3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Magnetic speed sensor
How to make a magnetic speed sensor similar to those used to sense wheel speed in ABS systems
Step 1A magnetic speed sensor is...
The sensor works using a iron cored coil with a magnet attached to one end. When a peice of ferrous metal is moved towards the end of the sensor it changes the shape of the magnetic field in the coil, this changing magnetic field then induces current to flow in the windings of the coil resulting in a small amount of electricity being generated.
This sensor only detects movement of ferrus objects near the sensor so is typically used for speed sensing (for example a wheel sensor in an ABS system) usually in combination with a toothed steel wheel.
They are very rugged sensors and are not affected by dirt and have a very high signal output making them less sensitive to noise (ideal for automotive applications)
For example the sensor I have made will generate a sine wave of 50Vp-p into a 1Kohm load (that is a peak of 50mV)
54 comments
1-40 of 54next »
Apr 8, 2012. 10:25 AMgolddigger1559 says:
what would i do if i wanted it to detect a magnet. i lost the sensor for my bicycle speedo
Jan 21, 2012. 12:23 PMkotofeiivanovich says:
What sort of landy you have? Mine is an old range rover with a faulty speedo, and I'd be very glad to install an alternative to know what's my current speed.
First I thought of fixing up a hall sensor somewhere close to the transmission brake drum and putting a small magnet just on top of that drum, but that might cause some disbalance and it would show me just the speed of vehicle, while setting up four bolts like yours would allow me to track the speed of each wheel - I could even vizualize the traction on a pda or an ipod :-)
Right now I am investigating how the ABS/TC sensors are installed on the newer landies. I'd be glad to see continuation of your post - have you installed your sensor?
Aug 8, 2011. 4:23 AMabadfart says:
i would love to pick your brain over how you are going to mount this on your engine because i need a speed sensor on my 73 v8 dodge honey bee so i can add cruse control
Dec 17, 2011. 12:41 AMHomepwner says:
Hi, I'm not Peter the ungreat but I have a suggestion. take it or leave it. AutoMeter makes a digital speedo kit which comes with a modern sensor that you could "piggyback" to get your cruise input from. (you would lose your stock speedo functionality though.) You could use a modern rear diff/axle assy with an ABS sensor. This could be the input for cruise, and you would still have the cable op speedo. You could modify the oem gear to fit a modern speed sensor that might fit the original location on the extension housing of your trans, again this would make the oem speedo inop. Last but not least.... Old Cruise control units were vacuum operated, find one of your vintage and make it work. I hope this helps.
Dec 17, 2011. 4:58 PMabadfart says:
I actually found a old dodge motor home in the junk yard while harvesting a carb i pulled the cruse control and its running much better now except the cab over bed needs work
Dec 20, 2011. 8:36 PMHomepwner says:
Nice!" well, except for the fact that bodywork isn't any fun. " best of luck to you.
Dec 24, 2011. 4:46 PMabadfart says:
ya well it turns out that there was water damage in the frame and a crunch with a branch smashed it in. to bad but6 its tarped off waiting for the snow to go
Oct 27, 2011. 6:56 PMmandrews4 says:
Fantastic! I love it, some nice bit of magic there.
I have a tricky question. I want the sensor to produce a signal, which goes to a guitar bass amplifier, and produces a thump, when metal comes close to it.
How do I make the sensor produce a signal around the 33-100 hz range ?
Aug 13, 2011. 1:15 PMshodanx says:
is there a limit to the maximum signal frequency ?
I'd like to make a sensor like this to measure the six sided nut from a turbocharger shaft with a top speed of about 120 Krpm
not sure if I should go with an optical sensor instead (also not perfect because of condensation in impeller inlet blocking the view)
Jul 14, 2011. 5:31 AMvjoy d'souza says:
How do i put the magnet in between the coil and the iron...there is no gap there...any workaround??
Jul 15, 2011. 3:26 AMvjoy d'souza says:
Do we have to fit the sensor inside the bolt???If yes..why??
Does the sensor work directly without enclosing it in the bolt...Please reply urgently...
Sep 9, 2010. 2:47 AMDream Dragon says:
I might be missing something, but that looks AWFULLY similar to a Guitar pickup to me. I have a feeling that this is more or less the way Hammond make their "tone wheel" organs. The profile of the wheel obviously reflects the wave form of the desired sound....
Maybe I'm wrong, but it DOES look like one could feed the signal into an audio output device and yield some VERY interesting effects.
Oct 30, 2010. 11:33 AMJodex says:
This is actually just the same that Hammond organs have: tonewheel.
May 6, 2010. 4:02 PMmetric.nz says:
Well done.
This looks to be what I'm after, the general design looks about right.
I'd assume that if the sensor were looking for magnets passing past it on a rotating wheel it could work over a longer distance?
Does anyone know if this is available as a pre-made sensor by any name?
Mar 31, 2010. 4:39 AMdresch says:
Thanks! Really nice job. A great alternative for rigging up a quick custom sensor. Excellent.
Aug 15, 2009. 8:53 AMT3h_Muffinator says:
I think I'm going to end up doing something similar to this in order to detect the speed of a moving (ferrous) object. The amplitude of the signal should be proportional (?) to the speed of the object, right? Any ideas as to how I can figure out what the proportionality constant is? Do you think it's going to be linear? Awesome project, btw!
Jul 13, 2009. 4:46 PMluslugger says:
I would like to rotate the magnet and see the voltage rise and fall as it passes the coil. Would I just need a coil? Is there a simple way to get an iron core to wind the wire on? How does the coil winding orient to the magnet? If I need a 10 volt output do I put on more turns or get a stronger magnet? Both?
Jul 13, 2009. 5:33 PMWyle_E says:
A steel bolt will do. Radio Shack sels (or used to; it's been a while) magnet wire in small spools. Magnet wire has thin enamel insulation that lets you pack more turns into a given space, but any insulated wire will work. You're not trying to generate significant current, so smaller wire will let you use more turns. Note that small coin-shaped magnets are usually have their poles on the flats, so you need to spin the magnet like a flipped coin. The voltage you get is proportioal to the product of the strength of the magnetic field, the number of coil turns and the speed of the coil through the field. Depending on your application, you may be able to save some time by driving a small permanent-magnet motor as a generator.
Nov 25, 2008. 12:28 PMasfd says:
Sorry but I don't get the "(that is a peak of 50mV)" part. I thought 50Vp-p meant 50 volts peak to peak.
Sep 3, 2008. 11:54 PMvicky.vivi says:
i think it needs the hall effect wheel gear sensor to connect,and it is very cheap, about USD18, and if anyone want to buy, please contact me. my MSN: vicky.hu_123@hotmail.com
Sep 5, 2008. 10:20 PMwilliamgeorge says:
Ya its true and it will be useful for all if hall effect whell gear sensor to connect. How much prize it cost?
williamgeorge
Buzz Marketing
Jun 27, 2008. 10:50 AMjoeofloath says:
would this work in a similar way with a coil that detects a magnet fixed to the moving wheel? I want to use a reed switch like a bike speedometer, but I don't know if it can switch on and off at 10k RPM...
May 7, 2008. 6:45 PMnafango22 says:
i'm lovin the old school game boy in the back of this picture
Dec 9, 2007. 9:35 AMmaker12 says:
relays use cadmumium contacts and cadminum is a toxin eeeek!=
Apr 7, 2008. 1:47 PMOmegablood says:
Reference please.
Oct 29, 2007. 2:36 PMHAL 9000 says:
This is almost the same concept as the Tonewheel in the old hammond electric organs, instead of a magnet like you have Hammond used a guitar pickup and amplified it.
Jul 22, 2007. 2:23 PMironman53 says:
I really love your project but I wasnt really minded doing it cause i dont have any oscilloscope and it would be too hard to find an old computer and not compact enough..So i decicded to check in my workshop, i found a kellogs pedometer. Easy to work with, why not use this? incredibly easy, kellogs pedometer rules!
May 26, 2007. 9:59 AMThermionic says:
For those of you out there who want an Oscilloscope: build one! Seriously. Find an old Pentium 1 or 2 machine, put a teeny hard drive in it, install a small OS (linux, or windoze 95-8) and get a couple oscilloscope programs. There is a ton if info on the web about said FREE programs, and how to interface them with computer and the test leads. They may not be as pretty as having a packaged oscilloscope, but they get the job done. In the US you can usually find these old computers abandoned with an operating system still on the HD. Do some basic cleaning, and you have a scope on the cheap!
Mar 13, 2007. 11:30 AMpower says:
where to buy a cheap oscilloscope?I want to build this machine
May 15, 2007. 2:42 PMSullen70 says:
Check you nearest local thrift/recycling store. My bro-in-law found an oscilloscope for $3US that just needed a fuse. His local store's name is Deseret Industries. E-bay probably has a few at near-giveaway pricing too.
Mar 19, 2007. 7:04 PMgeoffcubed says:
Question. Now i know very little about this but had an idea. Theoretically since this just sends out a current proportional to the amount of ferrous material near the sensor could it not be used as a rudimentry metal detector? Thanks
Mar 7, 2007. 7:53 AMmje says:
Nice- although there are easier sources of magnets. You could probably sell the phone for $20 and buy a ton of small neodymium magnets!
Jan 12, 2007. 5:47 PMMrShifty says:
How long is your coil? Does it have more than one layer of windings? You're right about a hall-effect sensor being less rugged. Our robot team used a couple laster year to count sprocket teeth. They had to be so very close to the teeth that the tiniest amount of deflection would, er, did destroy them...
1-40 of 54next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:PeterTheUnGreat
I am Married to Beth, I am an Architect and have two wonderful children
