You can read about the Tzolkin Mayan calendar on Wikipedia http://en.wikipedia.org/wiki/Tzolk%27in. It is one of several calendars, and consists of 13 numbers and 20 day signs which appear in 260 combinations that rotate. In other words, with every change of the day the numer increases from 1 to 13 and then back to 1 again. Similarly the 20 day signs rotate.
What I needed was a frame and face with the numbers and day signs on it, which I modeled on the Sleek World Clock, and relied on scottbez1's great instructions on printing the face and making the actual calendar. The electronics are Arduino and I put the code together from bits and pieces to take the date from an RTC, calculate the Julian Date and then work out where in the two Tzolkin rotation that day falls. LED's are controlled via a shift register.
This is my first ever Arduino project - a testament to the great ease of use of this amazing technology!
Remove these ads by
Signing UpStep 1: Assembling the Electronics on the breadboard for testing
18 white, 5 red, 5 blue, 5 yellow LEDs (www.sparkfun.com SuperBright $0.50 each when bought in packs of 100) - $17
33 Resistors 330 Ohm 1/6th Watt - $2
1 Arduino Uno - R3 board www.sparkfun.com - $30
1 Real Time Clock Module DS1307 BOB-00099 www.sparkfun.com - $15
5 Shift Register 8-Bit - 74HC595 www.sparkfun.com - $7
1 Wall Adapter Power Supply - 9VDC 650mA www.sparkfun.com - $6
2 printed transparencies (see attached pdf on Step 2) - $1
Total cost: $88
Also: prototyping breadboards, prototyping leads, wire etc
Cardboard and other household items
Total cost: around $44 (using standalone ATMega168) or $67 (if you buy a full Arduino)
Visit Our Store »
Go Pro Today »
In addition to the Tzolk'in (agricultural?) cycle, I guess that this could be expanded to include the Haab' (365-day solar year) cycle, and even a long-count (essentially, Julian number :-) index.
The Haab' would probably be most easily done with a separate, second construction, with an appropriate display panel.
The Long Count is much simpler computationally, using the Julian date with an offset for the Mayan epoch (something in 3114 BC, as I recall), and then just doing a series of modulo-20 and modulo-18 calculations. The display (with at least five digit positions) would probably have to be done differently, either with servos rotating the glyphs into position, or with maybe multi-pixel displays.
In any event, this sounds like it was a lot of fun for you, and tied learning a new set of skills to something in which you were already interested. Congratulations!
http://arduino.cc/forum/index.php?topic=94925.0
You will see the exact code I used there, a little lower down.
I looked at the Wikipedia page, but the math was too challenging for me ;-(
For my purposes it may not be that critical to get the exact correct date, as the ultimate goal is to use Julian Date to calculate the Tzolkin state.
Oliver
