3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
MINI TESLA COIL 50KV!!!! (revised)
On my last instructable about my mini Tesla Coil I did not do so well because I did not know much about them but since then I have learned much more and have batter plans.
How it works: First off the mains goes through a high voltage transformer and charges the capacitor bank. When the caps are done charging they will let the high voltage from the transformer "pass" through them. During that split second (much to fast for a human to detect) the arc will jump through the spark gap, which is automated with RSGTC's, the caps will discharge into the primary coil. This is where resonance comes in, the fast action of the caps and spark gap rapidly induces an electromagnetic field around the primary, what many dont know is it starts off as a low voltage that adds up each time the spark gap fires until it creates extra high voltage
-=This project deals with high voltage that could potentially be lethal, do not touch the streamers unless you know what your doing=-
-=never operate high voltage equipment before turning it off=-
-=I will be some information from my other instructable=-
Step 1You will need
you will need
  • last photo ←
1' tall 1/2" diameter PVC pipe or other non conductive cylinder
about 5' of speaker wire, I didn't have enough of the thicker gauge wire
8" tall 1" diameter PVC pipe, you can use something a little wider but I couldn't find anything
10kV 23mA ignition transformer, you can get them on eBay for about $20-$40
15 1kV 0.01uF film capacitors
about 300ft of 32 awg mag wire
some 18 awg solid copper wire to connect everything
2 round headed bolts or "i" screws, try to keep them as smooth as possible
a 10"x4" piece of wood
copper connectors or some 1" bolts with nuts
a drill with various sized bits
a hot glue gun
a soldering iron, with solder
28 comments
Feb 14, 2012. 1:30 AMOVERLOADED says:
Jimmy are you still on instructables? I have been trying to reach you and left many comments about your 100kv EB driver. can you pls reply if your still taking on questions here thx.
Jan 8, 2012. 6:45 PMTechno Dude says:
Do u know someone who can help me
Jan 7, 2012. 5:10 PMTechno Dude says:
I want to know how to connect 555 timer with ignition coil,because I tried another ignition coil driver,
but it dint work why can some one pleas help me?
Dec 28, 2011. 10:19 PMBumba Lodh says:
Hi,I built a TESLA COIL with 5kv 30ma nst.Primary coil made with 4mm
copper tube with 10 turns secondary made with 2inch PVC pipe.Winding
height 10.2inch(0.315mm enameled copper wire used) also made Capacitor
bank with 2kv 0.15uF polyester film capacitor.But the problem is my
Capacitor burnt several times but the coil works with LEYDEN JAR
capacitor.Why the capacitor burning??????
Please Help Me!!!!!!!!!!!!!!!
Dec 7, 2011. 12:51 AMtechxpert says:
boooooooooooooooooooooooooooooooooooo
oooooooooooooooooooooooooom!
Sep 19, 2011. 2:26 AMTechno Dude says:
can u tell me the connect of the 555timer and ignition coil?
Sep 17, 2011. 11:12 PMBumba Lodh says:
I've bought 5Kv 30mA NST at 35$. Please tell me how many capacitor needed?
Here is Some Formula that can help you
1. calculate the resonant frequency of the secondary circuit:
f = [2π√(L(Ccoil+Ctop))]^(-1)
2.The primary coil forms an LC oscillator together with the capacitor. The desired inductance can be calculated with the following formula: L = [(2πf)2C]^(-1) C is the capacitance of the tank capacitor and f is the resonant frequency of the secondary coil.
3.The resonant capacitor value for the power supply can be calculated with the following formula: C = I ⁄ (2πfU)
and Visit http://www.richieburnett.co.uk/resonant.html
hope it may help you
Sep 11, 2011. 8:11 AMjosh1324 says:
Amazing! 5*s!
Sep 9, 2011. 1:59 AMBumba Lodh says:
i want to say can i use transformer(I Found it from my Old CD player) coil's wire to make primary coil
Sep 9, 2011. 2:25 AMBumba Lodh says:
how to make a toroid
Sep 8, 2011. 5:33 AMBumba Lodh says:
I've large amount of 200volts ac to 12 volts step down transformer coil. can i use it for make secondary coil
Aug 20, 2011. 5:18 AMTechno Dude says:
why do u need an 555 timer
Aug 12, 2011. 1:17 AMTechno Dude says:
so I was thinking of making a tesla coil using battery and ignition coil do I need a 555timer
Jun 17, 2011. 10:35 AMsguy1 says:
i am working on one of the teslacoil medium sized. but i don't know which part should i ground? is it the capacitor! or the primary coil or secondary coil? or none!
i again want t0 ask again one question
do we have to connect primary coil and secondary coil? i just don't get this part! how primary coil gets that enormous amount of voltage! is it because of the magnetic field due to secondary coil as you mentioned above!
please do reply soon because the science exhibition for high school is soon in my town.
May 7, 2011. 7:43 PM.Unknown. says:
Do you still need RF chokes like the last tesla coil you did?
(http://www.instructables.com/id/MINI-TESLA-COIL/step7/RF-chokes/)
Apr 29, 2011. 4:20 AMbaker amin says:
Hi. thank you for this instructable. if you want to know the equation you talked about in step 3, then download this program from this link
http://www.richardsplace.net/files/tccad20.zip
this program is called "Tesla Coil CAD" and its uses to designing tesla coils.
Hope you like it.
And I have a question. did you make it from the first time. I mean did it work from the first attempt??
Apr 29, 2011. 1:07 PMIncandescence says:
Good job, this is one of the best instructables about Tesla coil I have seen.
I understand how the primary part work, but i don't get it for the secondary, an end of the coil has to be wired with the earth (something like a radiator?)?So the circuit is open, why is there a current and how can it produce an arc?
I'd like to build one but i'm a little concern about safety, I was really surprised when i saw you "touching" the arc, why doesn't that hurt you? I thought HV was dangerous.
Sorry if my english is not correct but it's not my mother tongue.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
63
Author:Jimmy Proton
