Make a Speaker and Amplifier Without Complicated Electonics
313,330
568
64
Published
Introduction: Make a Speaker and Amplifier Without Complicated Electonics
About: I enjoy electronics and like to build things through whatever medium I need to in order to get to an end.
For a while now I have wanted to make an audio amplifier, but I haven't really had any good opportunities or means to the end. When I found out about the Mono Audio Amp Breakout from Sparkfun, I started to get exited. Its perfect for what I wanted. It's effective and soldering in the right wire is no more difficult than setting up a regular sound system. Not to mention how great it looks in that laser cut mirrored acrylic case. Enough Talk. What does it sound like?
Step 1: Materials and Tools
Hardware
1 USB  micro jack
2 Potentiometers, not logarithmic, mine are logarithmic and there is a narrow range of control now
2 Mono Audio Amp Breakout Boards
Solder
1 Switch
1 3.5 mm jack
Wire
8 bolts and nuts of appropriate sizes
Tools(This is what I used, you could probably get away with less)
Soldering Iron
Drill
JB weld
Sand paper
Helping hands are practically a necessity, but if you are dextrus enough you might slide by without them
Chisel and hammer, Theses come in really handy when I find out my laser cut design wast good enough, which is often.
Step 2: Design.
There is a great Google Sketchup Plugin by flightsofideas which makes an SVG file from 3D designs in Google sketchup. You can find the Instructable here
Anyway, I designed how I wanted the box to be using sketchup and then transferred the faces to an SVG file and put them on the Ponoko P2 laser cutting template.
Step 3: Prepare the Laser Cut Acrylic
I got it the acrylic laser cut at Ponoko. After it came I removed it from its protective layers and tested them for fit.
Step 4: Soldering Most of It
I connect a wire running from the ground wire on the USB jack to the ground pins of the mono Amp and the negative pin of the switch. Don't forget to put the switch through the hole before soldering.
Next I connected the positive voltage to the opposite end of switch.
I then connected the potentiometers to the appropriate holes on the mono amps, that is either edge pin to either edge hole, and the middle pin to the middle hole.
I connected the pins of the audio jack to the appropriated pins of the mono amps. That is the pin the pin with the hole is the negative wire, and the two pins that comes up and bends are positive (look at the pictures for help). Connect the different positive pins to different mono amps but connect the negative pin to both.
I fed the speaker wires through both of the holes, and then soldered them into the audio out pins.
Makes sure everything is connected and makes sense.
We are ready to test!
Step 5: Test 1
Check everything one more time, than plug the USB into a computer USB port and the speaker into a speaker output. Look for a headphones output. Then play some audio!
Step 6: Shrinkify
And now, because I have A LOT of extra wire, I needed to get less of it to fit it inside the box, so I cut the wire in two places, striped it, twisted it together and soldered. Then I covered it with electrical tape to keep it from shorting out. Repeat for all the long wires.
Step 7: Second Test
And now, another test of the speakers before it it all put together.
Step 8: Adjust and Glue
There are little pins on the potentiometers that keep them from spinning behind the acrylic. I put them into the appropriate laser cut holes and where the pin hit the acrylic, I made a mark with a sharpie. Then I drilled part of the way into the acrylic from the back, and tested it to make sure it fit.
Then I cut some necessary slots for the USB, and drilled partway from the front into the audio jack hole, this is for the little provided bolt. Be sure to drill in far enough or else the jack wont go in all the way, but not to far, or else it is much harder to affix to the acrylic.
Now start gluing! only glue the USB, audio jack and on/off jack. I used JB weld for all the parts going into the hole, and then I used hot glue for putting the box together. When there is one side left, put glue on the joints and push them together. After the glue dries, use a hobby knife to clean it up. When both boxes are glued, put glue on the side of the smaller box with the hole and push it onto the bigger box so that the holes of the speaker wires line up.
Step 9: Make It Look Nice.
If the light on the switch doesn't work 100 percent of the time (like with mine) you can put Sugru on the switch. Changes are you probably have some extra Sugru. May I suggest mending your 100% penguin Sugru phone case, or a wire holder.
Now time for a cable holder. Make some holes at each corner, and a trapezoid piece from the top. Then cut some slits into the holes. look at the pictures to see how to use it.
Step 10: Done!
now enjoy the marvelous awesomeness of the speaker!
  • Clocks Contest
    Clocks Contest
  • Woodworking Contest
    Woodworking Contest
  • Casting Contest
    Casting Contest
64 Comments
Will it work with 8ohm 10wat speakers?
can you add more watts and speakers.but the ohms will be the same right.8ohms
i want to 5 speakers with bass
can i build them
yes Fahad you can make but u can make your amp with lm386 ic and it gives 10w power at 12v dc. circuit diagram build yourr own
I got a tda 7784 can i make an amp
Of course u can build it. But u have to use high powered amplifier and it is better to use stereo amplifier to mono..
I got tda 7784 can i make an amp for my phone
how to make the board, i have speakers taken from an old radio (2big and 2 small radio has treble,bass,and one other thing) so how can i make a speaker set out of it which i can connect my mobile
how about if i dont have a matherboard
Where did you buy that mono amp breakout board from because i have searched many sites online and cant seem to find the same one or one that has as many inputs/outputs as yours
Hello, I was wondering if you had a link to the sketch-up design, or details on how to make it. I will get the plugin for Ponoko, but I don't know how to recreate the design.
Nice 'ible, I'm using it as inspiration for a school project!
The link is to a stereo 2.8W Amplifier breakout
thanks for the link I will buy this soon
BRAVO.... I've been wanting to build one for my car for a few years now but I lack the knowledge of electronic components to do so... hints this question I'm about to a ask....lol... I'm trying to add a remote bass knob to my amp that was soupossed to just plug in via a phone jack...but my amp lacks the jack... I want to replace the potentiometer on the amp with a phone jack, any chance you could be of any assistance if you have the time?
for future reference, you would get more bass and better sound out of it if you cut a vent about 1-1.5" circle in the back.
Thanks! I'll remember that.
I Like Your instructable, but I was wondering if there was something like this for a higher powered boombox?
