Step 5Testing and final assembly
Now press the entire assembly into the backplate assembly- note the orientation, making sure everything is aligned correctly. If the fit is really loose, you can put a couple dabs of glue between the wrapped copper wire sections and the backplate to hold everything together.
That's it! Now go finish your Iron Man armor suit...... :)
I have a niche for making things simpler to do. I'll let you know how it goes.
We also have a lathe too, I will make that outer ring out of aluminum like you said you wanted to do.
I am absolutely giddy about this project,
You could get everything from those places except the surface mount LEDs and the plastic materials.
http://www.cablesandconnectors.com/30000-30.HTM
I just got some from them and they shipped super fast. You might want to contact them to make sure they're in stock before ordering.
