Make Furniture With Cardboard!
A small end or occasional table is always handy to have around. so I decided to make this project and will enter it in the Gorilla glue contest as well.
Step 1Draw The Design
Draw The Design
I just do a rough drawing, saves time, and no need for a CAD program.
177 comments
1-40 of 177next »
Mar 30, 2011. 6:47 PMSam the Wizer says:
Brilliant! I have a small studio apartment and am poor, and think I might employ your techniques to build a large room divider/shelving unit. My only fear is that it might be a fire hazard to have such a large cardboard structure in such a small space. I think if I go with fire retardant paint I should be ok. Not that I expect to have open flames or heat sources near this structure, but it would help to put my mind at ease.
Jan 8, 2012. 5:20 AMHandyMummy says:
The answer to fire safety as well as strength is here:
http://en.wikipedia.org/wiki/Sodium_silicate
1 part to 5 parts of water will do ;-)
Jun 17, 2011. 11:57 AMdeathbyvolt says:
lol i wonder if anyone has used this method to make a guitar?
Jul 16, 2011. 8:50 AMSchober says:
Making a guitar out of cardboard like this would be next to impossible. You would have a hard time making the cardboard strong enough to support the tension of the strings. Not without some extremely well designed supports on the bridge and (assuming you are thinking of using a wood neck) where the neck meets the body. Even then the tension might still be too great to keep the body from folding over on itself.
Jul 17, 2011. 1:51 PMreptedjess says:
What if you used epoxy between the layers?
Apr 21, 2011. 10:21 PMCobalt59 says:
Lol. CAD stands for Communal Arduous Duties. LOL.
Jun 17, 2011. 10:11 AMbigjeff5 says:
I googled CAD - I could not find "Communal Arduous Duties" (I got bored after four pages).
By far the most common result was related to "Computer Aided Design", followed by the comic "Ctrl+Alt+Delete", followed by the Canadian Dollar, followed by the Welsh word "cad".
In other words, I do not think that word means what you think it means.
Jul 10, 2011. 10:51 AMCobalt59 says:
*sigh* It was a joke.
Jun 17, 2011. 8:31 AMjasmineconrad says:
No it doesn't...
Jun 19, 2011. 10:08 PMddarkeststar says:
Superb. I think I'm going to be looking for a cardboard mine now :-).
Jun 17, 2011. 4:49 PMMandingaRes says:
Esta idea es excelente!! Justamente hoy me regalaron varios empaques de unas motocicletas alemanas que están compuestos por un esqueleto de madera (que ya tiene destino) y todo cubierto por un inmenso cartón, para el cual todavía no encontraba utilidad y me da mucha pena tirar a la basura.Tengo suficiente cartón para copiar tu diseño (o algo similar) y me sobra para hacer algún gabinete para guardar todo tipo de cosas...
Prometo fotografiar el proceso de fabricación de los muebles y mostrarlos con mucho orgullo. Muchas gracias por compartir la idea!!
Jun 17, 2011. 2:51 PMstar_above_the_clouds says:
This is absolutely amazing! I could not believe that this was made of cardboard! Thanks for sharing, now I know what to do with all the extra cardboard that is laying around my house. (:
Jun 17, 2011. 2:11 PMseabee890 says:
It has probably already been said, but I think that I would have more confidence in his hightstand than some of that ICEA (spelled intentionally wrong to avoid slander or copyright violations) Beautiful project.
Jun 17, 2011. 1:38 PMjavajunkie1976 says:
That end table with the lamp is CARDBOARD??!! Seriously?? C'mon, what kind of wood did you use? Both thumbs up on this one!!
Sep 17, 2009. 3:26 AMKryptonite says:
That's amazing, you can still just see the small corrugates in the picture, I almost couldn't believe my eyes that it was cardboard. I definitely know what I'm pimping my house out with. Any ideas in terms of strength for largest size? For example, how large was the top of your little table, how far apart were the supports and how much can it carry? Not that you'd want to try break it just see how strong, but still...
Jan 22, 2011. 3:37 PMkarlpinturr says:
Your main problem, strength-wise, is that the corrugations cannot take a point-weight. Basically, they are the first point of contact for anything, and your top layer will collapse, despite (or because of) the number of layers beneath it.
A spread weight is better, but can still be affected where the 'top' meets its supports.
I have found that brown (wrapping/parcel) paper over a layer of wallpaper-paste (essentially creating Papier Mache) can add strength
Jun 17, 2011. 10:57 AMbigjeff5 says:
You can significantly increase the point weight (and spread weight) strength with nothing but cardboard, kraft  tape, and glue, but it is tedious.
Instead of using flat pieces of cardboard for the horizontal sections, cut the cardboard across the grain at the thickness you desire, then glue the individual pieces together end-up.  Once done, use the kraft tape (or the parcel paper) to cover the entire piece - wrapping the tape parallel to the vertical pieces.  Make sure it is nice and tight.  Note that the tape (or paper) is critical to the integrity of the shelf, and it is important to have pieces of tape that wrap all the way around the shelf.
This provides incredible stiffness to the pieces by simply reconfiguring the grain in a more ideal direction.  In order for an object to break the table it must be heavy enough to tear the tape by tension only, which is pretty difficult.  You could probably break it by pounding on it with something, but less than that wouldn't likely cut the mustard.  Basically, if you can tie one end of craft tape to the object and lift it, it won't deform the shelf.  You'd probably be surprised what you can lift with that tape, and in most cases you'll have four or five pieces of tape resisting, not just one.
You can do this one better by placing another layer of cardboard on the top and bottom - again with the grain parallel to the vertical strips.  This is more difficult to plan out but is a little less tedious to build and is even stronger than just the tape - and it looks better.
Sep 6, 2010. 2:44 AMCyborgGold says:
you could make it pretty strong, much stronger than it is already in fact, by adding some fiberglass to it. You might even be able to make patio furniture using the fiberglass method, layering the card and fiberglass should provide enough support.
Sep 17, 2010. 4:44 AMKryptonite says:
Yes, but that's not using just cardboard! Maybe I'm just a perfectionist.
Jul 17, 2011. 1:49 PMreptedjess says:
That's being a purist, not a perfectionist. Maybe if you can use an epoxy finish instead of a varnish. That would definitely make the entire project stronger
Jan 27, 2011. 5:36 PMspanner1969 says:
Whilst what I am about to suggest does not constitue 'just cardboard' I would like to say that a really thin wood veneer on top would make the functionality (strength) of the top much better in terms of taking on point weight.
You could use really cheep 2mm ply wood or you might even be able to recycle some wood scraps from somewhere.
So in essence this is a fantastic instructable which I will attempt to make this weekend if LOML (aka SWMBO) lets me have some shed time by my self! LOL.
Keep up the great work.
Jun 17, 2011. 10:01 AMJeonLab says:
This is great inctructable. Thank you for sharing your idea. :-)
May 26, 2011. 2:53 PMquan_chi says:
Me gusto, quedo muy bien
Salu2
May 24, 2011. 11:01 AMhusamwadi says:
now if only we could build card board airplanes with engines....OH YEAH, NEW PROJECT!
Feb 26, 2011. 4:19 PMCobalt59 says:
Simple CAD tool? Do you even know what CAD stands for?
Apr 14, 2011. 9:10 PMapapp77 says:
You know that was sarcastic, right?
Mar 27, 2011. 5:43 PMjanetsellers08 says:
These are superb instructions - thanks so much.
@ Cobalt: chill out. Nobody is worried about CAD...
May 24, 2011. 12:50 PMYotta_Byte says:
CAD also stands for Computer Aided Design... so there is definitely no need to worry! :)
Mar 27, 2011. 5:54 PMjanetsellers08 says:
Thanks for this. Very nice looking, too. In college, I used liquor boxes ( they have the partitions which makes the box stronger) and made beds and sofas out of them with a plywood top. 6 of those boxes with plywood on top & foam will hold 2 people easily. We just covered them with a clothe/dust ruffle and the sheets and blankets and voila.
Feb 5, 2011. 3:07 PMsantis308 says:
did you use school glue? would school glue work? does it make that much of a difference? any help would be greatly appreciated!
Mar 18, 2011. 5:44 PMtynow says:
on mine i used school glue for making the layers of cardboard, then gorilla glue for putting the pieces together
Mar 17, 2011. 5:48 PMtynow says:
great job, love the idea im making a small table with cardboard with a frosted glass top woth a light underneath to light up top any ideas where to get glass?
Feb 2, 2011. 5:50 AMrstackhouse says:
Are you cutting the cardboard with a band-saw?
Jan 27, 2011. 10:22 AMSpecies9 says:
I think I'll make a sofa bed
Jan 22, 2011. 8:22 AMarstudent4 says:
do you have any other methods of painting or waterprofing?
Dec 1, 2010. 11:49 PMWYN soldier says:
just what i call a perfect project in every aspects. keep it up!!
Oct 11, 2010. 10:00 PMfireguard says:
Is your varnish spray on or brush on, and do you think it makes a difference?
1-40 of 177next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
584
Author:Creativeman
Retired, doing art work now. Great. Have the time and the money to spend doing what I want to do.
