Today, the surplus firearms market is saturated with these firearms, which are typically on display by the case at local gun stores. Their caliber (close to .308) allows them to be used for cheap hunting rifles, and they are pretty accurate, reliable, and tough.
The challenge with these firearms is that the 3/8 sight rail is a bit anemic for mounting a scope. A common problem with them is for the sight ring screws to loosen up after a few rounds (even with locktite).
This instructable documents my 3rd (yes third) adventure in mounting a scope to my Mosin Nagant M91/30.
Note: This documents me making permanent modifications to a firearm. I am NOT a professional gunsmith and am not responsible in any way if you make modifications to your firearms. If you are not comfortable with the modifications in this instructable either structurally or for retaining historical value...don't do it! If you perform this modification...IT'S ON YOU !
Remove these ads by
Signing UpStep 1Required hardware
(4) Metric #4-.70x12 Cap Screws
(4) Metric #4 Wave Lock Washers
(4) Metric #4 Split Lock Washers
(2) 10-32x1/4 Set Screw
(1) 1/16 Allen Wrench (or whatever fits the set screw).
(1) Tube of locktite.
(1) 10-32 tap
(1) #21 Drill bit
(1) pair of medium height 3/8 dovetail scope rings (I used the cheap NCStar ones off Amazon).
With the sight rings, but not including the scope, I have about $15 in the mod.
Neat 'ible though, Locktite is very useful!
most rimfire mounts lack any real holding power even on the intended gun the use of set screws is a old gunsmith kink. PS I think it is great you did not use the worthless rear sight mounts.
Ironically, I've recently purchased an M44 (carbine version of a 91/30) and fit it with the ATI rear sight mount, subsequently putting about 20 rounds through it. The accuracy was astounding (using a Russian VOMZ scope) and I prefer shooting through it rather than the 91/30. The sighting for the scope mounted over the bolt feels more sure of itself. I'm looking forward to fall deer season with this gun.
