Introduction: Marshmallow Revolver & Speedloader
Recently, I have become obsessed with the mechanics of old-school revolvers, and PVC marshmallow guns. eventually, I decided to marry the two, and the Marshmallow Revolver was born! It boasts a yoke/cylinder assembly that swings out for reloads just like an authentic revolver that can be disassembled. Also, it has a long range, and is very accurate.
I have also included an instructional segment detailing how to build a speedloader for your finished revolver (quick 'mallow reloads). If you have any suggestions or questions, be sure to drop them in the comments section!
I have included a Google Sketchup file I created for any additional visualization needed. (I know, not exactly Autocad, but it can be useful to make a quick visualization of something in a pinch.)
Step 1: What You Need
- Hand Drill
- Assorted Drill Bits
- Wood Saw
- Coping Saw
- Wood File
MATERIALS
- Scrap Wood
- 2 inch PVC coupling
- 1/2 Inch PVC pipe
- Various wooden dowels
- super glue
- wood glue
Step 2: Building the Cylinder
1. cut 4 lengths of the PVC pipe to match the height of the 2 inch coupling.
2. slide all 4 lengths into the coupling, filing down the edges if you have to.
3. sand both sides of the cylinder to a smooth finish.
4. slide a ~5 inch wooden dowel into the junction of the 4 PVC pipes, this should be a very tight squeeze.
No adhesive whatsoever needs to be used in these steps! everything is just tightly packed in.
Step 3: Cutting the Frame
1. cut out a 2 and 3/4 by 3 and 1/4 piece of 3/4 wood.
2. cut out a 1 and 1/2 by 2 and 1/2 rectangular hole in the center, big enough to house the cylinder. to do this, I first drew out where the rectangular hole would go, drilled a hole in the middle of it, and then fed the blade of my coping saw through the hole and cut away to the line.
Step 4: The Barrel
1. Cut a ~6 and 1/2 inch length of the 1/2 inch pipe
2. cut away 1/2 of the pipe lengthwise starting at one end and going in ~ 2 and 1/2 inches
3. cut out a ~7 inch length of PVC pipe
4. glue the 1/2 inch pipe underneath the PVC pipe with superglue as shown in the picture.
Step 5: Creating the Yoke
1. cut a ~3/8ths dowel 1/2 of an inch
2. drill a hole through the center of this with a drill bit the same size as the PVC cylinders dowel. you have now created the eyelet.
3. glue a small piece of wood to one end of this eyelet, as shown in the picture.
4. cut a 1 and 3/8th by 1/2 inch piece of wood from ~3/16th plywood.
5.glue this piece to the eyelet as shown, onto the piece added on in step 3.
6. glue a 2 and 1/2 inch length of a ~3/16th inch dowel onto the plywood, as shown. (the dowel should be the correct size to fit into the housing of a household pen)
Step 6: Attaching the Yoke/Cylinder to the Frame
Finally, it is time to take the cylinder and yoke that we have built and establish them on the wood frame.
1. slide the cylinder into the yoke as shown
2. cut out a section on the left side of the frame to fit the eyelet of the yoke. test it! to do this, drill a hole at the midway point, then cut away to the frames edge with a woodsaw. look at the picture for details.
3. superglue a 2 inch length of a pen housing to the bottom of the frame, as shown.
4. slide the yoke/cylinder into the pen housing via the dowel on the bottom of the yoke.
5. the cylinder should now swing in and out of the frame. If it's working; hooray! if not, double check the measurements of all of the components, and make sure all of the joints are oriented correctly.
Step 7: Carving the Handle
At this point in assembly, we can finally take those woodcarving skills we learned in boy scouts to good use and create a wooden handle for the 'mallow gun. Go all out here, folks! For mine, I essentially used a round file to carve finger cavities into a 3 and 1/2 inch long piece of wood.
If you really don't want to attach a wooden handle, a piece of PVC pipe could be substituted.
this handle will be attaching to a vertical side of the frame, so make sure to cut out a flat place where it will meet the frame. if you want different handle orientation/angling, try cutting out the flat part at varying degrees.
Step 8: Gluing in the Handle and Barrel
Finally, It's time to unite all of the different bits that we've been assembling!
1. Begin by gluing the handle on to the side of the frame. (easy enough- right?)
2. mark a dot on the left side of the frame (the business end, where the barrel will go) to precisely align with the center of a chamber in the cylinder rotated to the top.
3. drill a hole through this dot with a drill bit the size of the PVC. this should be wider than the frame is, so make sure the frame is clamped when drilling.
4. slide the barrel into this new hole, and simultaneously the 1/2 inch pipe on the bottom should slide over the 'extractor rod', the cylinders dowel.
5. test the cylinders ability to rotate and slide open and closed. when everything is aligned correctly, glue the barrel in!
Step 9: Adding the Blow Tube
It's time to finish our marshmallow gun by adding the blow tube!
1. cut a piece of PVC pipe about 5 inches
2. cut a hole identical to the one cut in step 8 for the barrel, but this time for the blow tube.
3. slide the blow tube in, and when everything is aligned, glue it in!
4. cap it off with a 45 degree attachment to blow into.
Your marshmallow revolver is now completed - hooray! Now to reenact all of your favorite John Wayne or walking dead scenes.
To really spruce this up, I suggest staining the wood of the handle and frame. unfortunately, I did not have enough time to do this yet because of the deadline for entries in the zombie contest, but it's something I will definitely do in the future.
- Next step: on to the speed loader! -
Step 10: Building the Speedloader
It can be cumbersome to load bullets one by one into the cylinder, and in the heat of battle one can't waste those precious extra seconds. Fortunately, there is a Speedloader that can load all 4 marshmallows at once!
1. drill out a 2 inch diameter circle from a piece of thin plywood.
2. trace all four chambers on to one side of this circle.
3. using a coping saw, cut these circles as shown in the picture.
4. cut 4 lengths of index card to the right width , and slide these through the circular cavities.
5. staple all four ends of the index card segments together on the far end.
the speedloader is now completed! to use, place a marshmallow into each index card section as shown, slide the 'mallow end into the open cylinder, hold on to the wooden circle and pull the index card segments out! the marshmallows should be safely inside of the cylinder.
Step 11: Some Thoughts
Overall, I am satisfied with this project, although I did encounter several problems.
- I went through 3 different frames I cut out - I kept accidentally breaking them!
- I had to re - glue the barrel on numerous occasions, as it kept becoming misaligned with the cylinder
- I ran out of superglue about 3/4 of the way through - and had to substitute hot glue. it wasn't pretty, and didn't hold well at all.
- when I had finished the gun, my first tests were a failure- the barrel was slightly higher than the cylinder chambers! I had to file the edges of the barrel where it meets the cylinder chambers so that It would fire.
- I went through 3 different speedloader designs- all failed but my final one (marshmallows are sticky!)
If you enjoyed this instructable, or have any suggestions or responses, make sure to leave a comment below. Also, I would love to see how yours came out, so post a picture in the comments!
-MU5ICI4N
Second Prize in the
Toy Contest
Craft Contest
Epilog Challenge V
Zombie Contest
