Create your own Makedo Cardboard Christmas tree these holidays. All you have to do is download the template file available here on instructables and g...
Referencing from the downloaded template, measure and cut out the cardboard triangles. You should have a total of 16 triangle panels. Use the Makedo s...
Fold in the flaps below so they overlap one another. Connect the four corners together to complete the triangular module. Altogether there should be 4...
Position the triangle modules on top of one another starting with one of the medium sized ones on the bottom. Follow with the largest, the medium and ...
Your Makedo Christmas tree is complete! Decorate with reclaimed material ornaments as you wish. Makedo ornament instructions are also available on our...
Stop motion video of the Makedo Christmas tree at Makedo HQ!
Create your own Makedo Cardboard Christmas tree these holidays. All you have to do is download the template file available here on instructables and go to mymakedo.com for a Makedo KIT for THREE.
Step 1: Makedo Christmas tree template!
Download this template file to start making your Makedo Christmas tree. :)
Referencing from the downloaded template, measure and cut out the cardboard triangles. You should have a total of 16 triangle panels. Use the Makedo safe-saw to punch holes in each triangle panel as shown in the template.
Step 3: Score
Where the perforated line is illustrated in the template, lightly score the cardboard with the tip end of the safe-saw.
Step 4: Fold
Fold along the creased line. Repeat steps 1-3 for the remaining triangular panels.
Step 5: Build
Each module consists of 4 identical triangle panels. Begin by overlaying the creased fold over the edge of the second panel. Align the holes.
Step 6: Connect
Connect using Makedo repins and reclips. Continue this process to connect the remaining two triangles to form a tetrahedron.
Step 7: Build
Fold in the flaps below so they overlap one another. Connect the four corners together to complete the triangular module. Altogether there should be 4 modules. 1 x small, 2 x medium and 1 x large.
Step 8: Build
Position the triangle modules on top of one another starting with one of the medium sized ones on the bottom. Follow with the largest, the medium and the smallest on top.
Step 9: Complete
Your Makedo Christmas tree is complete! Decorate with reclaimed material ornaments as you wish. Makedo ornament instructions are also available on our website. Share and upload your creation to mymakedo.com
Step 10: Makedo Christmas tree in the making
une très bonne idée : merci pour le partage !... je cherche des freebies sur le web, mais je recherche aussi des créations "faciles" : mon but est de permettre aux gens qui n'ont pas beaucoup d'argent, ou qui débutent le bricolage, de créer des choses simples, ne demandant pas d'outils "exceptionnels" ni trop de matériel, et ce sapin est parfait pour cela... lorsque je trouve des choses qui me plaisent, je partage mes "bonnes adresses" : la vôtre y sera !... http://pinterest.com/lemondedis/ (j'ai déjà plus de 12000 liens vers des téléchargements gratuits et quelques autres milliers vers des projets de création !)
Merci beaucoup. Excuse my french, it is terrible. Thank you for your kind words. Yes, we also love making projects that are accessible and easy for people to make out of everyday materials, often things found around the home. We're on pinterest too. Check it out sometime http://pinterest.com/makedo
I have tried for 30 minutes to buy this somewhere--anywhere online and it isn't available. Is there a reason or a place I can go? I've gone directly to the makedo.com site, amazon and wherever else google would take me.
That's great that you are so keen! The idea is that you find your own materials locally, close to your home. It may be cardboard boxes or sheets, reclaimed packaging or even old advertising panels. You can then make your own tree following these instructions along with Makedo parts to connect it all together. We suggest using the Makedo Kit for Three for this creation.
Thanks! We do too, though we made some decorative baubles too (for any tree) using coloured bottle caps, coffee cups and cup cake liners, will have to share that also soon.
I love the concept behind makedo! What a brilliant way to tap people's imaginations & repurpose ubiquitous "waste" materials at the same time. Great design all the way down to the packaging. Me likey :).
Absolutely love this instructalbe. Great way to recycle cardboard. Great way to have a "tree" and then be able to store it flat, or send to the recycle bin at the end of the season. Thanks for the template and great pictures.
I just did the calculation and you need 13400mm of cardboard! whoa!
that aside... it is a great idea! I love it and will be making one.. i will post pics once done.
I just need to know what scale the paper is to be printed at? becuase this is of epic proportions one would need to print it out on several A1 sheets or break it up.
...or you could provide us with a scale perhaps?
I will probably be projecting the image via video projector across the room on to some cardboard roll until the scale is correct.... then trace a template... rinse and repeat on the floor until all are traced..
Hello! Love the enthusiam! :) The size of the template is scaled at 10% of original size. The easiest method of execution which we followed was to measure and draw out each individual triangle and cut them out. Then simply using these triangles as a tracing template for the remaining triangle panels required.
I could see spray painting it three shades of green, and decorating it with greeting cards from the previous year with space for the new ones this year.
One question: Why is the size from the smallest to the medium only increased by 125mm, when it's increased to 225 from the medium to the large? The final tree looked out of proportion to me, and I looked back at the pattern and the heights were 450mm, 675mm and 900mm. Perhaps 850mm would make it look more gradual.
Hello, Makedo is all about creative play and endless possibilities. This instructable is simply a guide so feel free to adjust it anyway you want. Can't wait to see the final result. :)
Hi! We are called makedo as in "make do" in English but many people read it as makedo in Japanese. The way people read it has aways intrigued us and we don't mind at all at how it is pronounced. :)
PDF Downloads As a Pro member, you will gain access to download any Instructable in the PDF format.
You also have the ability to customize your PDF download.
It's a table-top version of the coolest DIY tree in town.
Thanks to Makedo for saving Christmas
We can't wait to see the images you post. :)
Cool idea!
Cheers! :)
Site
