3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Miniature Camp Stove
While looking at camp stoves I thought that I needed a tiny one.
This is a wood burning (tea Light Alternative) miniature camp stove.
The stove is made from scrap copper tubing and about 3 hours of my time.
I used 2 5/8 copper tube and basic copper plumbing tube. all connections are brazed using my Smith Mini Torch.
When completed It will boil water and keep going for up to 25 minutes.
All that is missing is a laser etched maple leaf
Step 1Materials
Materials
  • last photo ←
I used scrap copper tubing that was 2 5/8 inside diameter. Along with small sections of regular 3/4 and 1/2 inch rigid plumbing copper.
You will need a section of flat copper. I used a section of the scrap tube to provide this. Flatten using scrap pieces of wood and a hammer rather than just a hammer since this will deform the metal. You want an even, flat surface.
Cut a section roughly the diameter of your tube for the burner box then another section that is the diameter of the pipe for the top and bottom caps.
36 comments
Dec 28, 2011. 1:22 PMAaronius says:
Your wood looks a little green!
Awesome mini-project!!
Dec 21, 2011. 11:56 AMElGooch says:
very nice project... not a bad way to spend three hours of your life. ;)
Dec 3, 2011. 8:08 AMarothschild says:
This is so cool! I hope you win!
Nov 28, 2011. 7:17 PMGpaSteve says:
Very nice.
Nov 25, 2011. 7:18 PMjavajunkie1976 says:
This is so cool!! I've been drawing stoves like this for awhile now. It reminds me of the stoves shown in "The Swamp" tent on the MASH tv series. I can't wait to make one.
Nov 22, 2011. 8:29 PMSpaceman Spiff says:
This is amazing, I voted and will likely make one of my own.
Nov 10, 2011. 7:31 AMGrumpyOldGoat says:
Just a suggestion to possibly improve the heat retention of an excellent design.
make the fire box a little taller, and bring the chimney out the back side below the top surface.
With the chimney coming directly out of the top, all the heat is leaving. With a space above the outlet, a higher temperature should be achieved, and it gives you an uncluttered top for a larger skillet to fry the sparrow egg on.
Nov 12, 2011. 5:17 AMTANZMEISTER says:
How does the airspeed velocity of an unladen sparrow compare to that of the swallow?
Nov 22, 2011. 6:50 PMbchambers999 says:
@Tanzmeister-
An African or a European one?
Nov 20, 2011. 7:32 PMGrumpyOldGoat says:
I meant to ask earlier, but it slipped my mind.
I need more information to actually answer that question.
What are you swallowing? Has it been well masticated and thoroughly mixed with a liquid?
Also, is the liquid water based, oil based or alcohol based?
Oil based should slide down rather quickly, but comparing the distance, assumed to be equal, to the distance the Sparrow travels, the Sparrow would win hands down.
Water is heavier and has a thicker consistency, so would naturally be slower.
Alcohol based, assuming again legal age to consume adult beverages, after the third swallow... who cares?
I do hope this helps clarify the question.
Nov 12, 2011. 6:18 AMGrumpyOldGoat says:
The two different body styles and wing/tail configurations make these two subspecies incomparable.
Swallows zip through the air like aerobats on steroids.
Sparrows hop around on my patio fertilizing the patio flooring where nothing can grow.
Nov 20, 2011. 2:38 PMak49er says:
As a physicist, I must disagree with your assertion regarding the non-sphericity of avian species. The spherical bird model is widely applied throughout physics, engineering, and numerous other disciplines[1] and has recently been empirically verified[2]:
As we know that birds generally share a common morphology, we may therefore conclude that a significant portion of birds are, in fact, spherical[3].
The problem, I think, is that your physicists are only educated to the undergraduate level. Postgraduate education would make such reasoning as this second nature.
[1]Kirkman, T. W. (1996).
[2]SzöllQsi, G. (2009).
[3] Troll, Edward D. ( :D )
Nov 20, 2011. 4:41 PMGrumpyOldGoat says:
Which exactly proves my point.
...unless your much higher level of education demands that all birds be considered to be quite similar to the their spherical body styles.
In which case I must point out that a Peregrine Falcon and an Emperor Penguin have few similarities, yet both are birds... As are Kiwis...
Nov 20, 2011. 6:01 PMak49er says:
Yup, both clearly spherical.
See
http://en.wikipedia.org/wiki/Spherical_cow
for a similar example.
Nov 10, 2011. 8:45 AMGrumpyOldGoat says:
How many sparrows do you know that have had a triple bypass?
Nov 22, 2011. 2:00 PMdblahnik says:
Love It Definately gonna build one !!!!!!!!!
Nov 17, 2011. 5:42 PMbigbang says:
This is so neat! Definitly on my to-do list now! Thanks for the great 'ible :)
Nov 11, 2011. 4:36 PMcanucksgirl says:
So Random_Canadian...
Where exactly were you years ago when my Ken and Barbie needed heat on those cold Canadian winter nights???
Nov 15, 2011. 2:25 AMcanucksgirl says:
lol ;)
Btw, Loved your ible!
Nov 11, 2011. 9:33 AMwobbler says:
Hot and cool! Funtastic.
Nov 10, 2011. 9:08 AMEternal_Tristan says:
Can you tell us a little about the process of brazing? How do the connections hold up with the heat of the stove? I've never tried to make a stove because I thought you had to use a welder.
Nov 7, 2011. 4:31 PMscoochmaroo says:
I hope you'll consider adding this to the Fire Challenge!
Nov 10, 2011. 3:46 AMspacesaver says:
THANKYOU!!!!!!! You have just given me a great idea for a Christmas gift to my brother. Over the years I have given him an antique, brass Primus stove, the same but converted for use as a desk light, and a motorcycle pistonrod assembly made into a desk clock. This will be a fitting continuation of this trend.
Cheers!! :-)
Nov 7, 2011. 4:22 PMmikeasaurus says:
This is great, what a neat design!
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
194
Author:Random_Canadian
I seem to keep breaking things....
