I've wanted to make my own embossed business cards since I was handed a really incredible one at a fancy restaurant. I tried several methods of achieving the effect (photoemulsion, electrolytic etching) but ended up having the most success with a pretty simple and straightforward acid etch method similar to the one used in home printed circuit boards. I still have to work out a few kinks (such as flattening the paper after the emboss without distortion, or reorganizing the method to print before embossing) but I hope you can take something useful from my experiments, and apply it to your own projects.
Remove these ads by
Signing UpStep 1Planning
Access to a laser-jet printer
Ferric Chloride (available here)
An Iron (with all the water emptied, please)
A meticulously clean brass plate (big enough to cover the space you want etched with room for more)
Heavy, thick paper. Card stock will do nicely, but heavy rag paper from art supply stores works well, too.
A clamping jig to align your sheets each time you use it. I used plywood with brass elbows and PTEG plastic sheet (to keep the paper nice and flat against the clamping jig), but it's up to your expertise.
6 or more C-clamps.
Shiny laser jet paper.
A plastic bus bin, or other wide plastic container for the acid etch.
A spray bottle.
My concept was to emboss a sheet of paper, and then run it through a printer to color the page. I'd then cut the cards out. On review I'd have changed some things, but got some cool results, regardless.
Begin by designing the pattern that you want embossed in the sheet. Remember that what is embossed onto the card is the mirror image of what is etched on the plate. So if your pattern reads properly on the brass, it will be backwards on the card. The same applies to the relief. If your logo is raised on the brass, it will be inset in your card. Design it in sharp black and white. If you want gradated patterns, consider going with a halftone pattern.
Thanks for this! I'd never heard of the process you used with the printer. It sounds like it could make things move quickly when you don't need the artist's hand for part of the process.
it is great, but cant download the PDF. pls re link.hardly waiting
and also, a question, do u have a solution to make my logo punch or emboss on a plastic/fiber sheet surface??
hardly waiting
shi
I bought some etching solution from radio shack ages ago to "play" with metal- quotes etc for jewelry- haven't gotten to it yet, now I feel inspired.
I wonder if a flower press would work- for those of us who don't want to make the press- they are usually ppretty inexpensive- or- a tshirt printer press- if you can find one cheap.
but what I'm thinking might work really well for the ironing part of this - and sometimes you can find them at a thrift store where I found mine is a home size ironing press like the dry cleaners use- seems like it might work really well- I haven't even used mine yet so I don't know how long you can leave the thing in there.
you can try ebay- they do have them new= plus, if it works you could make a second plate and do twice as many at the same time. If you were going to do this for other art projects it might be worth the investment. If I ever get mine going and try this- and it works- I'll email you with a pic.
Again, great instructable, thanks for the inspiration.
Try this method instead:
http://www.nontoxicprint.com/etchzincsteelaluminum.htm
You can get cupric sulphate here:
http://secure.sciencecompany.com/Cupric-Copper-Sulfate-Crystal-500g--P6367C670.aspx
standardized way of measuring weight than pounds, as the amount of paper being measured by the pound scale is different for different types of paper.
As weight is effected by thickness, finish, density, and amount of fillers, it is surprisingly difficult to use as a single judge of a paper. I prefer to give multiple numbers if possible, such as:
Brightness: normally a number between 92 and 102 that refers to the amount of optical brighteners and "clay" in the paper.
Thickness: normally given in mils, 10mil -12 mil is the standard business card weight range... 8-10 mil is inkjet card paper 12 mil is thermographic card stock (Nice!!)
Weight: preferably in g/m2
However, if you really want to get to know your paper, go to the mill, grab some headstock, run it through a Canadian Standard Freeness Tester (there will be one in the lab), and do a test burn to check "clay" content. Then, stop by the Machine Tender's booth to check dryer temperature and pressure. Finally, ask the Machine Tender how recently they changed their felt, and how many splices they ran the night before. Then, and only then, do you JUST FEEL THE DANG STUFF FOR YOURSELF.
Unfortunately, even with ALL the numbers, with most paper, you need to just try it out... ask if they have samples at the store, or if they use it in the print shop (for one stop office supply stores like Staples). if you are looking to cut the page, ask if you can cut a sample to size. an 8.5"x11" sheet of card stock feels VERY different than a 3.5"x2" business card made from it.
By the way, I use a lot of paper ;)
http://www.caswellplating.com/kits/index.html Sells kits for this.
