Make Your Own Biodiesel Processor
In a world where environmental awareness is becoming increasingly important for individuals, businesses, and mankind as a whole, it's always important to be looking for ways to re-use waste and cut carbon emissions. Biodiesel is a great way to do this. You're reusing waste oil and reducing your impact on the environment.
This Instructable will take you step-by-step through the process of making a BioDiesel processor. This type of Processor is called an appleseed processor. It uses an old (or new if you feel like dropping the money) water heater. The amount of fuel you can make will depend on the size tank you use. My first prototype uses a 10 gallon tank. Not too efficient if you plan on making large quantities, but great for figuring things out.
Before you do this project you should research the process and dangers involved in producing biodiesel at home.
Before you run out and buy $100+ worth of plumbing materials, I should say this: As biodiesel becomes more and more popular the resources available become more and more scarce, and people are starting to charge for things that used to be free, specifically Waste Vegetable Oil (WVO). I would suggest securing a source for WVO before you embark on this project.
There are many unspoken rules about gathering WVO from businesses, and I can talk about those in another instructable. For now just know that you CANNOT just take oil, for this you can get arrested and tried. You also need to be consistent (If you say you'll be there every Tuesday to pick up someone's oil and you show up on Wednesday half the time people will often give your oil to other people).
My instructable on how to use this processor can be found here.
Step 1Do some research
Do some research
Do some research. You can't read too much about biodiesel. I spent about a year researching before I built this and started making fuel.
A book that is a must read is Biodiesel Basics and Beyond: A Comprehensive Guide to Production and Use for the Home and Farm Much of the information you find on the internet (including this instructable, no doubt) is incomplete information. This book will give you the ins and outs of every step you need to take.
Be familiar with how the process works before you build a processor. If you understand how it's supposed to operate when it's finished, you will make fewer mistakes when you're building it.
96 comments
1-40 of 96next »
Jul 9, 2011. 9:03 PMaibarra1 says:
please I need to know how to use the processor ?
Mar 27, 2011. 8:05 AMMatt D655 says:
Bio-diesel is very useful. They even have bio-diesel heaters.
Jul 17, 2008. 8:09 AMMatt D655 says:
(removed by author or community request)
Mar 15, 2011. 7:09 AMPhantomOfHeat says:
It is possible but you should never try it. The only way it will work is if the car is to full temp and diesel is added it the tank but when it cools there is no chance of starting it till the tank and fuel lines have been drained and the fuel injectors are cleaned. (That all refers to dino-D but should be about the same.)
Do not try running any Diesel on a gas engine.
Sep 18, 2010. 5:48 AMowenaero says:
NO
Jan 24, 2010. 8:29 AMMT-LB says:
Before you try this, read about how diesel and gas engines work first. If you do want alternative fuel for your engine, try alcohol fuel or natural gas.
Jul 16, 2009. 2:28 PMnolanpoe says:
where do i get a water heater. is it assumed that i have an old one lying around. thanks, nolan
Mar 15, 2011. 7:00 AMPhantomOfHeat says:
As a reminder if using an old water heater I recomend filling and flushing the tanp several times to make sure that nothing that settled in the tank (hard water).
Mar 10, 2011. 9:25 AMcrashtestmonkey says:
You can use an old immersion heater or hack one out of an old kettle.
*BUT* they are way too hot for this application it will boil and brun the oil. You will need to step down the voltage to reduce the output. A 2KW kettle element @220V can be stepped down with a 110V transformer to 1KW.
Mar 10, 2011. 10:26 AMBytesmiths says:
BE CAREFUL about heating the oil! You need to keep the temperature below the boiling point of methanol (about 62C) or you will release a toxic cloud of methanol fumes!
Mar 10, 2011. 11:46 AMcrashtestmonkey says:
Oops! Forgot that slightly important bit of information!
I used a submersible thermostat on mine set to 60C about 2/3 of the way up the tank and a good flow around the element from the pump to prevent any overheating.
And of course, a very well ventilated area to work in.
Mar 15, 2011. 6:45 AMPhantomOfHeat says:
A tip if using a white board is to use wet-erase markers and not dry-erase markers. The reason is you will not rub the marker off and when you do clear it with a damp cloth it does not leave a residue that cant be removed (try removing dry-erase markers after it has been on it for a few days.)
Mar 11, 2011. 6:05 PMLaisseraller says:
Great Article! I like the stop and think first approach, I have purchased the Old School Black Boards from closing schools I can cut them into any size needed and put wood frames or metal frames I even have some felt errasors.
www.johnsartsandcrafts.com visit or send for more info.
Mar 11, 2011. 1:38 PMoilitright says:
I hope anyone who considers either biodiesel or SVO does some serious investigation into the availability of feed stock. The days of readily procurable waste oil from restaurants and other sources has for the most part disappeared. When biodiesel and WVO was pretty much unknown to the general public there was a lot more waste oil to be found for free. Now days there are so many companies paying for waste oil it is hard to come by. Unless you have a known secured source think very hard before proceeding.
As far as the WVO vs biodiesel argument goes, this too needs a thorough examination and understanding of the factors involved. Most importantly what kind of vehicle are you going to use it in as fuel. Where you live in relationship to weather and temperature is a factor. If you have a relatively new diesel vehicle you can pretty much forget about WVO unless you exert great effort in making sure you are doing it correctly, new diesel fuel systems are not at all tolerant and are hugely expensive to repair. But if you have an older diesel you are in a much better position to try WVO.
Biodiesel will be ok in newer vehicles again the fuel systems are expensive and can be cranky so unless you are confident your biodiesel meets fuel standards you risk disaster.
I have 20+ years experience with alternative fuels, live totally off the grid, run vehicles on both biodiesel and WVO, heat my shop and make hot water with waste motor oil and heat my house with wood and also use PV and solar for heating.
Mar 10, 2011. 4:13 PMhyoung says:
love this post. this is what instructables is all about. makes me wish i had all my cars converted to such fuel. We know there are soo many places that waste their oil. it would be such a lucrative self employment indeed.
kudos to the posting.
Mar 10, 2011. 2:29 PMmarcintosh says:
This is spot on thanks. I however have decided not to go this route. I'm headed to SVO land. In this place I'm not concerned about glycerine disposal, methanol and it's attendant issues (use storage recovery aquisition etc). I'm not concerned with burning anything down or blowing it up. My concerns are with filtration and moving it to and fro and storage.
Do not let me rain on your parade though. I'm certain that at one point or another I will become brave enough to move from SVO to BioD.
Thanks again
Mar 10, 2011. 10:49 AMBytesmiths says:
I've had very bad luck using the Harbor Freight "clear water pump" pictured here. I went through two of them before switching.
Problem is it is only rated for room temperature fluids.
I prefer a Taco or Grundfuss pump that is designed for hydronic heating systems. They cost about twice as much (~$80 vs ~$40), but they are designed for circulating hot liquids.
An added advantage is that these pumps are "flange mount," which means it is very simple to change them out -- although they don't ever need it! In contrast, the "theaded in" Harbor Freight pump causes you to disassemble almost everything to swap it out -- which was twice, in my case.
Jul 24, 2008. 4:56 PMEsmagamus says:
I suggest you put a low-pressure methanol recovery system there. I wouldn't want any unreacted methanol filling my garage or diesel tank with fumes. I can get you a schematic of a processor with methanol recovery, if you want to. Keep it green, keep it safe.
Mar 10, 2011. 10:37 AMBytesmiths says:
Since it is the biggest cost component of biodiesel, methanol recovery can be useful, but also consider that it makes your biodiesel "better" than commercial biodiesel.
In the winter, I purposely leave the methanol in the biodiesel and don't wash it. This allows me to run B100 down to about -7C, whereas commercial biodiesel is a solid brick at that temperature. You generally cannot use commercial biodiesel below about 3-5 degrees C, but just a bit of residual methanol lowers the cloud point significantly.
That said, in the summer, I do recover methanol. The beauty of an Appleseed design is that it can be pressurized with a vacuum pump. I then use an aluminum radiator with a fan for a heat exchanger to distill the methanol out.
But consider also the energy cost and time of doing this. I recover about 2 litres of methanol from a 120 litre batch. So that's a savings of $8 or so for hours of extra work.
Jul 24, 2008. 6:29 PMStevenArroyo says:
yo man whats up!!! i like how you made your bio-diesel processor here is a picture of my processor i make with my dad. i can make 20 gallons at a time!!!! i also have alot of good web-site's to help you with any problems you have i'll give you a web-site biodieselpictures.com they have alot of cool pic's all about bio-diesel
Mar 10, 2011. 10:30 AMBytesmiths says:
Be very careful with a poly processor. I have a friend in Mololla, Oregon, who burnt down his barn (and $20,000 worth of solar panels) when the processor heater melted the poly tank, which then ran out, causing the heating element to explode and ignite the biodiesel, which then ignited the methanol stored on site.
Thinks can get out of hand VERY QUICKLY! I strongly suggest avoiding the combination of plastic tanks and electric heating elements. You can use a poly tank processor ONLY if you use hydronic heating that well NEVER get hot enough to melt the tank!
Sep 10, 2009. 12:09 PMsarahfish says:
Do you have a parts list for this?
Aug 31, 2009. 10:31 AMjpaulstra says:
Steven, I like your system. Is it possible to obtain a step by step schematic of your entire processor? Thanks, Jim jpaulstra@hotmail.com
Sep 5, 2008. 8:26 PMdutchypoodle says:
I had an inkling that might be a problem. Think you could share the love my way, Esmagamus?
Mar 10, 2011. 9:52 AMdanfolkes says:
I had a REALLY good idea! :-D
Sep 21, 2010. 1:27 PMtysherman says:
I love the set-up, it looks somewhat mobile, which is what I'm trying to go for. The only question I have so far is, do you wash your biodiesel after it is finished in this particular processor? If so, may I ask what technique you've found is best for this task? Thanks!
Jun 6, 2008. 7:23 PMBiodiesel says:
Two other often-cited sources to stay away from are Josh Tickell's From The Fryer To The Fuel Tank (even worse than Kemp) and Journeytoforever.org
Jan 16, 2010. 12:36 PMJeremyA says:
What is wrong with journeytoforever? I have been using thier methods for years without any problems?
Feb 17, 2009. 3:20 AMproetus says:
hey dmc lemme be frank im bit new to this field of biodiesel...but read thro ur instructable ....wus actually curious 2 know in what way does this your bdp top the previously made ones.
Jan 22, 2009. 8:23 PMCAMACHO815 says:
NICE SETUP. CAN YOU ALSO WASH AND DRY IN THAT PROCESSOR?
Aug 17, 2008. 2:14 PMDerin says:
mazot var m1 ki biomazot yap1can?
Jul 25, 2008. 5:47 AMMetalron says:
men!what is the procedure in make the biodiesel you got there?
Jun 19, 2008. 1:53 PMkelleyboys4 says:
Congratulations and way to go DMC!!!!
Jun 6, 2008. 7:21 PMBiodiesel says:
For the love of God, do not buy Kemp's book, it's an overpriced underedited rant full of misinformation. Just as one example, his 'proper disposal' method is to pour glycerine on the roads- which most jurisdictions won't allow anyway, and he bases his chemistry recommendations on one set of lab tests done one time, which turned out a protocol that doesn't work most of the time to produce quality conversion fuel. His science is wrong in a lot of ways, he's just ripping off other people's work, he shows no evidence of having any real experience in making biodiesel, and he spends most of his time bashing the homebrew biodiesel community and setting up 'straw men' arguments for bad things he claims everyone else does. Here's the agreed-on-by-the-homebrewers set of good resources: www.biodieselcommunity.org (peer-reviewed site!) www.b100supply.com (has an excellent book on the subject and an even better 'library' of free information) www.biodiesel.infopop.cc (best forum on the subject, most info there is really good) www.graham-laming.com www.localb100.com/book.html
Jun 7, 2008. 8:57 PMforgesmith says:
Umm, dude, "Biodiesel" just signed up, the bio lists gender as robot, and the three comments here are all that they've made period. I've just done a lot of reading about Kemp and the book, seems he's irritated a lot of homebrewers, especially by criticizing about safety and waste disposal, with special mention to glycerine disposal which, curious enough, "Biodiesel" goes right to in the second sentence.
I think someone found this on a search and joined up only to bash Kemp, maybe one of the scores of disgruntled homebrewers offended from being told they are unsafe, wrong, and just not doing it as it should be. Well that and to mention resources recommended by "Real Homebrewers." You may be waiting a while for that reply.
Hey, I've been searching and everything I've found so far says the book is technically great and very informative, excellent reviews. You know you like it and it's worked for you. So...
Oh, hey, found this YouTube link in the search, Bill Kemp himself and the book, 1 min 23 sec. I'm on dial-up and that's like a half-hour of download time, so let me know if it's any good, alright?
1-40 of 96next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
119
Author:drinkmorecoffee
I live in a tent just outside of Port Au Prince, in Haiti. Ask me questions. I know the answers.
