Hi, I'm going to show you how to make a tiny TV/Oscilloscope. You will be working with a Cathode Ray tube which requires high volts and high pressure vacuums, so be careful. To build this you need patience.
Please rate my instructable or leave questions. They will be answered.
This is an old instructable I accidentally deleted a while ago and managed to find via a link deep in the interwebs. The TV has since been lost, but I plan on making a new and better one.
Step 1: Get All The Stuff
You will need...
Tools:
+ A soldering Iron/Gun*
+ Solder*
+ A small phillips screwdriver*
+ A Hot Melt glue gun
+ Hot Melt Glue
+ Scissors
Electronic Items:
+ 3 DPDT switches*
+ Reasonably thin wire*
+ Two nine-volt battery snaps*
+ A Relay*
+ An LM386 audio amplifier IC*
+ A 100k Potentiometer*
+ A 10uf Capacitor*
+ A Small Speaker*
+ Female AV Jacks°
Other Items:
+ An old video camera {circa 1990}
+ A craft box to build it in
*can be bought at radioshack etc.
°salvaged
Step 2: What are these dohickys?
Before you get started, you will have to take apart the viewfinder/microphone. Pretty fun actually. Pictures are here to help.
Step 3: Get out the Important part
Take out the video section of the viewfinder. Don't break any wires or anything and be very careful not to get shocked. Capacitors inside may still hold a small charge. Also, don't break the screen for christ's sake.
Step 4: Identify the connections
This is frustrating. You have to figure out what is power in and video in. Hook up a nine volt to random wires to find out. If the screen lights up, you have found the power input. Once that is found, add more wires until some garbage appears on the screen, that's video in. Mine came out like this...
Step 5: Build and connect
Have fun. Think, Cut, Solder, Sweat, Get Burned, Yell F*ck, Stomp around, Rest, Build, Freak out when it don't work, Cry, Scream, Pee, Wash Hands, Build, Get it Done, Then realize you forgot batteries.
A pictorial of the layout is below. The wires are obviously not 'connected' to the batteries, the 9v battery snap however, you get the idea.
Tips:
+ On the LM386, the side with the indentation is top. Very important.
+ The colors of your coil wires may be different. It is trial and error. Go to http://censtron.com/?p=18 for more information on coil hookup.
+ Taping wires down makes it easier to move around.
Step 6: Mount
Get the glue gun ready and build a thingamabob out of the craft box to make it look nice. It also may be a good idea to cut a hole for the screen...
1-40 of 175Next »
grampafish says: Feb 27, 2013. 4:03 PM
does anyone know the pinout for a panasonic wv - vf01 crt viewfinder? voltage needed already found video
aaronXtreme says: Jul 21, 2012. 6:17 AM
this rocks
spystealth1 says: Mar 3, 2012. 5:34 PM
Wow! I'm pretty sure I found an old video camera just like that in a thrift store.
bmarshall-2 says: Mar 26, 2011. 2:48 AM
100k pot for the gain adjust on your LM386, are you sure?! do you mean 1k?
kikazz says: Oct 14, 2010. 9:07 PM
I apologize for my rudeness... I should have been a little more thoughtful with my remarks. and hey, im starting to spell bad too. Sorry.
grenadier (author) in reply to kikazzJan 5, 2011. 6:23 PM
No problem, I used to use IE back then. IE had and still does not have a spellcheck.
kikazz says: Feb 7, 2010. 10:58 AM
pleeeeeeeeeeease learn to spell. it really is annoying. thanks
El Mano in reply to kikazzApr 12, 2010. 10:22 PM
Forgive me, but part of spelling is capitalization. Good job with the punctuation, though.
It's so funny when people post indecipherable garbage. It really reflects their personality.
12V says: Feb 5, 2010. 12:56 PM
i took apart a camcorder and found a crt with a 16mm screen and 6 pin base + a psu (2,200v) as well.
for brightness try adjusting the trimpots
e.g. those blue things with a screwdriver.
12V in reply to 12VFeb 5, 2010. 12:58 PM
try putting a 4.7-10 uf cap on the output of regulator  (mightprevent/reduce picture shrinkage)
luudvig says: Nov 22, 2009. 11:26 AM
Awesome!!
uskmrules says: Oct 12, 2009. 2:52 PM
 hey can u take a picture of the board where ur power wires and video wires connect to the tv board. i cant find the wires.
dark sponge says: Nov 22, 2008. 6:31 PM
Why are you using two 9v batteries? You could just use one. Better yet, use an old 9v wall adapter.
(by the way, I'm 13 too!)
grenadier (author) in reply to dark spongeNov 27, 2008. 2:28 PM
(removed by author or community request)
dark sponge in reply to grenadierNov 27, 2008. 4:09 PM
You could use 6 rechargeable AA batteries. It would last longer and would supply enough power for the sound and the picture at the same time.
grenadier (author) in reply to dark spongeNov 29, 2008. 8:33 PM
No; I have used a car battery and the same thing has happened.
ReCreate in reply to grenadierOct 4, 2009. 5:00 PM
Then the problem is not lack of power....
12V in reply to grenadierApr 10, 2009. 8:14 AM
can't you use a separate voltage regulator for each circuit. and a will charged battery.
dark sponge in reply to grenadierNov 30, 2008. 7:35 AM
That's weird...
grenadier (author) in reply to dark spongeNov 30, 2008. 11:43 AM
dark sponge in reply to grenadierNov 30, 2008. 3:19 PM
But that shouldn't happen if you use a bigger battery.
grenadier (author) in reply to dark spongeNov 30, 2008. 5:51 PM
well id does for some reason.
The 4th Doctor in reply to grenadierMar 7, 2009. 12:44 PM
I believe its because when the audio circuit is drawing power it steals voltage from the video circuit making it so although the powersource can supply the amperage the tv circuit isent getting the voltage to do so. ohms law ftw!
dark sponge in reply to The 4th DoctorMar 7, 2009. 2:42 PM
But that shouln't have happened when he used a car battery. Something else must be going on because it would have to draw tens (or even hundreds) of amps for this to happen with a car battery (which he said he tried).
The 4th Doctor in reply to dark spongeMar 7, 2009. 5:47 PM
Its the voltage the battery is capable of supplying the current but its voltage is divided up upon the 2 circuits spreading it thin it is kind of odd though that the video circuit has trouble when its rated for 5 volts maybe its just how much audio fluctuates
dark sponge in reply to The 4th DoctorMar 8, 2009. 8:25 AM
The amount of current a battery can supply is not based on it's voltage, but it's internal resistance. Bigger batteries (like car batteries) have a lower internal resistance, so they can supply a greater amount of current.
The 4th Doctor in reply to dark spongeMar 9, 2009. 8:24 PM
The maximum current is limited by internal resistance yes but the voltage/resistance determines how much current Does flow in a given situation every battery max's out somewhere but the current it supply's to a given situation is changed by its voltage and the loads resistance Anyways audio fluctuates CRT's seem to get affected from pretty small changes, my TV flashes a bit when i turn stuff on/off i suppose the video circuit probably doesn't even have a filter capacitor I shall leave it at that
grenadier (author) in reply to dark spongeMar 9, 2009. 7:15 PM
It seems to go away when i use a switching power adapter. Not a transformer adapter though.
12V in reply to grenadierApr 10, 2009. 8:16 AM
it's because they use voltage regulators.
okura says: Oct 3, 2009. 4:40 AM
Unbelievable.....a KID of 13yrs has SO much electronic savvy, so much vocabulary, so many tricks???? ...have seen many child prodigies and have mentored some myself, but this guy beats them all !! Either he's a miracle or a well planned hoax. Wish it isn't the later though...... I wish him good luck and Gods very best!!!! PS: wish there are ( I'm sure there are ) more kids like him around, too!
DELETED_dannydutton says: Aug 23, 2007. 6:46 AM
grenadier (author) in reply to DELETED_dannyduttonJan 20, 2008. 10:29 PM
yes grnd> -bat ground on vid cable is usually the 'hairy wire'
Aleksaa in reply to grenadierJul 15, 2009. 8:06 AM
seriously now that it really works or not, and is used as osciloscope?
Aleksaa in reply to AleksaaJul 15, 2009. 8:09 AM
just as in the picture, and who I make it just the same as in the picture and work? my viewfinder has only 4 pin.2 are the power and other 2 I do not know
grenadier (author) in reply to AleksaaJul 16, 2009. 10:03 AM
yes it should. so you found the power? good. thats tha hard part. one of those other two is video signal in. Cut a composite (yello) video cable in half and strip the wires. Attatch the shield (outer wire) to negative on the tv and power it up. plug the video cable into your xbox or something. now, try touching the center wire of the video cable to one of the two unknown wires. whichever one works is your video in.
aleksa in reply to grenadierJul 16, 2009. 2:20 PM
i done that and shows static.The viewfinder is from an old vcr blakpount cam....:(
grenadier (author) in reply to aleksaJul 17, 2009. 8:27 AM
OK, the one that shows static is video in. you need to make sure it is securely connected to get a picture, like soldered. then if it is still staticy, look for potentiometers on the circuit. they look like plastic screws. turn them while the TV is on. if you keep fiddling with them, eventually you should fin the sweet spot and get a picture. one is brightness, one is focus, and one is v-hold. there may be more. even better. is the video signal you are trying to put in NTSC? PAL or SECAM will not work.
aleksa in reply to grenadierJul 18, 2009. 9:09 AM
you are only 13 and you are a GENIUS...its working...!!!
razieltehawesome says: Mar 30, 2009. 8:51 PM
how would you make this just a tv and no oscilloscope?
aleksa in reply to razieltehawesomeJul 16, 2009. 1:36 PM
i done that it shows just static.....damn : (
1-40 of 175Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
