loading
Step 1: Broken Wheel Bushing
Here's the wheel, broken wheel bushing, and a working one showing how it normally attaches. The crack you see here is the same way the others previously broke.
It is more beneficial to have the wheels spin, just replace the hubs, use the same wheels, go to <a rel="nofollow" href="http://www.maytagwheelhubs.com">http://www.maytagwheelhubs.com</a> to get a kit of four stainless steel screws, washers and hubs for around 40 bucks or you can buy a new top rack for 140 bucks but will one day have the same problem.<br/>
<p><a href="http://www.maytabwheelhubs.com" rel="nofollow">www.maytabwheelhubs.com</a> is a fake url and they are trying to hack your computer. What a jerk.</p>
<p>This is a fake url and the jerk is trying to hack your computer.</p>
I have to chime in on the stainless steel kit. IMHO, it is the only way to go. I after hack-replacing 3 of my 4 rollers a described above, the dish tray didn't roll freely. Install the stainless hubs from http://www.maytagwheelhubs.com/ and everything rolls smoothly. It's worth the $40 to never have to deal with this again.
Yes I did some hacking too with drawer pulls before finding a simple long lasting fix. Why waste your time, just do it right and then you will have more time for fishing. lol
I have found what I consider to be a better solution for the Maytag dishwasher wheel repair. It allows the wheels to spin. I purchased 10ea 32x3/4" machine screws and 10 ea #10 zinc washers. This is enough to replace all 5 wheel hubs. I placed a washer in the cut out on the wheel(outer edge), put a screw through that with the head outward. I then placed a nut on the end of the screw and tightened until it was nearly flush with the shaft of the wheel. I placed the wheel on the rack and put another washer/ nut on the screw. When tightened, the 2 nuts compress on each other, allowing some wheel movement. The alignment from out to in is: screw- washer- wheel- nut- rack- washer- nut All for under $3. Good luck!
That's a great site! Thanks!
These parts work for me. I cut some tubing to act as a bushing
I got mine fixed in with 2 pieces from Ace Hardware - <br>1. is a Zinc Screw Post - 1/2 Inch post - Fits 1/4/ inch hole - includes a 10-24 X 5/16 inch male screw. Its basically a threaded tube with a screw head welded on one end and a regular screw fits into the other end.<br><br>2. I combined this with a nylon flange spacer - its a half inch long and had has a flange on one end that just fit into the wheel recess. Inside diameter is 1/4 inch and the out side fits the wheel hole just a hair loose. <br><br>Just slide the spacer into the recess of the wheel and the post into it. The screw that comes with it just fits through the hole in the rail on the basket - make it tight. <br>Also, in case you didn't notice, the plastic pieces in the rail ends that hold the basket into rail can be removed by pushing the head of the plug toward the basket and it will come right out of the rail and the basket slides right out.<br>Hope this help. I'll answer questions at rick@backcountryhikingclub.org - good luck.
I used rickinphx's fix using a zinc screw post and a nylon flange. Wow, easy as can be, and appears to be solid. I spent $1.10 on the hardware to fix one wheel hub. I bought three more sets, to fix future broken hubs. <br> <br>Thanks, rick!!
Just completed cjp96's fix...total cost $3.75!!!&nbsp; Woo-hoo!!<br> <br> Question though - my alignment out to in is: screw- washer- wheel- nut- rack- nut.<br> <br> Cjp's alignment out to in is: screw- washer- wheel- nut- rack-<strong> washer</strong>- nut.<br> <br> When I tried it with the last washer that Cjp has, the wheel doesn't spin.&nbsp; Is that last washer really necessary?
I just did an even simpler hack, though ymmv. Toilet seats are held in place by 3/8&quot; nylon screws, just right to serve as the bearing for these wheels, and in my junk I had such a screw. I sawed off the screw head and sawed off a chunk a bit longer than the original axle (which is 9/16&quot; long). I sanded the ends smooth. The part near where the head was has a smooth, unthreaded surface that serves as the bearing surface. I drilled a pilot hole in the threaded end and screwed the original self-tapping screw in, to make sure it fit. Then I assembled the unit where the wheel was originally on the rack adjuster, leaving just the axle sticking out. I slipped the original wheel onto the axle and slid the rack back into its supports. The support keeps the wheel from coming off, so I didn't need the lip present on the original axle.
I used the modification that <strong>cjp96</strong> did and all I can say is thank you for this site, <strong>cjp96</strong> and thank you for saving a lot of money. This fix cost me three dollars for the initial materials and when the other wheels break it will basically feel as though I fixed them for free. Cost of 10 washers:$1.18, Cost of 10 screws and nuts: $2.00, The power of people working together: <strong>PRICELESS</strong>
My dishwasher is fixed simply with one screw, nut and washer. Saved 40$ ... thanks to you !
Just a couple of improvements to what is already listed here.&nbsp; Mine broke in such a way that I had the wheel only.&nbsp; I&nbsp;put a nylon busing through the wheel with a 3/4 x 1/4 #10 stainless steel flat head screw.&nbsp; You could use a round head screw, but the flat head screw slides better.&nbsp;&nbsp;&nbsp; You will have to drill the hole in the rack bracket a little bigger, but the extra size will make it last longer.&nbsp; Put a stainless steel&nbsp;locking nut on the other end and tighten just enough so that it will hold and still allow the wheel to turn.&nbsp;&nbsp; Take the end cap off the slide, put the wheel assembly into the end of the slide and push it in, then put the end cap back on.&nbsp; Total cost $.88.
All too often people replace appliances rather then at least attempt to fix them because they feel they can't be bothered. Way too many times, it is a simple fix, too. <br/> I hope that is not a prevailing sentiment in Instructables and I am glad to see you're doing so much to encourage our replacing our <em>throw away</em> attitude with a <em>let's make it work <strong>or</strong> let's make it work better</em> attitude. <br/><br/>I don't own a dishwasher (well, to be honest, I <strong>am</strong> the dishwasher), but I did have a coffee maker blow out on me years ago, before I knew about this place. I removed the back and found that, the only reason it wasn't working anymore was because it had popped a hose off of a fitting. Securing it back on made it work again (and it taught me the lesson as to why you don't put cold water into a coffee maker that has just finished making a batch of coffee without letting it cool down first :-) <br/>
haha thanks for sharing, a reminder to double check if we can fix something before calling out the experts..
I don't believe mine is the same brand, BUT!! It's still a piece of crap design and this will do well. I was thinking about this and possibly using one of the rollers made for sliding screen doors that you find at Lowes or such places. Thanks for the instructable!
How incredibly handy...
Yay! Happiness is a working dishwasher.
About This Instructable
29,945views
1favorite
License:
Bio: Eric J. Wilhelm is the founder of Instructables. He has a Ph.D. from MIT in Mechanical Engineering. Eric believes in making technology accessible through ... More »
More by ewilhelm:LEGO table with integrated parts bin Custom Wooden Train Track X-crossing Mad Max and War Boy Nux father son costume
Add instructable to:
