I basically modified a wire mesh office file holder to mount on back of a 22in. LCD to hold my Macbook for desktop use, conveniently hiding the computer while providing easy port access.
You will need:
- a laptop
- an LCD monitor
- external keyboard and mouse
- an office file rack/holder
- 2-4 screws with washers
- pliers, perhaps a metal file
- foam (optional)
mattlumpkin@gmail.com
http://mattlumpkin.blogspot.com
Remove these ads by
Signing UpStep 1Select an LCD
I chose the Asus VK22H (about $200 from Newegg.com). There are lots of LCD's that work for this and and only a few won't. The easiest method is to look at the pics on Newegg or Amazon to confirm available screw holes and room above the stand.
Going to be doing this myself to watch TV in my room using a USB TV Tuner and external speakers and just want to make sure I get the orientation right as the TV Tuner can sometimes make the fans run a bit.
That said, two years into this setup my fan started to get loud. I still insist it doesn't run any more than normal, but I did decide to replace the fan with one from ifixit. No problems since and I'm still using it daily. Just know your mileage may vary. Good luck on the TV setup. I like it.
Will let you know how it goes.
I take the battery out when I have it plugged into the monitor, so I have to take a long piece of tape, wrap it once around the power cord near the plug, and tape it plugged in.
And if your keyboard has quick keys you can set, just make one of them the eject button. Apple keyboards are basically the exact same as the ones on their laptops, so they have the eject/volume/brightness/etc.
But using Snow Leopard (10.6.1) I had to use InsomniaX to keep my MacBook Pro from sleep.
Man I must get me a 30" monitor. Or at least a 24". :)
