loading
Step 7: add the usb socket
wire up the usb socket red (pin 1) to out of the regulator and black (pin 4) to the spare  ground, ounce you have done that plug a battery in to the clip and a ipod to the usb socket and see if it charges (if it catches fire, you did something wrong check wiring and try again)
Should i attach a diode so when the battery dies it wont suck power from my ipod. If so where should i attach it.
7805&nbsp;regulator&nbsp;is the best&nbsp;choice&nbsp;in making that charger. readily available<br> any electronic shop<br> <br> but if your are planning to experiment something unique<br> you ca <strong>build a&nbsp;portable&nbsp;charger using &nbsp;transistor</strong><br> see picture below <strong>copied </strong>from&nbsp;<a href="http://www.simple-electronics.com/2010/11/simple-ipod-charger-using-6v-to-9v.html">http://www.simple-electronics.com/2010/11/simple-ipod-charger-using-6v-to-9v.html</a><br> <br> <br>
R1 is 390 ohms for 6V or 1.5K for 9V battery<br><br>what about R2?
i think its fake you can charge take a screenshot and put as lock screen but pretty cool im still gonna try it but is ur iPod jailbroken <br>
honestly it's not fake, my ipod is jailbroken, but that dosen't change anything
Where do the two wires soldered to the clip attach to?
there are a total of 3 wires soldered to the clip, two negatives and one positive, one negative goes to the voltage regulator, the other to the usb socket, the positive goes to the voltage regulator (who's output goes to the usb socket)
just a thought<br><br>there are Sealed Lead acid battery's<br>small and light enough to be cared around and will<br>provide a longer changer time<br><br>with whats been assembled is easily transferable
I actually ran these on SLA batteries a few times, but unfortunately i don't have these anymore, needed parts for other projects, but they do run perfectly from SLA batteries (and last a dam long time)
Why does it have to run on 5v? Why not the full 9v available?
9V will smoke your device...
the nearest electronics store is pretty far away (aka - im lazy)<br>my towns dump is very close to me however and they have a whole bin filled with electronics<br>which electronics have 5v regulators in them?
i found a few in an old laptop that was broken. they were within a couple inches of the usb ports
can anyone help me...I am not using a super small regulator like in the instuctable, just a normal sized one. It would be a great help if some one could made a diagram or show a picture to where the wires are going.
Buy LM7805 (3 terminals). Terminal 1: +ve from the batteries. Terminal 2: -ve from the batteries. Terminal 3: +ve going to the iPod. Also connect -ve of the batteries to the GND of iPod. Check for USB connector connections and double check the polarity before charging the iPod.
thanks.
&nbsp;I tried this and it doesn't charge my device (any of them cellphone or Ipod) I used a multi meter and I am getting 5 volts of current through the system. The one difference I did was that instead of using a usb socket I used a usb extension cable and cut it would this be the problem?&nbsp;
Check the polarity.
sometimes you need a resistor connected up with the data lines for some devices to charge, a better charger is the minty-boost having quite a high compatibility rate it does this using these 2 resistors in data lines,&nbsp;<br> check it out:<br> <a href="http://www.ladyada.net/make/mintyboost/" rel="nofollow">http://www.ladyada.net/make/mintyboost/</a>
I recently found a way to jailbreak my itouch 3g MC model, and it's tetherless too (meaning it can drain the battery and will still be jailbroken when turned back on. It's called Spirit. go chck it out.......<a href="http://tii.libsyn.com/spirit_jailbreak_and_cydia_tutorial_os_3_1_3_for_i_phone_and_i_pod_touch_and_3_2_for_i_pad/comments" rel="nofollow"><br /> http://tii.libsyn.com/spirit_jailbreak_and_cydia_tutorial_os_3_1_3_for_i_phone_and_i_pod_touch_and_3_2_for_i_pad/comments</a>
just tried that and it didn't work<br />
I think you have to start off the process with a itouch that's not jailbroken. so in order to do it, you'd need to restore your itouch before you jailbreak it with Spirit. So I don't think you'd want to start fresh, but just in case you ever do want a tetherless jailbreak and are willing to restore your device to get it, you know where to look.
that would be the problem<br />
About This Instructable
17,402views
56favorites
License:
More by max1zzz:Super Capacitor keyboard mod Mini portable ipod charger
Add instructable to:
