Make Your Own LED Sign VU Meter
41,531
344
52
Published
Introduction: Make Your Own LED Sign VU Meter
About: Awesome Electronics Tutorials, Projects and How To´s
In this project I will show you how to create a custom LED sign that reacts to the loudness of your music, just like a VU meter does. Let's get started!
Step 1: Watch the Video!
The video gives you all information you need to build this project. But in the next steps you can find a parts list, schematic and reference pictures for your convenience.
Step 2: Order the Components!
Here is a list of all the parts you will need to recreate the project.
Amazon.com:
1x Stripboard: http://amzn.to/1q6WVz3
100x 5mm Green LED: http://amzn.to/1q6X3yr
1x Perfboard with copper dots: http://amzn.to/274wjQY
1x 3.5mm Audio Jack: http://amzn.to/274wv2p
1x DC Jack: http://amzn.to/1q6X999
2x LM324 OpAmp: http://amzn.to/1q6X9pK
1x 47µF Capacitor: http://amzn.to/1rAYQx7
1x 100kΩ Potentiometer: http://amzn.to/1OiIKgt
7x IRFD220 N-channel MOSFET: http://amzn.to/274wH1M
11x 10kΩ, 1x 47kΩ, 4x 1kΩ, 2x3.3kΩ, 3x 4.7kΩ, 2x 2kΩ, 1x 6.8kΩ, 1x 2.2kΩ, 1x 51kΩ Resistor: http://amzn.to/1OiIOws
1x 12V 2A Power Supply: http://amzn.to/1q6Xl8q
1x: Buck Converter: http://amzn.to/1rAYZ3t
Ebay:
1x Stripboard:-
100x 5mm Green LED: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x Perfboard with copper dots: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 3.5mm Audio Jack: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x DC Jack: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
2x LM324 OpAmp: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 47µF Capacitor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 100kΩ Potentiometer: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
7x IRFD220 N-channel MOSFET: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
11x 10kΩ, 1x 47kΩ, 4x 1kΩ, 2x3.3kΩ, 3x 4.7kΩ, 2x 2kΩ, 1x 6.8kΩ, 1x 2.2kΩ, 1x 51kΩ Resistor: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x 12V 2A Power Supply: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
1x: Buck Converter: http://rover.ebay.com/rover/1/711-53200-19255-0/1?...
Amazon.de:
1x Stripboard: http://amzn.to/1Ky7A8A
100x 5mm Green LED: http://amzn.to/1SW1GH4
1x Perfboard with copper dots: http://amzn.to/1WhVmwA
1x 3.5mm Audio Jack: http://amzn.to/1WhVr3q
1x DC Jack: http://amzn.to/1NtXgmx
2x LM324 OpAmp: http://amzn.to/1WhVsnX
1x 47µF Capacitor: http://amzn.to/1SW1Q1l
1x 100kΩ Potentiometer: http://amzn.to/1WhVJXY
7x IRFD220 N-channel MOSFET: http://amzn.to/1TwZeDp
11x 10kΩ, 1x 47kΩ, 4x 1kΩ, 2x3.3kΩ, 3x 4.7kΩ, 2x 2kΩ, 1x 6.8kΩ, 1x 2.2kΩ, 1x 51kΩ Resistor: http://amzn.to/1E9uEhN
1x 12V 2A Power Supply: http://amzn.to/1TwZhPB
1x: Buck Converter: http://amzn.to/1TwZi66
Step 3: Build the LED Sign and the Circuit!
Here you can find the schematic of the circuit and reference pictures. Use those to create your own circuit. The average time to make the LED Sign VU Meter should be around 4 to 5 hours if you do not face any problems.
Step 4: Success!
You did it! You just created your own LED Sign VU Meter!
Feel free to check out my YouTube channel for more awesome projects:
http://www.youtube.com/user/greatscottlab
You can also follow me on Facebook, Twitter and Google+ for news about upcoming projects and behind the scenes information:
https://twitter.com/GreatScottLab
https://www.facebook.com/greatscottlab
3 People Made This Project!
  • Woodworking Contest
    Woodworking Contest
  • Casting Contest
    Casting Contest
  • Oil Contest
    Oil Contest
2 Questions
Please can i have a clear schematics paper.Its all blur.
Hello,
I’ve assembeled this, following the schematic and pictures for reference, but alll my leds are lit all the time, whether an audio signal is connected or not. What have I done wrong?
Any help would be greatly appreciated!
Thank you :)
52 Comments
Clear picture of cricuit diagram
Is it possible to replace the IRFD220 MOSFETs with IRF540? Thanks
I decided to test the voltages before I connected the mosfets and the headphone jack has 8v coming out of it
Can any one tell me why a buck converter is used here
So that if the voltage is too high it won't destroy the leds
Did you watch the video?
Does anyone have the Eagle schematic file that i can have please? The link thats on here doesn't work. Thanks
Can u plz tell me the use of a comparator??
In the scematic u have used 8 lm324 but in the images u have shown there is only 2 lm324.Please help me.Thanks in advancefor ur reply.
Lm324 has 4 comparators.. so for 8 such comparators only 2 IC are needed... Check out the pin diagram of LM324
this is your best project with the worst explanation. You can barely see the schematics and you go really fast while soldering so no one can actually see what's going on...
I really don't quite understand what it means by 'Audio' with the little arrow pointing upwards in the circuit diagram. Where is that actually connecting to?
Any help would be appreciated! Thanks.
When I do that, the LEDs dont light up ?
have you checked all the connections and made sure everything is wired up right?
I'll get back to you on that tomorrow after trying different things haha, but this is what i have observed:
Instead of starting with Row7 (i.e. connecting the 1st op amp output to the "Row7"
configuration of resistors) I started with Row1 and connected the positive input to the output of the first opamp and that worked great. I went on to wiring up Row2 and found that when I connected the positive input for Row2's opamp to the output of the first opamp, the LEDs would simply not light up. However, when i connected Row2's opamp positive input to the output of Row1's opamp, they lit up fine. The only problem was there was hardly any difference between the rows brightnesses. I initially started with the row7 configuration although that yielded null results as well...
I'll get back to you with some pictures soon...
