028 says:
can i use any 555 timer? what kind of 555 timer did you use? sorry i dont know anything about electronics kindly help me thanks.i saw that there are LM555 and NC or NE 555 timers what is the differences in those timers?thanks!
Dec 16, 2009. 7:15 AMluudvig says:
Does it matter how many volts the capacitor is on?
Aug 9, 2009. 5:04 AMblindrulz says:
hey guyz comment this simply like wat is did
Jul 24, 2009. 11:36 PMLaogeodritt says:
Hello, This looks like an interesting project, thanks for posting. I have a few questions regarding the light theremin: Does it allow controlling the amplitude of the output with one control and frequency with another (as with the real theremin)? From what I understand of the IC and this circuit, it doesn't seem so... If not, do I understand the 555's specs correctly in that the amplitude of the signal is proportional to the input voltage, and so I could implement this feature by varying the voltage at the +V pin? What is the max voltage this puts out? Is there any risk of damaging drivers with an impedance in the 8-16 ohm range by hooking them up directly? (Or, in other words: what considerations should I make regarding the speakers - impedance, etc. - or the output to prevent damaging them?) Thanks, Laogeodritt
Jul 27, 2009. 5:17 PMLaogeodritt says:
Hello, Yes, essentially, volume - to me, a given instrument isn't musical if it's lacking the ability of expression, a lot of which is done through dynamics. I was hoping it implemented or I could implement something similar to the left antenna using light-sensitive components. (I was looking at the circuit itself, but I stupidly neglected putting something at the output stage... I can pretty trivially add a voltage divider there.) All right, thanks. I was mostly concerned with damaging them. I plan on putting an output jack on it and playing around with the sound using a few (home-made) analog effects/filters, so I'd rather be sure. I'll probably check the output and see if I have cheapie speakers lying around just in case... Thanks for the reply. Laogeodrtt
Jun 30, 2009. 6:52 PMamplex says:
very cool!! ive been wanting to make one of these with an antenna for awhile, picked up an RC antenna from radioshack awhile ago, how much different would that be?
Jun 30, 2009. 9:12 PMamplex says:
i understand that you are using resistances to determine the pitch of the 555 osc with the LDRs, not radio waves or IR, but im thinking that you could easily adapt it to the antenna type by having one pin on the 555 be the top of the antenna, and the other pin be the bottom (so the antenna acts as a variable resistor depending on where you put your hand on it and how much contact you make).. not exactly the original theramin idea (of not touching it to play it) but would this work? kind of like how a ribbon controller works?
Jun 23, 2009. 7:06 PMGamernotnerd says:
Sounds like a squirrel getting raped... On some sort of squeaky surface.
Jun 26, 2009. 6:22 PMGamernotnerd says:
It was a good idea, lol.
Jun 14, 2009. 2:54 PMdatenkrieger says:
I tested it on a breadboard, didn't work until i removed C2 and put it between pins 1 and 2. But then it worked like you described. Nice casing btw.
1-40 of 41next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
30
Author:TXTCLA55(Simple Circuits By: TXTCLA55)
Hack, build, design, and create.
