Remove these ads by
Signing UpStep 1Making wicks
The salt keeps the paper from burning too fast. Also the salted paper wicking is stiff so it doesn't need wire to stand up. This property is useful for the candles and oil lamps described in the following steps. Actually any kind of wicking, like wick cut from a cotton towel will burn best if it is salted which retards charring. Just something useful to know if you are making any other types of instructables oil lamps. Presently the other lamps featured on instructables.com don't work well because they don't salt their wicks.
1. Wet some cheap copy paper with some very salty water or pour salt over the wet paper in a tray.
2. Fold and cut the paper into strips then twist or roll the paper.
3. Dry in an oven at 200F for 20 minutes or air dry overnight.
Here is picture of a tray of paper wicks made from one sheet of cheap copy paper.
[img]http://i7.tinypic.com/87mpudd.jpg[/img]
TY very much!! I'm having the same problem...the oil lamp burns like it's supposed to for about 10 - 15 seconds then goes out.
Now that I know it's the oil, I know how to fix the problem. :)
Q:
would a fiberglass wick do better in an oil lamp than a cotton wick?
If fiberglass wicks will work better, I'll toss the cotton wicks in a New York Minute.
Now I'll just have to keep my eyes open for more jars or cheap glass cups.
I used a Kerr jelly jar.
Punched a small hole in the center of the metal candle holder, twisted in my
salted paper wick, floated it on top of the oil and waited for it to absorb the oil. Took it out with a needlenose pliers, lit it while holding with the pliers, and put back in the oil.
The wick was about 1/8 above the metal and the extended about an inch
below it, into the oil.
It also explains the popularity of kerosene lamps. The kerosene is thinner, and will "go up" a wick a further distance. Thus using all the fuel before needing to be refilled.
any suggestions? could i be over salting (sometimes there are little bits of salt deposit on the wick)? is cotton twine too dense (paper occasionally works better, but not always)?
