I have included here a small sample of these recipes -- but I'd like to reassure the folks at Gorilla glue: although really fun to make, these glues won't cut into your market share. Commercial glue still beats the homemade variety for convenience, strength and even cost -- with the possible exception of step #1, paper paste for large scale collage projects.
(*) boil deer hooves and antlers with some lime in rain water for a couple days, apply hot.
Remove these ads by
Signing UpStep 1Traditional paper paste
Ingredients:
1/3 cup wheat flour
2 tbsp sugar
1 cup water
1/2 tsp alum powder (optional preservative -- not necessary if the glue is for immediate use)
Mix flour and sugar. Gradually add water while stirring vigorously to prevent lumps.
Cook over low heat, stirring constantly, till the paste is clear. Remove from heat and stir in the optional alum.
Spread over paper or cardboard with a paintbrush. Press and smooth paper to be glued before the paste dries.
Store in a covered glass jar. This will keep for several weeks without rerigeration.
Badartworld.com
Great info and find ~ thank you!!
I have some questions about this snail glue:
1. is it biodegradable?
2. can I put it in my compost?
3. does it glue wood?
4. is it poisonous to humans once set?
5. if i constantly run water over it will it degrade?
6. if it degrades from water and agitation, is it poisonous?
Thanks you for your replies to my questions
Clive
How often do those carefully planned smarties fall out?
Hide glue works by dehydration. As the water in it evaporates it pulls whatever it's sticking to together. If you rehydrate it, obviously it will fall apart again. Of course in most cases it will need to soak a while, or be steamed, which is likely what happened to the coffee mug if it wasn't the milk.
Is that strong enough for water resistance?
On the other hand, heating up this glue softens it, so it follows logically that it's the heat which made the cup fall apart. Of course water might have contributed to weakening it, but my guess is it would come apart in the microwave oven too. Next time I break a mug I'll test that theory.
Of course if the sealer isn't cracked, by all means, have at it.
I was looking for a very low strength adhesive to attach plastic on plastic. It should be something like with 3M sticky notes that come off without damaging the paper. Maybe that book has something...
