If you want to test out the J.C. Lee (the J.C. stands for Johnny Chung, but he does kinda does miracles too...) or the Smoothboard program at www.smoothboard.net (light years ahead, because Boon Jin started where JCL ended, thanks tthe open source programming...) well... YOU NEED an ir pen.
I do theatre in English, and Magic/circus for ESL. and you can see my page (only the blog is in English the rest is in Spanish.) here.http://www.fifthbiz.com) I work with a lot of teachers that know a lot about teaching and nothing about a soldering iron. So I came up with this..)
So, for non-techies or impatient people here is a tiny pen with just one LED, a 1.5 volt watch battery, and some electrical tape that you can make in less time then it takes to play the MacGuyver theme music.
Not apt for using with small children (because these are easy to eat) this is a good STARTER pen, but I think you will want to upgrade.
Nonetheless, these ROCK for a screen with projector and wii-mote behind, and with one in each hand... and for testing the Wiimote IWB for the first time.
Materials:
http://www.instructables.com/files/deriv/FL3/HQXG/FXA3D45B/FL3HQXGFXA3D45B.MEDIUM.jpg
1. ir led at 940 nm (i used a Vishay TSAL6400) which runs on 1.2-1.6 v costing14 centimos of a Euro, as I'm in Spain, it would be under 20 US cents , I think)
2. watch battery at 1.5 v (50 centimos/70 cents)
3. Electrical tape
4. Scissors.
5. Mobile phone with camera, webcam or digital camera (to check things out.)
Remove these ads by
Signing UpStep 1Understanding and preparing the IR LED.
Two basic concepts are essential.
1. The light is invisible to the human eye. (Infra-Red - below the red spectrum, the lowest visible light we can see.)
It is not invisible to a digital camera that is not protected against the IR spectrum, ie: mobile phone, digital camera or webcam, so we can use that to check things out.
2. The LED is polarity sensitive. �
You have to connect positive to positive, and negative to negative for it to work. The negative is the shorter leg of the LED. (To remember: Being short is negative for LEDs.)
http://www.instructables.com/files/deriv/F0K/ARID/FXA3D45C/F0KARIDFXA3D45C.MEDIUM.jpg
Preparing the LED.
On my watch battery, the positive side was flatter. So I bent the negative side to use as my trigger.
http://www.instructables.com/files/deriv/FE0/0D2B/FXA3D45A/FE00D2BFXA3D45A.MEDIUM.jpg
I then made a "v" bend (two would be better) in the positive (longer) wire, that goes flat against the battery to keep the LED flat and stuck to the battery in the next step, instead of falling out of the tape.
http://www.instructables.com/files/deriv/F30/NVOC/FXA3D458/F30NVOCFXA3D458.MEDIUM.jpg
Have to be careful, or make a bigger pen with little peeps around.
The assembly came apart quite easily - nothing was glued or soldered. I simply pulled out the UV LED and replaced it with one I had from an old remote control.
Works like a charm but the battery life is very short.
I intend to attach AA or AAA batteries to it somehow in the long term.
I only mention this because it was one or two Canadian dollar(s) for everything except the IR LED, everything was included, and it was already configured as a pen.
This is the pen in question:
http://www.dealextreme.com/details.dx/sku.88
That link is provided just so you all know what the pen looks like, but I suppose you could order the pen there as well if you like.
There are several variations of this idea out there, and a host of LED flashlights that could also be used.
I liked this one because it was shaped like a pen and all you had to do was screw off the top and pull out the entire LED assembly, attach the IR LED and put it all back together - no fuss, no muss.
http://whaleboneir.com/mark5.html
If you have any questions or need help setting up a Wii interactive Whiteboard, just send an email to james@whaleboneir.com
Thank you for the warning but I do make all of my IR pens myself, and setting up a Wii Interactive whiteboard, is enough of a DIY project in and of itself. Many people who are on this board also sell what they make, and where is the harm in that?
you can use it as a quick and dirty ir pen while you are trying out an wii whiteboard like this (rear projected) smoothboard one
www.youtube.com/user/fifthbizcom#p/a/u/0/nLbT-HAaspk
i honestly didnt know what it would be used for, no joke
thanks
