iImage Information
Frequently I need to make something small an exact thickness. Here the piece of oak needs to be reduced in thickness to fit into the saw kerfs on the corners of this child's toy. It is easy with a sanding drum on a radial arm saw and an auxiliary table.
Step 1First, cut the kerfs
iImage Information
The toy is a wooden frame with a swinging yellow door in it. A child threw a tantrum and then threw this. The joints were end grain glued, and several broke. Just to get started, I glued the pieces back together just as they had been. I decided to make kerfs and add glued splines for strength. The jig is from a
previous Instructable on accurate miters with a radial arm saw. I have set the motor so the shaft is vertical. The jig slides from right to left against the fence. Each corner has two kerfs, so after cutting one set, I turned the toy over and cut the second set. This is about as close to the blade as I care to get my fingers without using pusher sticks.
Thanks for sharing
Thank you for your comment. I enjoy your Instructables.
Yes I understand completely how and why you do it now.
I would then recommend an instructable to you, by Phil B "A precise table saw from an electric hand saw" he might teach you a thing or two. So no excuses not to have one now hehehe
Thank you my friend for this great ible. For this you'll get a patch.
